Re: Hangprinter version 3
February 09, 2019 10:27AM
Hi guys just wanted to post a quick troubleshooting guide. Since most issues with the hangprinter are the same.
- Heating issues / Overextrusion
1) Calibrate extruder steps.
2) Check wire connections on the extruder end.
- If you're seeing temperature fluctuations:
1) Use thicker wires or double the number of wires connecting to extruder heater
- Bad connections
1) Create a strain relief on the wires on the extruder end ( Hint: Zip ties )
- Motors not working
1) Check connectors. And do a G6 command to test individual motors.
2) Try older version of marlin. Even try the old github hangprinter marlin fork.
- Bad prints, slack, tight lines, vibrations, gross errors in position.
1) Bad calibration. Try to achieve a less than 1mm error in your measurements.
2) Don't use nylon wires. Use the dyneema ones, they're made of ultrahigh-density polyethylene ( balistic fiber ).
3) Slower print speeds
4) Build wooden frame.
5) Use 32 bit board or try klipper with old 8 bit boards ( But at moment there's no kinematic support for the hangprinter)
6) Get creative. Ultrasonic ranger finder to measure distances. 1-2mm steel wire. 3d print a wire tensioner or even use a arduino to measure wire tension.
On a side note. The hangprinter deals better with organic shapes or prints that don't need a great deal of accuracy. Here's a little encouragement video from Saurabh Sogi: [www.youtube.com]
Edited 3 time(s). Last edit at 02/10/2019 03:09PM by LordThingol.
February 16, 2019 08:33AM
Finally first Print !!
Next Stage : Improve dimensional accuracy through some calibration !!
open | download - 52781886_2209702915947520_9177792125922705408_n.mp4.mp4 (127.5 KB)
February 16, 2019 09:16AM
@LordThingol
There's a lot of hours of HP wisdom in that post. Greatly appreciated!
@jaxshah
Awesome work!
torbjornludvigsen.com
February 21, 2019 11:41PM
@tobben, All the credits goes to you smiling smiley
March 25, 2019 05:20PM
is there a smart stepper firmware with the recent 0.39 updates?
March 29, 2019 04:50PM
Not that I know of. I think Trampas might be working on including HP support upstream, but you have to ask him to get the exact status.
April 13, 2019 10:13AM
Howdy everyone.
I'm revisiting this project after a long hiatus and moving locations.
Upon setting up the hangprinter again, i'm running into the same issue as I was before where when making Z-axis moves (G1 Zxx), the A, B, and C spools do not move proportionally to keep up with the D spool.
I have checked my stepper drivers and the jumpers were all identical on the bench, and the all appear to be set to 1/16 stepping. (DRV8825).
Does anyone have any suggestions for what to troubleshoot next? I'm so close to the finish line.
Calibration values below:
ANCHOR_A_Y -1345
ANCHOR_A_Z -116
ANCHOR_B_X 1165
ANCHOR_B_Y 632
ANCHOR_B_Z -116
ANCHOR_C_X -760
ANCHOR_C_Y 1105
ANCHOR_C_Z -116
ANCHOR_D_Z 2064
EDIT: It appears that my DRV8825s are still stuck in 1/32 stepping even after changing the jumpers around.
Edited 1 time(s). Last edit at 04/14/2019 11:42AM by Alandaeta.
April 21, 2019 09:07PM
After some more digging. I replaced my DRV8825 drivers with A4988s, which have a maximum of 1/16 stepping, and put the jumpers back in place.
Similar behavior after updating the firmware and everything, so I suspect maybe I have some funky values somewhere in the firmware where they shouldn't be.
Next troubleshooting will be to re-calibrate and then start from scratch with the firmware.
Thanks for coming to my TED talk.
April 28, 2019 08:34PM
One thing you might want to check, underneath the jumpers some of the Chinese ramps boards have a small trace connecting the pins without the jumper. I’ve seen it on two of my ramps boards from two different sources. You can’t see it unless you pry off that black plastic that’s usually underneath the jumper. Since you said your other drivers were stuck in in 1/32 mode it might explain some strange behavior.
May 02, 2019 10:53AM
I'm having problems getting my printer to react properly to G95 and G96 commands through Pronterface. I'm using smart steppers running the SmartStepper Subtree from the hangprinter repository. Everytime I issue a G95 or G96 command the printer will drop its connection with pronterface and reboot. I'm using the SCL and SDA lines from the LCD screen header through a level shifter to the ramps board. Connections were checked and rechecked. Printer reacts to G6 and G1 commands fine. Not sure what to check next, anyone have any ideas?
May 02, 2019 01:59PM
Hm. Then it sounds like those pins were not initialized properly by the firmware.
Do you have MECHADUINO_I2C_COMMANDS defined in your Configuration.h?
