Very Different Extruder in action July 14, 2021 03:05PM |
Re: Very Different Extruder in action July 14, 2021 03:36PM |
Admin Registered: 18 years ago Posts: 14,192 |
Re: Very Different Extruder in action July 14, 2021 05:07PM |
Re: Very Different Extruder in action July 15, 2021 05:01AM |
Re: Very Different Extruder in action July 15, 2021 07:38AM |
Re: Very Different Extruder in action July 15, 2021 01:15PM |
Re: Very Different Extruder in action July 15, 2021 01:24PM |
Re: Very Different Extruder in action July 16, 2021 07:39AM |
Re: Very Different Extruder in action July 16, 2021 08:19AM |
Re: Very Different Extruder in action July 16, 2021 11:57AM |
Re: Very Different Extruder in action July 16, 2021 03:25PM |
Re: Very Different Extruder in action July 16, 2021 06:12PM |
Re: Very Different Extruder in action July 16, 2021 10:52PM |
Re: Very Different Extruder in action July 17, 2021 10:51AM |
Woodgrain, no. Vertical banding yes, no matter what extruder I'm using. I've always attributed it to improper acceleration and/or jerk settings, but its never bothered me enough to spend time on. I probably will now that I have to play with those settings anyway for the screwstruder. The effect is visible on the corner of the test cube I posted earler, but as I said, its always been there.Quote
the_digital_dentist
Take a look at this thread at Duet forums, then look at your prints- do you see any of the "woodgrain" or vertical banding in your prints?
Re: Very Different Extruder in action July 17, 2021 02:11PM |
Re: Very Different Extruder in action July 17, 2021 03:53PM |
Re: Very Different Extruder in action July 17, 2021 04:26PM |
obelisk79
Is the edged roller you are using custom cut on a lathe or something off the shelf you bought?
Re: Very Different Extruder in action July 17, 2021 04:36PM |
the_digital_dentist
That looks like ringing, caused by flexibility in the mechanism and the moving mass of the extruder carriage, not the vertical banding that people think is coming from the gears in the BondTech extruders.
Re: Very Different Extruder in action July 17, 2021 05:53PM |
VDX
... my own designs are named something like "RollRing..." for the German name ... maybe something with "...spin..." or "...spinner..."?
Re: Very Different Extruder in action July 17, 2021 06:05PM |
Re: Very Different Extruder in action July 22, 2021 04:21PM |
Re: Very Different Extruder in action August 30, 2022 02:18PM |
Re: Very Different Extruder in action August 30, 2022 07:10PM |
Coarse thread/self-tapping screws would probably work even better. In my experience machine threads in PLA wear out pretty quickly, and thus are generally looser and more likely to wiggle free without spring washers. You could even vary the hole diameter so the threads don't have to cut very deep in the thin walled post and risk cracking it, but do have a nice tight fit once they get down into the solid base.
Maybe another attempt at my outrunner version, and just make the shaft supporting section much longer this time to hopefully eliminate the rotor tilting/magnet rubbing problem I had before.
Re: Very Different Extruder in action August 31, 2022 03:50AM |
Re: Very Different Extruder in action September 01, 2022 10:39AM |
Re: Very Different Extruder in action October 05, 2022 03:59AM |
Re: Very Different Extruder in action October 05, 2022 03:35PM |
