Rostock: pregi e difetti. August 19, 2013 05:56AM |
Re: Rostock: pregi e difetti. August 19, 2013 08:54AM |
Re: Rostock: pregi e difetti. August 21, 2013 09:06AM |
Re: Rostock: pregi e difetti. August 21, 2013 09:25AM |
Re: Rostock: pregi e difetti. August 21, 2013 09:51AM |
Re: Rostock: pregi e difetti. August 22, 2013 07:18AM |
Re: Rostock: pregi e difetti. August 22, 2013 07:40AM |
Re: Rostock: pregi e difetti. August 23, 2013 01:21PM |
Re: Rostock: pregi e difetti. September 06, 2013 08:49AM |
DELTA_DIAGONAL_ROD 250 mm center-to-center distance of the holes in the diagonal push rods. DELTA_SMOOTH_ROD_OFFSET 175 mm horizontal offset from middle of printer to smooth rod center. If your print head is too high or low in the middle of the print surface, adjust DELTA_SMOOTH_ROD_OFFSET by half mm and try again. DELTA_EFFECTOR_OFFSET 33 mm horizontal offset of the universal joints on the end effector. DELTA_CARRIAGE_OFFSET 18 mm horizontal offset of the universal joints on the carriages. DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET) effective horizontal distance bridged by diagonal push rods. Z_HOME_POS 402 mm distance between nozzle and print surface after homing.
