Wattage rating for 24v power supply for smoothie June 01, 2020 04:43PM |
Re: Wattage rating for 24v power supply for smoothie June 02, 2020 07:47AM |
Re: Wattage rating for 24v power supply for smoothie June 02, 2020 05:43PM |
Re: Wattage rating for 24v power supply for smoothie June 03, 2020 02:10AM |
jbernardis
I was planning on swapping out the fans and the extruder heat cartridge for 24 volt versions, and the bed has an alternate connection configuration for 24 volts. At first glance, this would tell me that the 15 amp 24v PSU is fine, except that I would guess that the bed draw does not halve. It probably will continue to draw 11 amps at 24 volts which won't leave enough for the other components.
