Report on under bed sensor problems January 11, 2020 10:52AM |
Re: Report on under bed sensor problems June 24, 2020 06:18PM |
Re: Report on under bed sensor problems June 25, 2020 02:23AM |
Re: Report on under bed sensor problems June 26, 2020 08:30AM |
The Rime of the Ancient Mariner
He went like one that hath been stunned,
And is of sense forlorn:
A sadder and a wiser man,
He rose the morrow morn.
Re: Report on under bed sensor problems March 23, 2021 11:11AM |
Re: Report on under bed sensor problems March 29, 2021 12:14PM |
Re: Report on under bed sensor problems March 29, 2021 02:17PM |
Re: Report on under bed sensor problems March 29, 2021 07:55PM |
Re: Report on under bed sensor problems March 30, 2021 05:33AM |
Re: Report on under bed sensor problems April 02, 2021 06:13PM |
Re: Report on under bed sensor problems April 03, 2021 06:34AM |
Re: Report on under bed sensor problems April 04, 2021 06:44AM |
Re: Report on under bed sensor problems July 08, 2021 06:58AM |
Re: Report on under bed sensor problems July 08, 2021 05:31PM |
Re: Report on under bed sensor problems July 09, 2021 05:19AM |
Re: Report on under bed sensor problems February 12, 2022 11:37AM |
Re: Report on under bed sensor problems February 14, 2022 12:42PM |
Re: Report on under bed sensor problems February 14, 2022 02:19PM |
Re: Report on under bed sensor problems February 14, 2022 03:51PM |
leadinglights
Hi rq3, I will have to modify my hotend to accept a diamond nozzle as all of my nozzles have M4 threaded unions, but it sounds like a modification worth using.
The failure to trigger on dirty nozzles was part of why I started on this long investigation. Having two trigger points, one for a good contact and one for any contact allowed the detection of plastic on the nozzle. It was only after doing some quite thorough data gathering at various speeds and pressures that I came to the conclusion that it would be difficult or impossible to rely on underbed sensing even for the "any contact" detection. Even having a bed that is apparently without problems does not mean that somebody else using a quite similar bed won't have disastrous inaccuracies or failures to trigger.
I have a thought about a touch sensor that is very simple to make as well as being light and robust. Initially, it will use a piezo sensor to investigate accuracy. This will as stated in other posts be used with a single underbed sensor to get what is called "Z offset" and address effector tilt problems.
Mike
Re: Report on under bed sensor problems April 10, 2022 12:10PM |
Re: Report on under bed sensor problems April 12, 2022 05:38PM |
leadinglights
A new item I am exploring in this quest: A printer that uses 4 (yes four) sensors, each on the extreme corners of the build plate. A video showing this printer is on YouTube at [www.youtube.com] Although the printer shown uses expensive and heavy strain gauges - and will need quite complicated support electronics, the placement of the sensors at the corners should reduce dynamic and sensor miss-match problems to a lower area than three sensors.
Although I still have to build mechanical and mathematical models to check this out, I think (hope) that a version using piezo sensors will get around the combination of dynamic behavior and sensor miss-match which gives unexpected - and occasionally damagingly incorrect readings.
Mike
Re: Report on under bed sensor problems April 13, 2022 02:03PM |
rq3
.......................... I recently got a report of someone using one of the TAP-100 sensors I invented on an Anet A8. He reported that it was the best sensor he's ever used, and this is on a bed slinger. Why pursue complexity (other than that it's fun)? Four strain gauges!?
Re: Report on under bed sensor problems April 13, 2022 06:32PM |
leadinglights
The main project at the moment is a piezo touch probe for bed leveling and mapping, combined with a single underbed sensor for setting Z zero when the nozzle touches the bed. I will try to get a video on YouTube in the next week or so.
Mike
Re: Report on under bed sensor problems April 14, 2022 01:04PM |
rq3 February 14th 2022
after using my under-bed piezo for over a year, my experience has been that IF the nozzle is not scrupulously clean, or there is a cat hair on the bed, the M48 repeatability test in Marlin will either fail, or show an excessive standard deviation (over 3 microns).
