Re: Info Prusa I3 reprapworld December 12, 2013 11:58AM |
Re: Info Prusa I3 reprapworld December 12, 2013 12:20PM |
Re: Info Prusa I3 reprapworld December 12, 2013 12:33PM |
Re: Info Prusa I3 reprapworld December 12, 2013 01:03PM |
Re: Info Prusa I3 reprapworld December 12, 2013 01:07PM |
Re: Info Prusa I3 reprapworld December 12, 2013 01:17PM |
Re: Info Prusa I3 reprapworld December 12, 2013 05:30PM |
Re: Info Prusa I3 reprapworld December 13, 2013 03:54AM |
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402,78.7402,4000,500} default steps per unit for ultimaker
//#define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402*2,78.7402*2,200*8/3*2,760*1.1*2} // default steps per unit for ultimaker
#define DEFAULT_MAX_FEEDRATE {500, 500, 5, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for r retracts
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
// #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
// #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
// The speed change that does not require acceleration (i.e. the software might assume it can be done instanteneously)
#define DEFAULT_XYJERK 20.0 // (mm/sec)
#define DEFAULT_ZJERK 0.4 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
Re: Info Prusa I3 reprapworld December 13, 2013 04:06AM |
Re: Info Prusa I3 reprapworld December 13, 2013 04:16AM |
Re: Info Prusa I3 reprapworld December 15, 2013 09:51AM |
Re: Info Prusa I3 reprapworld December 15, 2013 10:10AM |
Re: Info Prusa I3 reprapworld December 15, 2013 10:15AM |
Re: Info Prusa I3 reprapworld December 15, 2013 10:17AM |
Re: Info Prusa I3 reprapworld December 15, 2013 10:37AM |
Re: Info Prusa I3 reprapworld December 15, 2013 12:56PM |
Re: Info Prusa I3 reprapworld December 15, 2013 01:49PM |
Re: Info Prusa I3 reprapworld December 15, 2013 02:53PM |
). Tra l'altro settimana scorsa ha rifatto il manuale di assemblaggio e anche quello ora è fatto bene.|
Re: Info Prusa I3 reprapworld December 15, 2013 03:09PM |
Re: Info Prusa I3 reprapworld December 15, 2013 04:49PM |
Igloo_it
Buonasera Nicola ho provato a fare due prove e quando partiva si alzava un po' la z è faceva uno strano rumore nei motori poi stavalì una decina di secondi e partiva. Mah cosa strana cmq che amp mi consigli x stare dalla parte della ragione? Non so se in azienda ho qualcosa xké usiamo maggiormente quelli a 24 volts. Ciao
Paolo
Re: Info Prusa I3 reprapworld December 15, 2013 04:59PM |
Re: Info Prusa I3 reprapworld December 15, 2013 05:53PM |
Re: Info Prusa I3 reprapworld December 30, 2013 09:06AM |
Re: Info Prusa I3 reprapworld December 30, 2013 09:13AM |
Re: Info Prusa I3 reprapworld December 30, 2013 09:35AM |
Re: Info Prusa I3 reprapworld December 30, 2013 09:50AM |
Re: Info Prusa I3 reprapworld December 30, 2013 09:51AM |
Re: Info Prusa I3 reprapworld December 30, 2013 09:52AM |
Re: Info Prusa I3 reprapworld December 30, 2013 09:54AM |
Re: Info Prusa I3 reprapworld December 30, 2013 09:59AM |
