Re: Interest in environmental projects like "Ocean Cleanup" and more?
September 16, 2018 04:17PM
A good use for empty oil drums & old bikes.
September 17, 2018 12:40AM
I bet, every big city in China has those mountains of bikes. Now they start driving cars instead...Imagine how this scrap yard will look in ten years!
I used to work in bike service business and within 12 month I collected dozends of 'damaged' e-bike batteries. Usually, there was only one cell broken or the wiring/BMS failed.
With these 2nd hand batteries you could build a range extender for an e-car or re-use it as solar power buffer. But truth is, there is almost no business dealing with old e-bike batteries.
September 17, 2018 01:27AM
VDX
... "productivity" or "efficiency" are mostly technically and profit-oriented concepts, when size and costs count.
In the "wealth without money" view, what Adrian meant for the RepRap project, other problems and solutions can be totally different.
So why look at (and pay for) the "most productive" high-tech fabbed wind or solar generator, if low-tech variants in bigger counts can generate the same amount of energy?
This too is more in line with the point of view of our for-profit society, what is also the reason for our current environmental problems.
We need a different "view" on our world to find better ways ...
I think money is here to stay (barter is more difficult, it's much easier to have a central item you can trade for any other item). Even if it didn't "cost" would still exist in terms of how difficult something is to produce and how many resources it uses. "High tech" is good when it does more for less, when it makes it so things require less resources and processing to be made. We will not dig ourselves out of a garbage hole by making more garbage because "if we make enough of these less effective items it will add up to what we need". Why not do the same thing with fewer resources?
That being said, you'll have a hard time curbing resource use when demand keeps growing with a growing population. I'm not saying I have the answer to that problem, I'm not even sure there is a "good" answer to population growth that keeps everyone happy.
My $0.02? Aside from recycling and waste reduction, a closer look at passive devices would be good. A lot of pollution (the sort we can't even see) comes from energy production and use. Right now we have active heating and cooling systems, lighting etc. which could all be supplemented or even replaced with passive systems. Reduce energy consumption and energy becomes more plentiful, now you can use that extra energy for recycling which can be quite energy intensive.
Cool video on one aspect of the matter: [www.ted.com]
The best part? "Runs for free" makes it a lot easier to get people to adopt it. Plus this particular one actually removes heat from the planet (from my understanding?) which would be good in the short term. I can imagine it coming back to bite us later when we have a "heat shortage" or something of the like, but we can always kill that particular problem with fire.
VDX
September 17, 2018 02:51AM
... radiation cooling sounds good!
For the money-aspect -- I think, not "money" is the problem, but the general expectation that one can let one's money "work" in order to make more money out of a sum ... this is called the "value chain" and fired by interest and compound interest.
And the more money you invest, the more can be "earned"!
The biggest problem with this is "market saturation" -- the more money "works", the less it becomes worth and other problems grow like "bubbles".
Such "money bubbles" can only be dissolved if the excess stock of money is "destroyed" - in the past this was mostly done by wars, today by "market adjustments" which lead to financial crises or the like at regular intervals.
As said - this is only my personal opinion ...
Viktor
September 17, 2018 09:44AM
Imagine if Flying to the Moon too early was actually a human setback.
or the Push for Electric Vehicles by 2025 or whatever the stupid date was,
imagine its 50 yrs too soon, so we have all this leading edge junk
creating more mess than it solves,
imagine we used up a particular natural resource before we discovered it's true potential as some future catalyst,
perhaps if they knew the exact point it/changes to the sytem should be done, ie best for planet not for cash registers.
(perhaps the sooner the better isnt the right way but I know some progress happens haphazardly )
Removing heat from the Planet into out of Space, perhaps we need a bigger hole.
Edited 2 time(s). Last edit at 09/17/2018 10:46AM by MechaBits.
September 17, 2018 10:01PM
From my understanding it doesn't work on making a hole, more off which frequencies the atmosphere reflects or absorbs. Not saying it's a holy grail solution, I can imagine it'll have its own set of reprocussions, but just thought it might be of interest.
I like vdx's idea of recycling on the molecular level. That would mean a) there is no longer a recycling "cap" for things like plastics where the material can no longer be recycled, and b) it means compounds which are toxic and currently can't be recycled can be broken down and recycled.
