Hello
I am doing research on a which board to use on a CNC type project I am working on. I have done research online and cannot find the answer so I need assistance please.
On the Smoothieboard firmware, it is possible to have a set of GCode running from an SD card then after a certain position is executed, the system will wait until an external trigger is activated, then the Gcode continues running from the position where the pause was executed and continue is this fashion. It is a stop start motion.
The external trigger will be in the form of a switch from an external devices (will send an on/off signal).
Is this possible and if so what would be the starting point for me to figure out how to create something like this?
Thank you