May 02, 2019 06:04PM
#define MECHADUINO_I2C_COMMANDS is uncommented. In Marlin right?
Edited 1 time(s). Last edit at 05/02/2019 06:06PM by Sgreener.
May 03, 2019 07:05AM
Hmm I think I might be using an older version of the motor firmware. If I'm building a V3 should I use the firmware on the gitlab Openscad_Version_3 repo? Or go with a fresh Marlin download and different motor firmware?
Thanks
SteveG
May 04, 2019 11:53AM
Yes, definitely use gitlab Openscad_Version_3 versions of the firmwares. Otherwise you'll bump into problems I don't recognize and can't fix.
May 12, 2019 08:24PM
Howdy all.
Starting to narrow down my issues hopefully.
Re-calibrated again, sanity check says +-3mm this time, so i'm feeling pretty good about it.
Drivers are all now confirmed to be in 1/16, no issues there.
The behavior i'm seeing is this:
Move -Y = lose tension
Move +Y = gain tension
Move -X = lose tension
Move +X = gain tension
Move +Z = lose tension
Move -Z = gain tension
Might be a rookie question, but is there a proper steps/mm setting in the firmware that needs to be adjusted?
May 13, 2019 09:42AM
Hi, steps/mm settings are not used by the Hangprinter.
The behavior you describe sounds like something is up with the anchor position calibration values. Are you measuring manually? If yes, then the most common mistake is to not measure between the right pivot points.
Are you measuring from the point where the line enters the effector, to the point where the line hits the anchor?
May 13, 2019 10:33AM
Thanks for the quick reply!
I was measuring manually, values reported in mm in the firmware.
I followed the attached diagram for where my measurement points were.
All measurements were taken at the same Z-height.
The sanity check came back within +-3mm.
Edited 1 time(s). Last edit at 05/13/2019 10:33AM by Alandaeta.
open | download - Hangprinter_XY_calibration_from_above.png (14.7 KB)
May 13, 2019 10:39AM
Great!
Was the nozzle was at the origin when the measurements were taken?
Have you also measured the Z-values (not depicted in the diagram)?
May 13, 2019 12:21PM
Yes!
The nozzle was at the origin. (Everything appeared to be parallel and centered)
I measured my AZ BZ and CZ values from the print surface to the top of the mover.
My DZ was measured from the top of one of the D-line idlers to the top of the mover.
It's got to be something easy i'm missing.
May 13, 2019 02:23PM
Nice. Only error is that Az, Bz, and Cz should be measured from where line enters mover to where line enters anchor.
Not sure if that error is enough to explain the behavior you're observing, but at least fixing it is a good start winking smiley
Edited 1 time(s). Last edit at 05/13/2019 02:26PM by tobben.
May 15, 2019 12:55PM
Hey
Just the other day I upgraded my Hangprinter with a new mover that includes corner clamps with mechanical advance. Also I switched the anchor points. In the configuration.h I changed the mechanical advance setting from 1, 1, 1, 1 to 2, 2, 2, 2? Is this correct.
I needed to change also the lines since the old ones weren't long enough. The A, B and C lines measure now 14m the D-line 6m. Those values went into the config file. Now I have few question...
1. The A, B and C-line rotational adjustment is quite obviously handled by pulling the line between the anchors either to the left or the right. But how about the D-line adjustment? I haven't seen any solutions for that? Is there one?
2. I have strange issues with the autocalibration script. When trying the standard method I don't get any results. The other method outputs some data, but the estimations are off by several meters!? I was using 21 datapoints collected at random positions at random levels. There must be something wrong I'm doing, I just don't know what.
Any ideas?
May 15, 2019 01:16PM
Yes, if you use corner clamps from HP4, then 2, 2, 2, 2 is correct.
D-line adjustment for HP4 doesn't have a good solution yet. If you have any progress with it, please track it here: [gitlab.com] smiling smiley
The autocalibration script acts like that if it can't find any optima at all. I have never used Marlin with 2 ,2, 2, 2 mechanical advantage, so I'm not entirely sure why your data is not good.
Do some sanity checking of M114 S1 output.
- Put mover at origin and do g96.
- Put mover at (0, 100, 0) and do M114 S1
- Does the A-motor report something close to 100?
- Put mover at (0, 0, 100) and do M114 S1
- Does the D-motor report close to -100?
If yes, try removing your latest data points one by one until the script starts to converge again. I have noticed that errors tend to accumulate if one is collecting data over a long-ish period. It probably depends on lines not winding/unwinding in a repeatable enough manner. If the line is very tight or very slack when rolled onto the spool, we pay an accuracy penalty when that line is unrolled again.
My work-around on the HP4 has been to go to origin and do g96 between each collected data point. Not really satisfactory, but might help your situation.
May 15, 2019 02:52PM
Ok, thanks Tobben. I'll look into your suggestions tomorrow.
