A Very Different Extruder
Posted by rq3
VDX
Re: A Very Different Extruder
July 19, 2021 01:55AM
... I've tested with some "micro-gearing/teething" with screw-heads for better friction -- it works pretty well with a fiberlaser and the edges/teeth are harder than the not heated surface cool smiley
Viktor
July 19, 2021 03:05PM
rq3: This looks quite similar to your extruder: [www.youtube.com]
Son of MegaMax 3D printer: [www.instructables.com]
VDX
July 19, 2021 04:33PM
... there where/are some other versions too around -- it's an older principle, patented 1952 by a Mr. Uhing for moving spool-heads on horizontal axes ... but could be used for other tasks too smoking smiley
Especially this "scewed tap-rollers" were sometimes used for special high precision CNC-applications ...
Viktor
rq3
July 19, 2021 09:21PM
the_digital_dentist
Yes, mentioned and linked to earlier in this thread. However, my drive rollers are not gear syncronized. Completely different design, unless we all want to give credit to Archimedes. And I do.
Generally there is rarely anything new under the sun, which is part of what makes the current patent system unworkable. Different topic.
rq3
July 19, 2021 09:32PM
VDX
I'm not sure what you mean by "screwed tap-rollers". The Rohlix linear drive is commercially available, but not particularly accurate or repeatable (see the very beginning of this thread).
Rolled threads are very common industrially, especially external. Some web searching will yield a plethora of data on the design of the tools used, and the criticality of their angles.
It's a good place to start if you want to repeat or improve upon my effort.
July 20, 2021 03:07AM
I think VDX is reffering to this patent: https://patents.google.com/patent/US2940322A/ which, as far as I'm aware, is the oldest recording of using canted bearing riding on a smooth rod to propel the bearing assembly (or rod, whichever way you look at it).
https://groups.google.com/g/3dp-ideas/c/YGFYajwyVrc is a google group discussing a similar extruder to the Fuselab 3D one, though predating their patent with a few years.
There is another execution of the idea here: https://www.reddit.com/r/3Dprinting/comments/nowr6v/i_made_a_silly_extruder_works_like_a_charm/.
By the way; hollow tubes with an outside thread are called "nipples" (though if you search for them, add "threaded"). Commonly available for lampfittings or as a plumbing connector. I've seen them with diameters ranging from 10mm to 1", in materials from stainless to brass.
What made you switch from the treaded sleeve to a single, sharpened concentric race? Ease of manufacturing? Is there a performance difference? Intuitively I'd excpect a lower gripping force, but also less grinding, compared to the threaded sleeve.
July 20, 2021 10:11AM
Skrogh
I think rq3 mentioned it in the other thread, but if I understand correctly, their concern was over repeatability. By using the concentric edge it allowed for greater repeatability and accuracy as it would always ride the resulting groove in the filament during retraction/de-retraction. You could probably get improved grip (if its even necessary in this application) by stacking additional races. However you'd have to consider implementation carefully. Do you space it to cut 2 helices into the filament or attempt to accurately space/machine them so they ride the same helix. For simplicity sake, I would assume 2 helices would be easier and potentially superior for grip.
July 24, 2021 08:08AM
Brilliant design! Might actually be light enough to convert my SCARA printer to direct drive. I have a 50 gram round NEMA14 I could use. And TMC2209 drivers, so I can adjust the microsteps to whatever works best. I'd prefer to use non-canted axles so I can make the carrier out of aluminum, but would all three rollers need to be threaded then since the filament would be getting dragged axially across the smooth rollers, or do you think the friction would be negligible? It would be nice not to have to worry about the issue of cutting multiple thread starts into the filament.
rq3
July 24, 2021 05:34PM
dekutree64
From my experiments, non-canted axles will work with one threaded drive roller. BUT, you will have to turn off all micro-stepping for the motor to get reasonable stepping rates. Use the largest pitch thread that you can fit onto the drive roller. The friction of the other two support rollers is negligable. I did machine an aluminum carrier with canted axles, and it wasn't too tedious. The worst part was feeding the canted 11mm end mill into the aluminum. It's engaging at the edge of the cutter, and wants to chatter pretty ferociously. Go slow. Once the end mill flat spot is done, you're all set to drill the hole for the axle threads, since you are going into a flat surface, and the mill is already properly located.
Edited 2 time(s). Last edit at 07/24/2021 09:30PM by rq3.
July 25, 2021 07:33AM
Thanks, that confirms my thoughts. I probably could make a fixture to mill/drill the tilted axes on my 3DOF mini-mill, but I'd actually prefer the higher effective gear ratio since it should allow using even lighter motors. There is one seller for pancake NEMA11 on ebay, though it costs $25 with shipping, and has a 4mm shaft, which doesn't leave much meat after drilling a 2mm hole.
