Bed temperature offset and stabilization August 13, 2024 12:34PM |
Re: Bed temperature offset and stabilization August 13, 2024 02:33PM |
Re: Bed temperature offset and stabilization August 13, 2024 03:10PM |
Re: Bed temperature offset and stabilization August 13, 2024 07:44PM |
PCLoadPLA
I confirmed the temperature with a bimetallic hot-plate thermometer as well...I trust it, but it responds very slowly so I had to use the IR gun to measure the stabilization.
If the thermistor were in the aluminum, instead of the heater, the PID control should compensate for at least some of the offset and "lag" between the heater and the top of the aluminum.
For now I will just add 90 seconds extra stabilization time, but this doesn't seem a common thing to do, at least not within the Voron community. Even the default stabilization time of 10 seconds in the Marlin configuration files seems to indicate many people are not letting their bed properly heat up before printing. Since the first layer is obviously the most important one for bed adhesion, the temperature of the bed during the first layer is what's important, and it seems incredible if everyone is printing a first layer 10+ degrees cooler than their nominal bed temperature without knowing it.
Re: Bed temperature offset and stabilization August 14, 2024 09:20AM |
PCLoadPLA
