Re: Interest in environmental projects like "Ocean Cleanup" and more? October 02, 2018 03:19AM |
Admin Registered: 18 years ago Posts: 14,162 |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 02, 2018 03:46AM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 03, 2018 01:57AM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 03, 2018 05:24AM |
"I've asked you for some ideas about developing the software for a sort of \"swarm-bot ecology\" -- autonomous flying drones, rafts, ships, submarines and \"micro-submarines\", only capable of short travels, enough to start from a \"base\" (raft, ship or submarine), find and clamp to a piece of garbage ... and then start to float a \"swim bladder\" to rise the \"prey\" to the surface, were it can be collected conventionally (and tried to retrieve the micro-submarines)."
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 03, 2018 04:40PM |
VDX
then it even won't "notices" the wave
VDX
There is a lot more - e.g. "labyrinth structures" to "divide" the wave fronts and let them run out in side channels ... or deep (>100m) horizontal "wedges", like a beach in front of it with breakwater structures in random grids on top, so that the waves can distribute themselves on them and can decompose their energy ...
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 04, 2018 12:50AM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 04, 2018 04:06AM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 05, 2018 06:56AM |
In addition, the foundation is as stable as concrete, but has only 40 percent of the density of water: "A new, floating construction made of polystyrene and concrete," explains Bart Roeffen. "It consists of several layers: The lowest layer is made entirely of polystyrene, and several polystyrene blocks lie above it. The gaps are then filled with concrete. Together this results in a very stable material that is unsinkable."[/code]
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 05, 2018 12:21PM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 06, 2018 01:52AM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 06, 2018 01:58AM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 06, 2018 04:11AM |
) to fix them realtive ... or underwater-drives -- maybe the "Lamellar drives" I've mentioned previously - slow oszillating horizontal plates on the undersides, with skewed, merely elastic lamellas in the water, which works like "gigantic" cilia ... did this with parts in size of some ten centimeters, but it's much more efective, if bigger
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 20, 2018 11:57AM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 20, 2018 03:48PM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 24, 2018 05:47PM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 25, 2018 12:52AM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 25, 2018 02:41AM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? October 26, 2018 02:14PM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? November 17, 2018 04:14AM |
Re: Interest in environmental projects like "Ocean Cleanup" and more? December 03, 2018 04:11AM |
Harm of marine litter July 02, 2019 05:24AM |
