not a sanctioned board?
Posted by Dust
April 01, 2019 07:20AM
Intersting.
Playing with my smoothie board. (an original from the kickstarter)
It for a CNC machine so I install the CNC build
Version returns the following...
Build version: edge-5829d90, Build date: Mar 3 2019 14:55:00, MCU: LPC1768, System Clock: 100MHz
CNC Build 3 axis
WARNING: This is not a sanctioned board and may be unreliable and even dangerous.
This MCU is deprecated, and cannot guarantee proper function
How can this be a "not a sanctioned board" when its is an orrginal board?
VDX
Re: not a sanctioned board?
April 01, 2019 09:46AM
... the cloners are ever faster this days spinning smiley sticking its tongue out
Maybe something with the Arduino-brands?
Viktor
July 26, 2019 07:06PM
The "original" smothieboard comes with the LPC1769 MCU, as mr VDX said, you probably got a clone board.
I'm also have a board with the LPC1768 mcu, the error you got I was getting it too I was able to solve it by change the "dfu_enable" parameter to false:
dfu_enable                                   false            # For linux developers, set to true to enable DFU
Cheers.
July 26, 2019 11:10PM
The current smoothie website is not telling the entire story
It originally said "NXP LPC 1768/9 32-bits Cortex-M3 MCU, running at 96 to 120Mhz. 512kB Flash, 64kB RAM." (you can see this on [web.archive.org] )
somewhere between dec 9 2016 and dec 28 2016 it was changed to "32-bit Cortex-M3 LPC1769 with 512kB flash and 64kB RAM"
The official kickstarter which ran in 2015 came with the LPC1768 [www.kickstarter.com]
July 27, 2019 05:37AM
Dust
I didn't know that they started with both MCU's, It's quite strange that they "deprecated" the LPC1768 MCU, for all what I can see the only difference it's the clock speed.
Cheers.
July 27, 2019 06:21AM
Not sanctioned is not the same as deprecated, if it had said the latter I wouldn't have mentioned it.
July 27, 2019 06:45AM
Dust
I got your point but it's the same arguments for both topics, it's pretty much the same mcu, the 20mhz difference it's not really a game changer on any matter that I can think of.
Probably just to mess with all the copies that are flooding.
But still, the smoothie firmware works fine just disabling the dfu parameter or do you want to using this feature?.
July 27, 2019 11:37PM
Doesn't the MKS SBase use the 1768?
Huh.
July 29, 2019 04:57AM
Diggrr
Huh.
Yes and it is why I migrated to Reprap F., implemented by sdavi.
[reprap.org]
Edited 1 time(s). Last edit at 07/29/2019 04:58AM by MKSA.
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
April 01, 2020 06:06PM
A few of the early boards had LPC1768 instead of LPC1769.
Most cloners use LPC1768 ( saves them a buck ).
You can ignore the message you'll be fine.
