Getting a (RC) servo to move... November 26, 2017 12:26PM |
# Switch module for servo control switch.servo.enable true # Enable this module switch.servo.input_on_command M280 # M280 S7.5 would be midway switch.servo.input_off_command M281 # Same as M280 S0 0% duty cycle, effectively off switch.servo.output_pin 1.23 # Must be a PWM capable pin switch.servo.output_type hwpwm # H/W pwm output settable with S parameter in the input_on_comand #switch.servo.pwm_period_ms 20 # set period to 20ms (50Hz) default is 50Hz
Re: Getting a (RC) servo to move... November 27, 2017 11:28AM |
Re: Getting a (RC) servo to move... November 28, 2017 01:55AM |
