Marlin 2.1.2.1, laser ttl pin number
Posted by rajthuvanoor
September 09, 2024 10:29PM
I recently upgraded to Marlin 2.1.2.1 and cingured laser / spindle pwm. What is the default laser ttl pin number? Please help.
Re: Marlin 2.1.2.1, laser ttl pin number
September 27, 2024 04:00AM
For Marlin 2.1.2.1, the default laser TTL pin can vary based on your board and configuration. It's often set in the pins_arduino.h file or in the configuration files for your specific setup. Commonly, people use pin numbers like D11 or D3 for laser control, but it's best to check your board's documentation or Marlin's configuration settings for the exact default. If you can’t find it, consider asking in the community for more tailored advice based on your hardware setup!
Edited 1 time(s). Last edit at 09/27/2024 04:03AM by Michealj.
