Re: Maybe the World's Lightest Extruder September 18, 2022 10:37AM |
arsi
I have tried different knife shapes and the best solution for me is to thin the bearing flange to 0.2-0.3mm and perpendicularly ground to the required diameterQuote
1) The knife edge had to be symmetric, or the extrude and retract would be different.
The force required for rotation has not changed...
But the main problem, which appears with all knife shapes, I have not yet managed to eliminate. The pressure on the filament from the hotend, causes a change in the thread pitch at different speeds of extrusion and therefore the number of steps per millimeter. According to this video, I'm not alone [youtu.be]
Re: Maybe the World's Lightest Extruder September 18, 2022 01:53PM |
arsi
Re: Maybe the World's Lightest Extruder September 18, 2022 07:16PM |
dc42
arsi
This is why RepRapFirmware supports nonlinear extrusion, to allow for the extruder steps/mm increasing with extrusion speed due to the increased back pressure from the hot end. See [reprap.org].
Re: Maybe the World's Lightest Extruder September 19, 2022 09:53AM |
Re: Maybe the World's Lightest Extruder September 24, 2022 10:35AM |
Re: Maybe the World's Lightest Extruder September 24, 2022 12:24PM |
Re: Maybe the World's Lightest Extruder September 24, 2022 12:29PM |
Re: Maybe the World's Lightest Extruder September 24, 2022 01:14PM |
rq3
You're making a fundamental error in thinking. Been there, done that. The extruder doesn't PULL on the filament (except to get it off the spool). It PUSHES the filament in to the nozzle.
Re: Maybe the World's Lightest Extruder September 24, 2022 01:28PM |
arsi
rq3
It's easier to simulate it that way. But it's about the same thing. I figured it out by measurements on a real hotend during extrusion. (50mm of filament at 1mm/s vs 5mm/s and the difference was 8mm)
A conventional extruder will easily rip the filament from my fingers when I hold it or loses steps, in this case unwinding the filament from the spool will have an impact on the pitch of the cut thread..
Re: Maybe the World's Lightest Extruder September 26, 2022 02:58AM |
Re: Maybe the World's Lightest Extruder August 02, 2025 04:13PM |
rq3
The attached photo is of a piezo drive motor that juuuust barely works. It weighs 4 grams.
Re: Maybe the World's Lightest Extruder August 03, 2025 11:39PM |
Re: Maybe the World's Lightest Extruder August 04, 2025 08:19AM |
Re: Maybe the World's Lightest Extruder August 04, 2025 08:37AM |
Re: Maybe the World's Lightest Extruder August 04, 2025 09:47AM |
Re: Maybe the World's Lightest Extruder August 04, 2025 11:05AM |
Re: Maybe the World's Lightest Extruder August 06, 2025 06:06AM |
dekutree64
I don't think it would need a force sensor or anything fancy. The bowden compression delay shouldn't be a problem since retraction moves don't require much force. The bowden motor only needs to respond fast enough to stop applying force in opposition to the VDE before it starts moving after a direction change, and to get the filament fully compressed before the VDE finishes de-retraction moves.
And I don't think it would even need a controller as fancy as B-G431B-ESC1. Since the bowden motor will only be applying high force at low speed, it can use voltage control without current sense. Current/torque will decrease when it speeds up during retraction moves, but again it doesn't need to apply much force.
But after giving it some more thought, I think it's more trouble than it's worth. Since VDE is backdriveable, we can at most double its usable force without risk of the bowden motor overpowering it. This approach would be better with a worm gear or something that can't backdrive. But then a little motor may have trouble turning the worm against the friction of the bowden motor pushing on it.