I'm also toying around with the idea of making one of these based on a small outrunner instead of NEMA stepper. I'm fairly sure it would be possible to rewind one as a stepper as long as it has an even number of stator arms. Resolution would be very coarse (for example the common 12 stator arms/14 rotor magnets would be 28 steps per revolution, or 12.86 degrees per step), so probably will need microstepping even with straight axles (if my calculations are correct, that would give 128 full steps per mm with 1.75mm filament and 10mm rollers with 1.25mm thread pitch). Both the roller carrier and hollow mounting structure between the motor and hotend could potentially be eliminated. But there's nowhere to mount the anti-torsion wheel without an equally heavy structure to reach around the motor, so it may be a no-go. Depends on if I can come up with some other anti-torsion technique.
Edited 1 time(s). Last edit at 07/25/2021 07:46AM by dekutree64.
open | download - OutrunnerExtruder.png (3.5 KB)
rq3
July 25, 2021 04:25PM
dekutree64
You are right, there are several NEMA 11 pancake steppers available that have appropriate torque curves. They mass about 28 grams, which would make the entire assembly weigh in at about 60 grams. They have 3 mm shaft diameters, which doesn't concern me. A 0.5mm shaft wall would be more than enough. And yes, they are not cheap, but prototypes rarely are. I estimate I'm about $700 into this project so far, and I'm in the process of placing an order for the parts for the final, final, no really, the final design.
One hopefully final note. I have settled on two plain ABEC-5 shielded bearings as pressure rollers, and one flanged ABEC-5 shielded bearing for the drive roller. The flange will be ground to provide the required hardened knife edge, as I mentioned before. The note is that if the flange isn't ground symetrically, the filament extrusion and retraction will be different (which makes sense if you think about the filament contact geometry).
A final, final, no really, final note. It is possible for the drive roller to not roll at all, but just cut into the filament. This gives the fastest and most repeatable extrusion and retraction, but unless the knife edge is fabricated from boron nitride or zirconia, it will only last a few hours. I estimate I've run about 3 spools of PLA, ABS, and PETG through the rotating sharpened flange so far with no sign of wear, though the filament feed rate is reduced by about 20% versus a fixed knife edge.
Edited 1 time(s). Last edit at 07/25/2021 04:33PM by rq3.
rq3
Very Different Extruder Bill of Materials
July 26, 2021 07:04PM
Attached is the Bill of Materials for the Very Different Extruder (VDE-100), or SchnekenStruder. These are all common industrial parts, and require no machining with the exception of:
1) The Belleville washers act as preload springs for the bearings, and need to be stacked together, spun in a lathe, drill press, or a drill mounted in a vise, and ground with a dremel tool abrasive disc to an outside diameter of about 9mm to ensure clearance for the filament.
2) The drive bearing needs the same treatment so that its flange is ground to a symmetrical knife edge 10mm in diameter.
Note that I have increased all of the bearing axle diameters from 4mm to 5mm, so that I could use commonly available shielded bearings through out the design, and to stiffen the bending moment of the axles and their screw threads. I spent a great deal of time selecting parts so that the drive and pressure rollers are vertically aligned within 0.1mm (0.004"), inclusive of worst case part dimension tolerances. The bearing, washer, and spacer stack sequence is critical. It only goes together one way!
One of the issues with this entire design was that, while very easy to load (it just inhales the filament), it was a bear to unload. Originally I had the motor and drive assembly screwed to the groove mount adapter with 2 screws, which also fastened the anti-torque housing. I have changed to using rare-earth magnets implanted with epoxy in the groove mount adapter and the motor itself. For a filament change, or even an "atomic pull" for a clogged nozzle, I just twist the motor and drive assembly 45 degrees to unlock it from the groove mount adapter. It's then a simple matter to remove the whole thing, with the offending filament. The twist to unlock is required. It is VERY difficult to un-mate the magnets with a straight pull.
The magnets don't affect the motor at all, but may affect nearby sensors. This is not a problem for me as my nozzle contact sensor is a single under-bed piezo unit (previously described).
Have fun!
Edited 1 time(s). Last edit at 07/26/2021 07:09PM by rq3.
open | download - VDE_BOM.xlsx (10.4 KB)
July 27, 2021 08:58PM
Thank you! That ought to save me a few trials and errors. But I also now see where all your money went smiling smiley
We should be able to eliminate the expensive shoulder screws by machining the posts as part of the carrier and using short M3 screws to hold the rollers on. Also can leave a little ledge at the bottom to replace the shims. Of course this will mean that only people with CNC milling capability can make them, but for larger production runs the carrier will probably be machined regardless.
