Collegamento fili EndStop January 23, 2014 08:07AM |
Re: Collegamento fili EndStop January 23, 2014 09:31AM |
Admin Registered: 12 years ago Posts: 954 |
Re: Collegamento fili EndStop January 23, 2014 10:31AM |
Re: Collegamento fili EndStop January 23, 2014 10:48AM |
Re: Collegamento fili EndStop January 23, 2014 10:53AM |
Capelion
La stampante è una pruse i3, gli endstop sono meccanici,
Ho letto la wiki e ne ho dedotto che il filo centrale non va collegato giusto? Solo gli esterni.
The recommended firmware will provide a configuration to use mechanical endstops with just two wires.
Find the area labelled "endstops" in the upper right corner of the board and for each of the X, Y, and Z pairs of pins (label should be below each set) do the following:
Connect S (top row, labelled to the left) on RAMPS to NC on the switch.
Connect GND on RAMPS to C on the switch.
Note: The latest firmware such as Marlin seems to use NO as the default pin on the switch. Otherwise you may need to invert the endstops in the firmware. You can use M119 to check your endstops status.
| ---- "Let me make my move" ---- |
Re: Collegamento fili EndStop January 23, 2014 12:00PM |
Re: Collegamento fili EndStop January 23, 2014 12:56PM |
Re: Collegamento fili EndStop January 23, 2014 01:28PM |
Re: Collegamento fili EndStop January 23, 2014 04:08PM |
Re: Collegamento fili EndStop January 23, 2014 05:05PM |
Re: Collegamento fili EndStop January 24, 2014 06:15AM |
Re: Collegamento fili EndStop January 24, 2014 07:10AM |
