A Very Different Extruder May 03, 2021 06:07PM |
Re: A Very Different Extruder May 03, 2021 08:58PM |
Re: A Very Different Extruder May 04, 2021 10:12AM |
Re: A Very Different Extruder May 04, 2021 11:46AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: A Very Different Extruder May 04, 2021 03:56PM |
VDX
... its the combination of the 3 "slanted" bearings, what's propagating the filament, when rotating
Re: A Very Different Extruder May 04, 2021 04:32PM |
Re: A Very Different Extruder May 05, 2021 09:42AM |
Re: A Very Different Extruder May 05, 2021 11:54AM |
Re: A Very Different Extruder May 05, 2021 02:52PM |
Re: A Very Different Extruder May 05, 2021 04:04PM |
Re: A Very Different Extruder May 05, 2021 05:03PM |
Re: A Very Different Extruder May 05, 2021 05:15PM |
Re: A Very Different Extruder May 05, 2021 05:26PM |
MKSA
So ?
Where is the hot end, and all the rest ?
Seriously, I know how this "works", not a new idea. What would be new is a working and if possible better extruder !
Someone who boasts: "Very repeatable, and accurate to 125 nanometers (16 microsteps and a 1.8 degree stepper. 62.5 nanometers with a 0.9 degree stepper)." better proves it !
Re: A Very Different Extruder May 05, 2021 06:23PM |
Re: A Very Different Extruder May 06, 2021 12:11PM |
Re: A Very Different Extruder May 07, 2021 03:01AM |
rq3
A piece of paper, a pencil, and some trig tables will confirm the figures. Or maybe you can even use a calculator?
Re: A Very Different Extruder May 07, 2021 06:19AM |
Re: A Very Different Extruder May 09, 2021 04:27PM |
Re: A Very Different Extruder May 10, 2021 06:00AM |
Re: A Very Different Extruder May 10, 2021 06:35PM |
leadinglights
Just a passing thought: Is it possible that this would work with only two wheels? At first blush, this sounds silly as the filament would pop out sideways as very under-constrained. However, the sideways force may possibly be easily constrained with guides if they were slippy enough or maybe with guide bearings just beyond the ends of the drive bearings. The question is, how big should the wheels be? There would be no sideways force with infinitely big wheels but perhaps 20mm is close enough to infinitely big for our purposes.
Mike
Heatsink done and mounted May 11, 2021 09:08PM |
Tri-Metal Heatbreak May 12, 2021 03:39PM |
Anti-Torque May 17, 2021 06:49PM |
Re: A Very Different Extruder May 23, 2021 05:32PM |
Re: A Very Different Extruder May 24, 2021 06:43AM |
Re: A Very Different Extruder May 25, 2021 02:19PM |
Re: A Very Different Extruder June 02, 2021 03:54PM |
Re: A Very Different Extruder June 02, 2021 04:19PM |
Re: A Very Different Extruder June 02, 2021 04:32PM |
obelisk79
Do you have a screenshot of the updated design? I've been mocking up some simple experiments using 10deg pitch with some 683zz bearings and heatshrink to provide friction, I'm still dialing in tolerances on my design/print.
Re: A Very Different Extruder June 02, 2021 04:43PM |