I don't think the belleville is necessary either with the machined posts. They can be made slightly shorter than the bearings, and use a countersunk screw to pinch the roller with some thread to spare. I've attached a drawing showing my envisioned post with ledge at the bottom to provide clearance, and screw with a bit of thread to spare at the top. The see-through blue rectangle represents the bearing.
For unloading, have you tried running it backward 15mm or so, waiting for the filament to cool, and then running some more? The previously-melted filament end may be too lumpy and jam, but may make it through. Especially if it's still a little warm and soft. The magnetic detachment system is certainly more reliable, but also adds to the cost.
EDIT: I had a second drawing attached before, but realized it made no sense.
Edited 1 time(s). Last edit at 07/27/2021 10:00PM by dekutree64.
open | download - MachinedPost.png (2.9 KB)
July 28, 2021 07:58AM
I've decided to go with the canted axle/sharpened bearing flange approach. I'm not sure my mill could handle boring out a 10mm steel screw, nor do I have an easy way to get it centered and vertical under the spindle, so I'm going to have to make some new fixturing regardless. And the bearing should be sharper and longer lasting.
I'm using a 4x8x3mm flange bearing because it's what I have on hand (along with a couple of 4x9x4mm without flange). And I think the 9.2mm flange diameter is good, because it gives exactly 0.1mm "extra" radius for penetration into the filament compared to the two idlers. It also makes grinding easier since you can just go until the edge is sharp, rather than having to reduce the diameter by a precise amount.
I made a 30 degree holder for my trusty DMT Dia-sharp stones out of a scrap of 2x4, with a little ledge glued along the edge to prevent the stone sliding down. Then hot glued the bearing to a 4mm rod, chucked it up in my mini-mill (a drill press would work just as well), applied some more hot glue, and went at it. I like to rub some water on the diamond stone for cooling and dust collection. Turn on the spindle and gently slide the stone back and forth against the bearing, while gradually changing Z position so you're not just running back and forth along the same line on the stone (spread out wear on the stone, and don't have to stop and clear away dust). Once the edge is sharp, repeat with finer diamond stones to polish. You really only need extra-extra-coarse and extra-extra-fine, but it's nice to have one more grit inbetween (I'd recommend fine).
Then take it out of the chuck, put some alcohol on your thumb and pick off the hot glue (hot glue releases with alcohol). Easy smiling smiley
open | download - HotGlue2.jpg (48.7 KB)
open | download - Grinding.jpg (54.3 KB)
open | download - Done.jpg (55.6 KB)
open | download - Edge.jpg (45.9 KB)
rq3
July 28, 2021 12:03PM
dekutree64
Looks nice! One thing I did find is that the knife edge on the bearing flange needs to be symmetric, not flat on one side. Otherwise, the extrusion and retraction rates will be different. Of course, that could be dealt with in software, but it's a quirk to be aware of. Also, the tiny radius on the edges of the flange need to be removed during the sharpening process, so you'll never get a razor edge on the full flange diameter if you bevel only one side.
I think you will need at least some method of quick access to the drive assembly, whether its magnetic or mechanical. Retracting molten filament through the drive leads to an un-godly mess. Ask me how I know.
The drive carrier can certainly be simplified and CNC machined for production once the exact geometry is nailed down. For development purposes, 3D printed carriers and "mix and match" standard washers, belleville springs, shoulder screws, bearings, etc., was an easy method of making the unit at least partially "RepRap"able, with easy machining of just a few standard parts that could be done without access to a lathe or milling machine.
Using belleville washers to preload bearings is pretty standard practice, as they apply a known force that compensates for dimensions that vary with load and temperature. I'd be very leery of using countersunk screws to preload a bearing's inner race, as the preload will be non-constant, or even non-existant, and the tapered screw surface will want to spread the bearing race. A real concern with very small components like these!
There is certainly more than one way to skin a cat, as your approach clearly shows!
Edited 2 time(s). Last edit at 07/28/2021 12:37PM by rq3.
rq3
Re: Very Different Extruder Bill of Materials
July 28, 2021 09:35PM
Sorry for the new post. For some reason I can't edit my BOM post. Attached is the STL file for the 5mm axle bearing carrier, edited and tuned to 1 micron. I print this directly in PLA at 50 micron layer height with a 0.4mm nozzle. I slice with the latest Cura with the Arcwelder plugin, 100% concentric infill.
For those designing the CAD file directly, note that every time you move the origin axis for the axles, especially for engagement angle, the contact point of the driver knife edge changes drastically.
open | download - Carrier_5mm.stl (190.5 KB)
PCR
August 10, 2021 12:15AM
rq3
August 10, 2021 08:03AM
PCR
[www.youtube.com]
This is about the 5th time someone's linked to this video. It's a completely different mechanism.
