Re: Hangprinter version 3 December 07, 2017 01:22PM |
Re: Hangprinter version 3 December 07, 2017 10:45PM |
Re: Hangprinter version 3 December 11, 2017 08:00PM |
Re: Hangprinter version 3 December 11, 2017 09:15PM |
Re: Hangprinter version 3 December 12, 2017 09:20AM |
Re: Hangprinter version 3 December 12, 2017 10:50AM |
Re: Hangprinter version 3 December 12, 2017 09:41PM |
Re: Hangprinter version 3 December 13, 2017 12:25PM |
Re: Hangprinter version 3 December 13, 2017 04:38PM |
Re: Hangprinter version 3 December 14, 2017 08:34AM |
Re: Hangprinter version 3 December 14, 2017 09:06AM |
Re: Hangprinter version 3 December 14, 2017 02:44PM |
Re: Hangprinter version 3 December 14, 2017 03:29PM |
Re: Hangprinter version 3 December 16, 2017 09:31PM |
Re: Hangprinter version 3 December 17, 2017 05:20AM |
Re: Hangprinter version 3 December 18, 2017 11:43PM |
Re: Hangprinter version 3 December 19, 2017 09:04AM |
Re: Hangprinter version 3 December 19, 2017 09:19AM |
Re: Hangprinter version 3 December 23, 2017 07:22AM |
Re: Hangprinter version 3 December 27, 2017 03:49PM |
Re: Hangprinter version 3 December 27, 2017 03:59PM |
Re: Hangprinter version 3 December 27, 2017 04:13PM |
Re: Hangprinter version 3 December 27, 2017 05:40PM |
You should not have to do anything differentlyQuote
3dprintgeek
Is there any thing else I will need to do for a different size FH it will it be accounted for during the calibration?
Just measure distances between pivot points as usual when calibrating.Yes, both tmc2130SSS and Mechaduinos are supported in HangprinterMarlin. Be sure to use the Openscad_version_3 branch.Quote
3dprintgeek
Are [tmc2130SilentStepSticks] supported in the current Marlin you have in git?
Re: Hangprinter version 3 December 27, 2017 05:57PM |
3dprintgeek
@dc42
I will be heavily documenting my build - If you want to lend or donate a controller I'd be glad to test it. I'm going to design a pre-done board layout and try to come up with a CNC pattern. I already have a slide in mount for stock Arduino / Ramps, so exchanging the electronics is 1 optional screw besides the terminals. I could do the same for the Duet WiFi. I also have a similar mount for the Raspberry Pi. The board also will include handles and a ceiling pre-mount system. You mount the Pre-mount to the ceiling and mount the "main board" to the pre-mount in a slide in manner. OSMS . - Overhead Speed Mounting System
Thank you
Re: Hangprinter version 3 December 27, 2017 08:36PM |
Re: Hangprinter version 3 December 27, 2017 09:02PM |
Re: Hangprinter version 3 December 28, 2017 12:31AM |
Re: Hangprinter version 3 December 28, 2017 03:06AM |
Re: Hangprinter version 3 December 28, 2017 06:14AM |
Re: Hangprinter version 3 December 28, 2017 03:55PM |
