Re: Hangprinter version 3 December 07, 2017 01:22PM |
Re: Hangprinter version 3 December 07, 2017 10:45PM |
Re: Hangprinter version 3 December 11, 2017 08:00PM |
Re: Hangprinter version 3 December 11, 2017 09:15PM |
Re: Hangprinter version 3 December 12, 2017 09:20AM |
Re: Hangprinter version 3 December 12, 2017 10:50AM |
Re: Hangprinter version 3 December 12, 2017 09:41PM |
Re: Hangprinter version 3 December 13, 2017 12:25PM |
Re: Hangprinter version 3 December 13, 2017 04:38PM |
Re: Hangprinter version 3 December 14, 2017 08:34AM |
Re: Hangprinter version 3 December 14, 2017 09:06AM |
Re: Hangprinter version 3 December 14, 2017 02:44PM |
Re: Hangprinter version 3 December 14, 2017 03:29PM |
Re: Hangprinter version 3 December 16, 2017 09:31PM |
Re: Hangprinter version 3 December 17, 2017 05:20AM |
Re: Hangprinter version 3 December 18, 2017 11:43PM |
Re: Hangprinter version 3 December 19, 2017 09:04AM |
Re: Hangprinter version 3 December 19, 2017 09:19AM |
Re: Hangprinter version 3 December 23, 2017 07:22AM |
Re: Hangprinter version 3 December 27, 2017 03:49PM |
Re: Hangprinter version 3 December 27, 2017 03:59PM |
Re: Hangprinter version 3 December 27, 2017 04:13PM |
Re: Hangprinter version 3 December 27, 2017 05:40PM |
You should not have to do anything differently Just measure distances between pivot points as usual when calibrating.Quote
3dprintgeek
Is there any thing else I will need to do for a different size FH it will it be accounted for during the calibration?
Yes, both tmc2130SSS and Mechaduinos are supported in HangprinterMarlin. Be sure to use the Openscad_version_3 branch.Quote
3dprintgeek
Are [tmc2130SilentStepSticks] supported in the current Marlin you have in git?
Re: Hangprinter version 3 December 27, 2017 05:57PM |
3dprintgeek
@dc42
I will be heavily documenting my build - If you want to lend or donate a controller I'd be glad to test it. I'm going to design a pre-done board layout and try to come up with a CNC pattern. I already have a slide in mount for stock Arduino / Ramps, so exchanging the electronics is 1 optional screw besides the terminals. I could do the same for the Duet WiFi. I also have a similar mount for the Raspberry Pi. The board also will include handles and a ceiling pre-mount system. You mount the Pre-mount to the ceiling and mount the "main board" to the pre-mount in a slide in manner. OSMS . - Overhead Speed Mounting System
Thank you
Re: Hangprinter version 3 December 27, 2017 08:36PM |
Re: Hangprinter version 3 December 27, 2017 09:02PM |
Re: Hangprinter version 3 December 28, 2017 12:31AM |
Re: Hangprinter version 3 December 28, 2017 03:06AM |
Re: Hangprinter version 3 December 28, 2017 06:14AM |
Re: Hangprinter version 3 December 28, 2017 03:55PM |