Has anyone here heard of gasification? It's used to "recycle" organic compounds by turning them into a bio-gas. Not a perfect solution to landfill but it seems like a step in the right direction. At least fuel is usable and co2 is relatively easy to get rid of compared to landfill. This is a very energy intensive process but I believe it works for pretty much any organic compound.
Edit for clarity: I'm using "organic" in the chemistry sense, meaning hydrocarbon chains.
Edited 1 time(s). Last edit at 09/17/2018 10:02PM by Trakyan.
September 17, 2018 11:14PM
Perhaps Productivity is the Problem, they discover the Productivity Puzzle but only see it from one viewpoint...
So they keep banging on we need to make more...do more.. use more...buy our 5#!Zzle.
VDX
September 18, 2018 04:18AM
... yes, you have to change your perspective on environmental interactions and sustainability in order to find ways out of the current chaos eye rolling smiley
Viktor
VDX
September 19, 2018 04:10AM
... to motivate discussion, here a transcript from the German forum:
[luclass]:
sorry people...
I see interesting approaches to this global problem, but I think it is, as long as it is not guaranteed that more material will be "added",
for a basically laudable and necessary undertaking but unfortunately without a long-term perspective at the moment.
Islands made out of plastic dirt don't make any deeper sense because the stuff has to come out of the sea. And as already noticed here several times.... the effort is and remains more than gigantic... not to say pessimistically: The train has left a long time ago...
Doing something is always better than just watching, only you feel like an ant in the funnel of the ant lion.
The large accumulations of plastic represent actually only the tip of the iceberg, much more dramatically (from my point of view) is nevertheless the situation by the already decayed material which surfs as microplastic by the oceans. But a solution will be much more urgent because the plankton eaters pump themselves full with the microplastics and in the course of the food chain the plastic ends up on the plate. If the chain does not break down earlier, because the nutritional value of the microplastic is exactly zero.
There is still an idea going through my mind:
Swimming pool, swimmer washes his hair with a stuff which contains microplastic as a peeling additive, does not rinse his hair thoroughly and the stuff is also in the bath water.... there is still a filtering possible... and also still ´ne simple thing because yes only must be filtered.........but how one separates Plakton from plastic in the sea ???
Honestly... I feel like crying.....
The stupidity is round. Nobody knows where it starts and where it ends.
[VDX]:
... and? "Put your hands in your lap" and do nothing?
There are already some approaches (and there will be more and more) to prevent the spreading and recovery of the easily collected and visible garbage.
Some experts are already thinking about genetically modifying "oil-eating" bacteria in such a way that they can also eat plastic ... but that would also cause other problems.
My ideas around the "floating islands of garbage" go further than just collecting the floating plastic - plastic can easily be broken down into its chemical components ... or newly converted into "non-toxic" forms and with binding agents (sand, shell/coral limestone, tang/plant fibres, etc. ...) into building material for the islands and the further infrastructure.
If you think "big enough", even "artificial lagoons" with purified/filtered sea water can be created between islands ... but these are again only precursor ideas.
I think that we have to start at all! - with the time new ideas and concepts come together, which are possibly continuing ...
Viktor
September 19, 2018 01:26PM
Floating Islands
Looks like a Good Place to Start.
VDX
September 20, 2018 03:30AM
Hello folks,
I'm always trying to involve people (or groups) with "VIP status" in this discussion in order to enhance the topic and achieve more interest+participation.
If you know someone or have ideas of your own -- I know that it usually takes much longer until the resonance is so big that it becomes a self-runner (with the RepRap project about 3 years) ... but the more interested people and also the more "VIP's" there are, the faster it goes cool smiley
Viktor
September 20, 2018 08:08AM
Here's a device that could have saved a hell of a lot of waste over the years.
hope you can see it
[www.facebook.com]
shake up the rip off merchants
September 21, 2018 12:36AM
It's just a local German problem and not directly related to 'plastic polution', but the plans of RWE to lumber Hambacher Forst, just to get more area for brown coal surface mining is pi$$ing me off ATM.
It is the biggest hole on earth already and they want to increase it although they don't need that coal in the near future.
VDX
September 21, 2018 02:31AM
... yes -- this is one sample for "bad" environmental interactions even in countries, positioning themselves as "environmental friendly" sad smiley
Viktor
September 21, 2018 05:45AM
o_lampe
But... more bigger more better?
I kid, I kid. That's what they call "potential for growth". Coal can be sold even if you don't need it yourself, so digging a bigger hole is just digging more money as far as they are concerned. Until coal stops being a very useful and sought after resource, they'll want to keep digging.
