[Solved] Azteeg x5 GT with BSD2660, dual Z axis problems. May 10, 2020 08:33AM |
I have everything configured regarding the axis and stepper drivers, but I have problems on my dual Z axis. I am using pronterface to test, sadly smoothieware does not seem to have an option for TMC2660 debugging, like marlin has or I haven't found it yet.Quote
Diggrr
Dual Z in smoothieware isn't too hard once you find the near impossible to find clues. LOL
Herculien's machine gave me the clues, as his has a dual z.
First, Copy your config.txt off to the side or add a 1 to the copy's filename, so you have an untouched/unchanged reference.
There's 3 jumpers next to the E1 driver socket [JM6]. Connect them with 3 jumpers. This locks both E sockets in step with each other.
Then you swap numbers in the config.txt, the E1 pin numbers go in the Z part of the config, and Z pin numbers into the E1 part.
Your extruder motor will plug into the Z socket, and your two Z motors will plug into the two E sockets.
If your config.txt has the section for a second extruder, comment all those lines out. Mentioning the E2 pins anywhere will cause problems.
No need to increase current for Z, both are set to what you set for Z in config.txt (aka a single motors current needs).
As for the 2660's, I wasn't that successful with them. I use the 6128's.
Re: Azteeg x5 GT with BSD2660, dual Z axis problems. May 10, 2020 09:13AM |
Re: Azteeg x5 GT with BSD2660, dual Z axis problems. May 10, 2020 11:16AM |
Re: [Solved] Azteeg x5 GT with BSD2660, dual Z axis problems. May 19, 2020 01:24PM |