I don't think this has anything to do with Marlin&mechanical advance. I had same issues last time I tried the autocalibration with standard hp3.
Now that you mention unwinding/winding the spools, I have to admit that two of the spools don't rewind them freely when in torque mode... We'll see.
I'll figure out something for the D-line adjustment. My new mover is now a prototype of the one I suggested couple of months ago. All corner clamps and the center piece are printed out of carbon fibre petg. It feels quite stiff already, but I had big trouble fitting the v groove bearings as the material won't flex a bit
May 19, 2019 08:51AM
Well, I think adjusting the spools did the job. They were fitted too tightly to the motor gears and that prevented them from rewinding properly in torque mode. As a result I wasn't able to get accurate data points for the autocalibration script. Now that I finally got it calibrated it seems to work perfectly.
As I write, the printer is printing a vase. Currently at Z 380 mm and with almost flawless surface quality eye popping smiley
At the beginning I tested few speed overrides, but the quality went down quite rapid.
Print speed is 60 mm/s and I ramped up to 150%
May 19, 2019 08:59AM
Awesome! Congrats on successful debugging =)
Looks like you downloaded those corner clamps before June 7, 2018 smiling smiley More recent versions are a bit stiffer (see [gitlab.com]) I stiffened them up before I actually had any practical problems, so yours might just work problem-free anyways. I'm interested to hear if your ABC lines bend your corner clamps over time or not winking smiley
May 19, 2019 03:54PM
Actually, this my own design, but it is based on your older design. I added a third slot for the center beams that connect the extruder carriage to the mover. I'll add some new pics on wednesday. If you like, I can share the design. Althpugj, it will undergo few redesigns when I get the time for it. It's still missing stress relief for the cables, a signle, magnetic, connector for all cables. And the fan duct doesn't work well. Or actually, it works too well. After the fans kick in, the heater can't maintain the temperature which results in system kill due to thermal runaway protection...
Next I will connect the precision piezo as z min endstop. Then it should be possible to do auto leveling by the nozzle. I still have this issue that the nozzle starts to lift the farther I go from the origin.
May 24, 2019 03:21AM
Hey, does anyone have experience in attaching a z probe to the hangprinter. I'm working currently with the precision piezo orion module which measures the z height by the nozzle tip. It's already attached to the extruder, but I'm having issues configuring the firmware. There's a tutorial on thingiverse how to tweak Marlin, but after doing the changes it won't compile. I'll put the compiler outpur here when I get to the printer. Maybe you, Tobben, have a solution?
Edited 1 time(s). Last edit at 05/24/2019 03:24AM by atmark.
May 25, 2019 09:05AM
Ok, major disaster...
One line snapped while printing overnight
And the culprit seems to be here in picture
The line sheared at the point where it enters the anchor at the top. Also for some reason the line at the bottom has been almost torn apart. It's the only line looking like this. Maybe the bearings are faulty or something. Anyway, I think there should be a safety measurement to kill the system, if a line should ever snap. @tobben is it possible to recognize such event by comparing the motor torques to each other?
May 25, 2019 09:36AM
Oh crap eye popping smiley
If the line jumps off the bearing, it wears down very quickly. It's not possible to use motor torques to recognize such an event, since a slightly mis-calibrated machine will also have close to zero torque in many positions. But we need to think harder about a anchor design where lines are guaranteed to always stay on the bearing, within a wide range of 3d angles.
The planned Cartesian position feedback feature would solve many problems, emergency stop upon snapped lines are one of them. [gitlab.com]
June 22, 2019 07:30PM
hey everyone!
I ve been following the project for about a half year now. Sounds super exciting to me (ie my compliments to tob and all the other involved members, developers, testers and enthusiastssmiling smiley! Im not very skilled at 3d printing but I believe I will learn as I go as Im too messy to do proper preperations when it comes to just about anything. But than, hey - I read all (yes, all 14 tongue sticking out smiley) pages of this thread, tob's blog, clicked on most of the links wherever i could, and started printing the parts, and am about to start oredring electronic components and hardware bits. I must admit, reading through all of this wasnt easy but helped me clarifed quite a bit. I feel I have an understanding of whats going on even though im missing a lot of details, whereas before i was just missing it all and only had this awesome 3d animation from hangprinter website going on and on in my head grinning smiley
my motivation is to print full scale gallery exhibition on the spot using this machine, photogrametry, and heaps of luck. I also like the "style" with which printer seems to print as exposing the technology of 3d printing by leaving imperfect traces behind makes it actually more human and accessible to me.
anyways, just wanted to share my enthusiasm here smiling smiley
im doing a shopping list right now and the aliexpress mid year sale ends in 2 days so im hoping to get some insights before that, but that may be too optimistic of a wish tongue sticking out smiley
still, i ll post here again in a bit
cheers for now!
mizu