September 22, 2018 02:20AM
You can't call yourself 'environmental friendly' and then sell this crap to others!
1to of brown coal produces 1to of CO2. Plus the polution to transport it to Australia or China.
It's like Switzerland would start exporting weapons of mass destruction...
VDX
September 25, 2018 03:43PM
... (transcript from the German thread):
... here's an example of the "recycled building material" I meant - these elastic plates and blocks for road edgings are probably made of shredded car tires glued together with an elastic "binder" and are more porous/air-permeable than waterproof (which is also an advantage for roads):
But I also saw others made of shredded CD's or PC-cases made of ABS, which were mixed with silicone - they were then rather "airtight".
For the baffle plates in explosive bunkers they made bigger blocks up to a few meters in size ... for the "floating islands" I think rather of some tens to hundred meters cool smiley
If the binder/adhesive itself is environmentally harmless (e.g. lignin/vegetable resin, currently a waste product of paper production), then only the embedded particles have to be appropriately selected - e.g. sand/lime or the collected waste plastic, by "thermal reduction" converted into carbon chunks -- and the extracted/vaporized toxic components otherwise bind or "chemically break down".
Here I also remember the "promises" of the nuclear industry with "low-level radioactive waste" poured into glass, which could be "safely" packed away for thousands of years - during a guided tour through the first German experimental reactor in Kahl (my neighbour's town) I got an eraser with a (non-radioactive!) black "glass cookie" inserted into a well, with which they wanted to demonstrate how "harmless" nuclear waste disposal could be eye rolling smiley
Viktor
September 26, 2018 12:24AM
Yeah, right! eye popping smiley
Reminds me of the 'duck and hide' videos they showed in US American schools during cold war...
Like, crawling under the desk would help against the H-bomb.
VDX
September 26, 2018 03:00AM
... here a link to a German company, selling parts made from recycled plastic:
[www.recpro.de]
[www.recpro.de]
The shown sizes are "small to medium", but no problem to make much bigger parts, if enough material at hand and the mould big enough cool smiley
Viktor
September 27, 2018 01:00PM
Just saw a report about a new plastic made from chicken feathers. The source is cheap and would usually be burnt. A win_win for our planet.
VDX
September 27, 2018 02:21PM
... but not for the chicken population sad smiley
Viktor
VDX
September 30, 2018 04:15AM
... I have just emailed Klaus Teuber (who doesn't know him - he is the author of "The Settlers of Catan" and a game series based on it) whether the idea to "colonize" the "garbage continents" could not be included in the series as a new game concept winking smiley
The Catan games are about discovering (unknown) countries and islands and building an infrastructure (settlements and roads) to build new settlements and roads with the resources earned in the settlements (or around them) ... doesn't this seem familiar if you think about the construction and "settlement" of the "floating islands"? cool smiley
Viktor
VDX
September 30, 2018 05:23PM
... another group, battling on the same front - [recycledisland.com]
Viktor
October 01, 2018 12:16AM
Reminds me of Kevin Costners 'Waterworld'. ...not the place they wanted to be and everyone was dreaming of 'Dryland'.
VDX
October 01, 2018 03:22AM
... floating structures, big enough to plant forests on them, can represent islands even better, than real ones - especially with the options to relocate ... or withstand any tsunami ... or ...
Think about all the micro-nations, living on islands, and rising sea levels ... best, they can do, is building/populating artificial islands ...
Viktor
October 01, 2018 05:21AM
That already happens in the Netherlands: floating houses connected to each other.
October 01, 2018 06:30PM
Seems that Floating Plastic Islands are teeming with nasty bacteria, so your going to need a real virulent non toxic competitor.
VDX
October 01, 2018 06:40PM
... it's more a decision, what to "terraform" first - moon, mars or "ye ole earth" smoking smiley
Viktor
October 01, 2018 07:28PM
Ruining the Earth is a world government conspiracy, to give them all jobs to do going forward, create the problem, then become the solution.
October 02, 2018 01:23AM
VDX
Where would the 'soil' come from that covers the plastic island? A good fertile ground can't be made easily. We'd have to steal it from somewhere.
Those garbage collections are far away from any current or coast. In the eye of the hurricane if you will. It would cost a fortune to get goods delivered.
We'd better grow trees and fertile soil in Sahara, where people really need it.
