An Optical Filament Sensor That Actually Works June 28, 2022 07:03PM |
Re: An Optical Filament Sensor That Actually Works July 02, 2022 11:22AM |
Re: An Optical Filament Sensor That Actually Works July 02, 2022 04:53PM |
Re: An Optical Filament Sensor That Actually Works July 02, 2022 07:28PM |
leadinglights
Very nice. I like the use of a red LED as a sensor and the tiny PIC mcu. Is there any chance of a photo showing the optical path and perhaps the programme?
Mike
Re: An Optical Filament Sensor That Actually Works July 16, 2022 12:22PM |
Re: An Optical Filament Sensor That Actually Works August 06, 2022 06:14PM |
Re: An Optical Filament Sensor That Actually Works November 09, 2023 03:28PM |
Re: An Optical Filament Sensor That Actually Works November 10, 2023 10:07AM |
looxonline
Am I right in thinking that you needed to cut two slots in the guide tube at the base for the LEDs to shine through?
Re: An Optical Filament Sensor That Actually Works November 17, 2023 02:23AM |
Re: An Optical Filament Sensor That Actually Works November 17, 2023 10:51AM |
Re: An Optical Filament Sensor That Actually Works January 03, 2024 02:09AM |
Re: An Optical Filament Sensor That Actually Works January 10, 2024 06:52PM |
looxonline
What was the reliability like with movement detection. I notice that you are looking for even just a single value difference between the two averages. It seems like ADC noise alone may be able to generate that. I am struggling to understand how movement of the filament would produce a different value across the ADC when the filament tolerance is around 0.005mm diameter these days. Surely any difference in diameter would be far outweighed by circuit noise.
Re: An Optical Filament Sensor That Actually Works June 13, 2024 02:37AM |
Re: An Optical Filament Sensor That Actually Works June 13, 2024 02:25PM |
Re: An Optical Filament Sensor That Actually Works June 16, 2024 04:50AM |
moosix
You mentioned that typical filament samples have an average error of less than 0.005 mm per 100 mm and 0.012 mm as the maximum error. This level of accuracy is very important for consistent 3D printing results. Manufacturers strive to minimize these errors, but there can still be variations due to factors such as material properties, manufacturing processes, and environmental conditions. The image you provided shows an oval PMMA filament measuring 1.95 mm by 1.58 mm. It is important to realize that sometimes even in this business to pause and , e.g. Relaxing at https://porn2all.com so download to get a dose of hormones. Filaments that deviate from a perfectly round cross-section are considered "non-circular". Although optical or physical sensors can accurately measure the cross-sectional area of such filaments, the apparent diameter (perceived by the printer) can vary significantly. The Roleo triangle example you encountered is intriguing! It emphasizes how irregular shapes can affect the printing process.
Re: An Optical Filament Sensor That Actually Works June 16, 2024 05:00AM |
leadinglights
I think some malware has injected something into this thread
Re: An Optical Filament Sensor That Actually Works June 16, 2024 05:23AM |
Admin Registered: 18 years ago Posts: 14,176 |
Re: An Optical Filament Sensor That Actually Works May 24, 2025 02:43AM |
Re: An Optical Filament Sensor That Actually Works May 25, 2025 05:44PM |
Re: An Optical Filament Sensor That Actually Works May 26, 2025 04:18AM |
Re: An Optical Filament Sensor That Actually Works November 08, 2025 03:52PM |
