First Notes on a Pure Silver Heat Block September 01, 2021 08:02PM |
Re: First Notes on a Pure Silver Heat Block September 02, 2021 01:17AM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: First Notes on a Pure Silver Heat Block September 20, 2021 07:16PM |
Re: First Notes on a Pure Silver Heat Block September 20, 2021 07:32PM |
Andrew_F
This got me thinking..
Oxidation would be a problem on a copper block.
Does anybody make/sell a nickel-plated copper heat block?
Plenty of brass ("hardened copper") ones for sale on eBay, but brass and aluminium have similar thermal conductivity, so, aside from appearance, there would be little difference. Pure copper (Cu11000) and Silver have similar thermal conductivity A Nickel plated copper block would achieve this same result at a fraction of the cost..(Copper is a lot harder to machine than brass, so it would cost more to manufacture.)
Hardened copper (work hardened is the only way it's sold) would lose its temper the first time you heated it up.
Regards,
Re: First Notes on a Pure Silver Heat Block September 21, 2021 03:45AM |
Re: First Notes on a Pure Silver Heat Block September 21, 2021 08:50PM |
Andrew_F
Thanks rq3,
A local supplier had Nickel plated copper in C18150 (coefficient of thermal conductivity (k) ~ 324Wm-1K-1 at 20oC) at around 12 euro each delivered. C18150 is the alloy used in soldering irons.
At the price, I bought one to trial.
For comparison:
Pure copper (Cu11000) has a k value of around 400 at room temp, with pure silver being 440 at room temp.
At a guess, the aluminium used is 2000 series, approx conductivity k = 120-190, depending upon the alloy, at room temperature. The exact value varies widely, dependent upon the temperature and alloy content..
Data that I found (which I'd trust) in a brief 20 minute search was an NIST journal article. [srd.nist.gov] <-- p10 and 11 - values stay pretty well constant between 0oC.and 300oC
Interestingly, however, your diamond nozzle has a thermal conductivity closer to 2000 at working temperature (at 200oC) <-- p15, figure 6 of the above link. It gives (for type 1 diamond - clear) k=2000 at Room Temp (I'd trust your data better, as this data is 1972) but k essentially doubles at 500K to k ~3500 (it's on the nose of the conductivity curve.) Extrapolating, this gives you a k-value around 1600 to 2000.
Regards,
A
(this heater block is going to be heavy now, guessing the other reason why aluminium is used to minimise momentum.)
