Auto level does not seem to be working August 23, 2018 07:00PM |
PROBE LEVELS G28 (Home XYZ) 1: G32 Calibrate the machine 2: M500 Save probe results 3: G28 Home XYZ and the Jog down and Touch Bed 4: M306 Z0 Set and Save the Z-Offset 5: M500 Save homing offset 6: G28 GRID MESH 1: G28 Home XYZ 2: G31 Probe the grid 3: M374 Save grid to SD card 4: M500 Save probe results 5: M375 Add Grid command to SD card 6: G28 Home XYZ and the Jog down and Touch Bed 7: M306 Z0 Set and Save the Z-Offset 8: M500 Save homing offset 9: G28
Re: Auto level does not seem to be working August 24, 2018 07:48AM |
Moderator Registered: 12 years ago Posts: 351 |
Re: Auto level does not seem to be working August 24, 2018 11:44AM |
Re: Auto level does not seem to be working August 28, 2018 02:29PM |
arthurwolf
This could simply be something with how the probe measurements are done, interracting in a weird way with your machine geometry. Can you try changing ( increasing or reducing ) the grid resolution and seeing if it changes the effect ?
Re: Auto level does not seem to be working August 28, 2018 06:01PM |
Re: Auto level does not seem to be working August 30, 2018 02:32PM |
Re: Auto level does not seem to be working August 30, 2018 02:47PM |
Re: Auto level does not seem to be working December 18, 2018 03:04PM |
Re: Auto level does not seem to be working December 21, 2018 09:06AM |
Re: Auto level does not seem to be working December 21, 2018 09:08AM |
Re: Auto level does not seem to be working December 22, 2018 11:18AM |
arthurwolf
Can I see your config ? Do you have calibration enabled or both calibration and grid levelling ?
Re: Auto level does not seem to be working December 22, 2018 11:21AM |
Re: Auto level does not seem to be working December 23, 2018 11:25AM |
Re: Auto level does not seem to be working December 23, 2018 01:13PM |
Re: Auto level does not seem to be working December 23, 2018 03:12PM |
