Maybe the World's Lightest Extruder March 02, 2022 06:40PM |
Re: Maybe the World's Lightest Extruder March 06, 2022 06:29AM |
Re: Maybe the World's Lightest Extruder March 06, 2022 09:40AM |
dekutree64
Fabulous! But I still think the posts should be machined as part of the carrier with m3 screws into the top of them to retain the bearings, to eliminate the cost and almost all the weight of the shoulder screws.
Unfortunately I still haven't come up with a machining strategy to make it with my current tools and skills, so I'll probably just stick with the NEMA14 and 3D printed carrier and leave the outrunner version as a theoretical design. Especially since I wouldn't be able to use it anyway since my printer needs a reverse bowden tube. But for printers where the spool is above the extruder, it should be possible to reach below 30 grams with a 2204 outrunner.
Re: Maybe the World's Lightest Extruder March 06, 2022 10:43AM |
Wouldn't it be better to grind more off the cutter bearing flange? I'd rather have the bearings fit onto the posts without any wiggle room.Quote
rq3
As noted above, one of the benefits of using shoulder screws is that you can very easily trim the shoulder diameter to adjust the bearing clearance. It's a one time thing during assembly.
Re: Maybe the World's Lightest Extruder March 06, 2022 03:03PM |
dekutree64
rq3
Another way to do fine adjustment is to add shims under the cutter bearing. And flipping it over, as you did. Viewing the CAD model from above orthogonal, you can clearly see how much the blade penetrates the filament as you move the bearing up and down the post.
Re: Maybe the World's Lightest Extruder March 16, 2022 05:52PM |
dekutree64
Re: Maybe the World's Lightest Extruder March 16, 2022 08:15PM |
Re: Maybe the World's Lightest Extruder April 12, 2022 05:17PM |
dekutree64
I've still only sharpened the flange on that one cheap 4x8x3mm bearing months ago, so the 9mm bearings are to go with that. I moved the posts 0.5mm closer to the center so the blade penetration depth is the same.
As for the BLDC motor, they don't necessarily need high current. It depends on how many turns of wire per stator tooth. More turns = more torque for a given current, less turns = more speed for a given voltage. Assuming you use the same mass of copper either way (thinner or thicker wire depending on turn count), the maximum power, torque, and speed are all the same. Just different proportion of voltage and current to get it.
And you don't need an encoder or gearing in this application. Torque to weight ratio is similar between outrunners and steppers at low speed (both are rated much higher than you can actually use). BLDC motors are a kind of coarse stepper, and can be driven open loop at low speed. With the usual three phase winding, you have 6 commutation steps per north-south pair of rotor magnets. So for the motor I'm using with 14 rotor magnets, that's 42 steps per revolution. But to be able to use the standard stepper drivers on 3D printers, you need a different winding scheme which results in 4 steps per north-south pair. 28 steps per revolution gives about 0.05mm per step with my Schnekenstruder carrier, whereas many printers use a 10mm drive hob turned directly by the stepper shaft, giving 10mm*pi/200=0.157mm per full step. So it should be more than enough resolution, assuming microstepping works with this non-standard BLDC winding.
Mostly I just think it looks cool And the total mass should be a little bit less due to screwing straight into the heatsink instead of needing a mount to suspend the motor above it. But the stepper is certainly the better choice for most reprappers since it can use a printed carrier and doesn't involve rewinding a motor.
I can't wait to see your new extruder design. 9 grams is unreal. I think we need to be more concerned with heatsink/heater block weight at this point
Re: Maybe the World's Lightest Extruder April 13, 2022 02:59PM |
Re: Maybe the World's Lightest Extruder April 13, 2022 05:21PM |
the_digital_dentist
PLA? Really?
Re: Maybe the World's Lightest Extruder May 16, 2022 07:14PM |
dekutree64
Re: Maybe the World's Lightest Extruder May 18, 2022 06:15PM |
Re: Maybe the World's Lightest Extruder May 18, 2022 08:59PM |
dekutree64
Congratulations on a job well done
How about a new BOM with sources for the extended race bearings and such?
Re: Maybe the World's Lightest Extruder July 04, 2022 11:39AM |
Re: Maybe the World's Lightest Extruder July 04, 2022 06:34PM |
arsi
Great job, this is exactly what I need. I'm working on my version of a BLDC extruder and I'm currently troubleshooting a problem with the accuracy of my rollers. I'd like to ask you if you could post a close-up photo of the sharpened bearing here, and pics or a video of how you sharpened it would be cool too.
Thanks.
Here is my project:
3d Model
BLDC Klipper firmware
Re: Maybe the World's Lightest Extruder July 30, 2022 03:38PM |
Re: Maybe the World's Lightest Extruder August 02, 2022 03:30PM |
Re: Maybe the World's Lightest Extruder August 02, 2022 04:38PM |
Admin Registered: 16 years ago Posts: 13,889 |
Re: Maybe the World's Lightest Extruder August 02, 2022 05:01PM |
VDX
... hmmm ... if you have the possibility to get hands on a marking laser - was experimenting with laser-engraving screw heads to get more "grip" or friction on the surface ... meant for filament transfer - but could be helpful here too ... here the related post:
[reprap.org]
And here the video, engraving one of the srew-heads (was something different for "give-aways") - [www.youtube.com]
This could be done with the surface of a ball bearing too ...
Re: Maybe the World's Lightest Extruder August 02, 2022 05:35PM |
Re: Maybe the World's Lightest Extruder August 03, 2022 02:29PM |
VDX
... so thumbs up from me!
If you're seraching powerfull micro-motors -- there are two main companies, building some - Faulhaber and Maxxon ... was developing assembling tools, stages and ideas for the smallest motors of them around 15 to 20 years ago
Re: Maybe the World's Lightest Extruder August 03, 2022 02:51PM |
Re: Maybe the World's Lightest Extruder August 03, 2022 06:18PM |
Re: Maybe the World's Lightest Extruder August 03, 2022 06:28PM |
VDX
... what's the stall-force of your piezo motor?
The radial weren't so strong - have some linear (pushing an Al2O3-rod) with 8N stall force, but less for "sound" operation -- have them in reserve, when in need for an AFM
Re: Maybe the World's Lightest Extruder August 03, 2022 06:42PM |
obelisk79
How exactly are you grinding a knife edge on such small bearings? I'd like to recreate one of these but I have a few limitations. I don't have a means to precisely drill a motor shaft hollow and I am unsure how I'm suppose to grind a double-bevel on a bearing flange (I should mention that I don't have access to a lathe and that may be the key to success).
Re: Maybe the World's Lightest Extruder August 11, 2022 05:44AM |
Re: Maybe the World's Lightest Extruder August 20, 2022 06:29AM |
Re: Maybe the World's Lightest Extruder August 20, 2022 05:34PM |
Re: Maybe the World's Lightest Extruder September 04, 2022 02:48PM |
Re: Maybe the World's Lightest Extruder September 18, 2022 09:54AM |
I have tried different knife shapes and the best solution for me is to thin the bearing flange to 0.2-0.3mm and perpendicularly ground to the required diameterQuote
1) The knife edge had to be symmetric, or the extrude and retract would be different.
