Re: A Very Different Extruder June 02, 2021 05:13PM |
obelisk79
I like it, I was concerned that the screw being on a bearing would just sit in place as the carrier spins around the filament, but if its working like this then I stand corrected. My brain can only visualize so much I guess. What about just using a single stationary grub screw with 2 bearings as an alternative (and more off-the-shelf) approach? I think that could work well.
I might go to a hardware store tonight to see what they have on the shelves to try that idea out.
Re: A Very Different Extruder June 02, 2021 09:53PM |
Re: A Very Different Extruder June 02, 2021 10:05PM |
Re: A Very Different Extruder June 02, 2021 10:39PM |
Re: A Very Different Extruder June 02, 2021 10:41PM |
NathanaelXYZ
I don't see how this newer design actually drives the filament-- it seems to me that the threads on the bearing sleeves would simply impress a "///////////" pattern on the cylindrical surface of the filament (much like a knurling tool) as they revolve around it, without any of the desired axial movement. The design will only function if the bearings don't actually rotate-- at that point the whole carrier would act as a solid, thread-forming nut being twisted onto the filament.
Re: A Very Different Extruder June 02, 2021 11:01PM |
Re: A Very Different Extruder June 02, 2021 11:16PM |
Re: A Very Different Extruder June 03, 2021 07:19PM |
Re: A Very Different Extruder June 04, 2021 03:35AM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: A Very Different Extruder June 04, 2021 09:18PM |
obelisk79
Ok, so need some help brain storming. What are some easy ways to evenly texture the bearings for filament grip that doesn't require specialty materials ie aluminum oxide powder or a laser.
Only thing I've tried so far was heatshrink tubing which was a big fail.
Thoughts on perhaps using thinned plasti-dip?
Re: A Very Different Extruder June 05, 2021 10:55PM |
Re: A Very Different Extruder June 06, 2021 05:12AM |
Re: A Very Different Extruder June 06, 2021 07:19AM |
Re: A Very Different Extruder June 06, 2021 12:43PM |
Re: A Very Different Extruder June 07, 2021 05:30PM |
Re: A Very Different Extruder June 07, 2021 11:08PM |
Re: A Very Different Extruder June 08, 2021 11:20AM |
Re: A Very Different Extruder June 08, 2021 03:28PM |
NathanaelXYZ
...appears to be filament dust on the roller threads in your posted image...
Re: A Very Different Extruder June 09, 2021 06:45PM |
Re: A Very Different Extruder June 09, 2021 07:55PM |
Re: A Very Different Extruder June 09, 2021 08:35PM |
obelisk79
Thanks for the update, mind attaching a photo or screenshot of the new design? I'm in the Navy and on a ship in the middle of the ocean. Due to network restrictions, I have no current means to transfer freecad files to my personal computer from the network to look at what you've done.
Re: A Very Different Extruder June 10, 2021 12:50AM |
Re: A Very Different Extruder June 10, 2021 06:21PM |
VDX
... for the videos -- I'm uploading my videos to youtube and posting the link ...
Re: A Very Different Extruder June 20, 2021 11:08AM |
Re: A Very Different Extruder June 20, 2021 05:26PM |
Re: A Very Different Extruder June 20, 2021 06:33PM |
Some Final (?) Notes June 27, 2021 06:17PM |
Final Prototype-time for more printing June 29, 2021 02:56PM |
Re: A Very Different Extruder July 18, 2021 10:21PM |
Re: A Very Different Extruder July 19, 2021 01:02AM |
