Re: Hangprinter version 3 June 14, 2018 03:29AM |
Is there a possibility to mirror these discussions? Are they accessible for non registered users?
. I guess - excluding maybe the gears because of tight fit - it is better to print the system on machines that it is designed for. I had some bearings slipping through the gears and spools because of differnce in tolerance from Markforged and consumer printers and I had to reprint the pulleys with the Wanhao in ABS. But they run fine in combination with the high resolution gears. Maybe it makes sense to machine the pulley in high-res (could be milled or powderbed printed) and the gears in DIY res.|
Re: Hangprinter version 3 June 14, 2018 03:30AM |
Re: Hangprinter version 3 June 14, 2018 06:39AM |
Moderator Registered: 13 years ago Posts: 401 |
Re: Hangprinter version 3 June 14, 2018 07:54AM |
Re: Hangprinter version 3 June 14, 2018 08:17AM |
Re: Hangprinter version 3 June 15, 2018 04:53AM |
Re: Hangprinter version 3 June 15, 2018 10:38AM |
Re: Hangprinter version 3 June 16, 2018 10:37AM |
Re: Hangprinter version 3 June 18, 2018 05:06AM |
Re: Hangprinter version 3 June 21, 2018 03:20AM |
Re: Hangprinter version 3 June 21, 2018 08:59AM |
33g is quite a lot. I'm interested in how low you can get.|
Re: Hangprinter version 3 June 21, 2018 10:10AM |
Re: Hangprinter version 3 June 21, 2018 03:46PM |
Re: Hangprinter version 3 June 22, 2018 06:09PM |
Re: Hangprinter version 3 June 23, 2018 03:27AM |
Re: Hangprinter version 3 June 25, 2018 10:51AM |
Have a look and let me know what you think. I plan on maybe doing a full set later this year.
Re: Hangprinter version 3 June 25, 2018 01:52PM |
Re: Hangprinter version 3 June 26, 2018 06:25AM |
Re: Hangprinter version 3 June 26, 2018 07:36AM |
Re: Hangprinter version 3 June 30, 2018 04:15PM |
I should have some prints done in time for MRRF next year. I might try to have them shipped there.|
Re: Hangprinter version 3 July 01, 2018 02:20AM |
Re: Hangprinter version 3 July 01, 2018 11:34AM |
Re: Hangprinter version 3 July 01, 2018 12:55PM |
Re: Hangprinter version 3 July 02, 2018 06:32AM |
brotherchris
Torb,
The simulator would be a great tool to have. I know very little about how to create it, but I am sure a developer could work it out fairly easily.
Chris
Re: Hangprinter version 3 July 02, 2018 07:07AM |
Re: Hangprinter version 3 July 02, 2018 11:25AM |
What I'm also planning, is to have three adjustable cross bars for sturdiness and for accurate calibration. I will most likely put them as down as possible and I also play with the idea to use them as a frame for the print surface. Do you have any additional ideas I should incorporate into the first design?
Re: Hangprinter version 3 July 02, 2018 12:07PM |
Re: Hangprinter version 3 July 02, 2018 07:17PM |
Re: Hangprinter version 3 July 03, 2018 04:33AM |
Re: Hangprinter version 3 July 03, 2018 05:26AM |
