A5984/A4982 and APFD mode (Is ROSC grounded on a v1 smoothie?)
Posted by aaronH
November 07, 2019 02:04PM
Nebbian in the Delta forum has a theory that the "tree ring" patterning seen on delta printers might be due to the drivers missing a step at the transition from slow to mixed decay.
[reprap.org]
I was looking over the A5984 and A4982 datasheets, and they have a mode called "APFD" which is turned on by grounding ROSC. This should keep the driver in mixed decay.
Based on the schematic on GitHub, Smoothie v1.1 boards don't ground ROSC. Is this correct?
Did you guys ever experiment with that?
