Marlin 2.X Upload Fails every Time....
Posted by chriss199815
February 28, 2020 10:19AM
Hello,
Last week I trayed to upgrade my Marlin through Visual Studio Code and AutoBuildMarlin to my Ender 3 Pro with bord version 1.1.5. I can compile the code, and I was able to Upload the code once, but sadly since then no luck. I trayed using the standard Config's from the GitHub Repo from Marlin but no Luck. I have read about the BAUDRATE, but I haven't found a way to set it in Visual Studio Code. I tried 3 Different Computers with known good USB Ports, and 2 Different Know good USB Cables!
This is the output I get at the end of the Upload:
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xef
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xef
avrdude done. Thank you.
*** [upload] Error 1
======================================================================================= [FAILED] Took 113.91 seconds =======================================================================================
Environment Status Duration
megaatmega2560 IGNORED
megaatmega1280 IGNORED
rambo IGNORED
FYSETC_F6_13 IGNORED
FYSETC_F6_14 IGNORED
sanguino_atmega644p IGNORED
sanguino_atmega1284p IGNORED
melzi IGNORED
melzi_optiboot FAILED 00:01:53.913
at90usb1286_cdc IGNORED
at90usb1286_dfu IGNORED
DUE IGNORED
DUE_USB IGNORED
DUE_debug IGNORED
LPC1768 IGNORED
LPC1769 IGNORED
STM32F103RC IGNORED
STM32F103RC_fysetc IGNORED
STM32F103RC_bigtree IGNORED
STM32F103RC_bigtree_USB IGNORED
STM32F103RC_bigtree_512K IGNORED
STM32F103RC_bigtree_512K_USB IGNORED
STM32F103RE IGNORED
STM32F103RE_bigtree IGNORED
STM32F103RE_bigtree_USB IGNORED
STM32F4 IGNORED
STM32F7 IGNORED
ARMED IGNORED
STM32F103VE_GTM32 IGNORED
STM32F103VE_longer IGNORED
mks_robin_mini IGNORED
mks_robin_nano IGNORED
mks_robin IGNORED
mks_robin_pro IGNORED
mks_robin_lite IGNORED
mks_robin_lite3 IGNORED
jgaurora_a5s_a1 IGNORED
STM32F103CB_malyan IGNORED
chitu_f103 IGNORED
STM32F401VE_STEVAL IGNORED
FLYF407ZG IGNORED
FYSETC_S6 IGNORED
STM32F407VE_black IGNORED
BIGTREE_SKR_PRO IGNORED
BIGTREE_GTR_V1_0 IGNORED
BIGTREE_BTT002 IGNORED
teensy31 IGNORED
teensy35 IGNORED
esp32 IGNORED
linux_native IGNORED
SAMD51_grandcentral_m4 IGNORED
rumba32_f446ve IGNORED
rumba32_mks IGNORED
include_tree IGNORED
================================================================================== 1 failed, 0 succeeded in 00:01:53.913 ==================================================================================
open | download - log.txt (3.8 KB)
Re: Marlin 2.X Upload Fails every Time....
February 28, 2020 12:12PM
Settings in platformio.ini:
[docs.platformio.org]#
Herzl. Grüße
February 28, 2020 01:08PM
Hallo danke für deine Hilfe.
Ich habe die upload_speed jetzt überall auf 19200 gesetzt, das hat leider nicht geholfen confused smiley.
Hast du eventuell noch eine Idee woran es Liegen könnte.
February 28, 2020 03:14PM
Versuch es mal mit der Arduino-IDE.
Eigenartig ist, daß es einmal geklappt hat. Sieht nach diesem Fehler aus, der ist aber gefixt:
[github.com]
Versuche es mal mit melzi statt mit melzi_optiboot.
sanguino_atmega1284p, melzi und melzi_optiboot haben alle die Einstellung
board  = sanguino_atmega1284p.
upload_speed = 57600 bzw. 115200
Siehe hier: [github.com]
Herzl. Grüße
February 29, 2020 05:29AM
Hallo,
Also ich hab es geschafft das der Code in Arduino Compiled. Habe dort aber das gleiche Problem.
Habe nicht wirklich eine Möglichkeit gefunden die upload_speed zu setzten, könntest du mir dort eventuell weiterhelfen?
February 29, 2020 11:56AM
Anleitung für 1284p hier, Beitrag #1 von pert
[forum.arduino.cc]
Was steht denn im Gerätemanager unter Anschlüsse (COM & LPT)?
Herzl. Grüße
