Rectangular bed leveling doesn't start February 13, 2018 02:54AM |
Send: N103 G31*25 Recv: Rectangular Grid Probe...(Here it starts with homing XYZ axes. After that, hotend goes up a little bit. Then it moves back to X- Y- direction until it hits the endstop)
Recv: Limit switch -X was hit - reset or M999 required Recv: Finding bed failed, check the maxz and initial height settings Recv: Probe failed to complete, check the initial probe height and/or initial_height settings
zprobe.enable true # set to true to enable a zprobe zprobe.probe_pin 1.28^ # pin probe is attached to if NC remove the ! - 1.28!^ zprobe.slow_feedrate 1 # mm/sec probe feed rate 5 #zprobe.debounce_count 100 # set if noisy zprobe.fast_feedrate 40 # move feedrate mm/sec 100 zprobe.probe_height 5 # how much above bed to start probe 5 zprobe.z_max 200 leveling-strategy.rectangular-grid.enable true leveling-strategy.rectangular-grid.size 5 leveling-strategy.rectangular-grid.initial_height 20 leveling-strategy.rectangular-grid.y_size 200 leveling-strategy.rectangular-grid.x_size 200 leveling-strategy.rectangular-grid.probe_offsets 0,0,0 leveling-strategy.rectangular-grid.home_first true
