Da Prusa a CNC 5 Assi April 23, 2015 11:01AM |
Re: Da Prusa a CNC 5 Assi April 23, 2015 11:07AM |
Re: Da Prusa a CNC 5 Assi April 23, 2015 02:50PM |
Moderator Registered: 13 years ago Posts: 1,865 |
Re: Da Prusa a CNC 5 Assi April 23, 2015 05:36PM |
Re: Da Prusa a CNC 5 Assi April 24, 2015 04:30AM |
inline void gcode_G0_G1() {
if (IsRunning()) {
get_coordinates(); // For X Y Z E F
#ifdef FWRETRACT
if (autoretract_enabled && !(code_seen('X') || code_seen('Y') || code_seen('Z')) && code_seen('E')) {
float echange = destination[E_AXIS] - current_position[E_AXIS];
// Is this move an attempt to retract or recover?
if ((echange < -MIN_RETRACT && !retracted[active_extruder]) || (echange > MIN_RETRACT && retracted[active_extruder])) {
current_position[E_AXIS] = destination[E_AXIS]; // hide the slicer-generated retract/recover from calculations
plan_set_e_position(current_position[E_AXIS]); // AND from the planner
retract(!retracted[active_extruder]);
return;
#endif //FWRETRACT
prepare_move();
//ClearToSend();
if (IsRunning()) {
get_coordinates();
prepare_move();
//ClearToSend();
void prepare_move() {
clamp_to_software_endstops(destination);
refresh_cmd_timeout();
#ifdef PREVENT_DANGEROUS_EXTRUDE
(void)prevent_dangerous_extrude(current_position[E_AXIS], destination[E_AXIS]);
#endif
line_to_destination(feedrate * feedrate_multiplier / 100.0);
set_current_to_destination();
la funzione che aggiunge il movimento è line_to_destination(feedrate...)
inline void line_to_destination(float mm_m) {
plan_buffer_line(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS], destination[E_AXIS], mm_m/60, active_extruder);
plan_buffer_line_mia(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS], destination[E_AXIS], destination[C_AXIS], mm_m/60, active_extruder);
//plan_buffer_line(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS], destination[E_AXIS], mm_m/60, active_extruder);
Non sto ad incollare qui la funzione in quanto, anche ripulita alla mia maniera rimane comunque abbastanza lunga; sostanzialmente dentro questa funzione ho aggiunto a tutti i calcoli anche l'asse C e facendo in modo di usare il T1 (secondo estrusore) della RAMPS
#define NUM_AXIS 5
enum AxisEnum {X_AXIS=0, Y_AXIS=1, A_AXIS=0, B_AXIS=1, Z_AXIS=2, E_AXIS=3, C_AXIS=4, X_HEAD=5, Y_HEAD=6};
const char axis_codes[NUM_AXIS] = {'X', 'Y', 'Z', 'E', 'C'};
#define AXIS_RELATIVE_MODES {false, false, false, false,false}
#define DEFAULT_AXIS_STEPS_PER_UNIT {160,80,4000,42.666,42.666} // default steps per unit for Ultimaker
#define DEFAULT_MAX_FEEDRATE {500, 500, 3, 45, 45} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {6000,6000,50,9000,9000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
Da notare che sull'enum degli assi ho modificato la sequenza in modo di avere X Y Z E C = 0 1 2 3 4|
Re: Da Prusa a CNC 5 Assi April 24, 2015 07:18AM |
Re: Da Prusa a CNC 5 Assi April 24, 2015 07:59AM |
Re: Da Prusa a CNC 5 Assi April 24, 2015 11:06AM |
) lavoro da 28 anni in un'azienda che produce CAD/CAM |
Re: Da Prusa a CNC 5 Assi April 26, 2015 12:08PM |
Re: Da Prusa a CNC 5 Assi April 26, 2015 12:23PM |
Re: Da Prusa a CNC 5 Assi April 26, 2015 12:44PM |
Re: Da Prusa a CNC 5 Assi April 26, 2015 12:46PM |
Re: Da Prusa a CNC 5 Assi April 26, 2015 01:08PM |
Re: Da Prusa a CNC 5 Assi April 26, 2015 03:30PM |
Re: Da Prusa a CNC 5 Assi April 26, 2015 04:44PM |
Re: Da Prusa a CNC 5 Assi April 27, 2015 02:48AM |
Re: Da Prusa a CNC 5 Assi June 07, 2015 03:18PM |
Re: Da Prusa a CNC 5 Assi June 08, 2015 02:48AM |
Admin Registered: 13 years ago Posts: 954 |
Re: Da Prusa a CNC 5 Assi June 08, 2015 03:16AM |
Re: Da Prusa a CNC 5 Assi June 09, 2015 04:03AM |
Re: Da Prusa a CNC 5 Assi June 10, 2015 06:17AM |
Re: Da Prusa a CNC 5 Assi June 10, 2015 01:43PM |
Re: Da Prusa a CNC 5 Assi June 10, 2015 03:12PM |
Re: Da Prusa a CNC 5 Assi August 22, 2015 02:17AM |
Re: Da Prusa a CNC 5 Assi January 09, 2016 05:41AM |
Re: Da Prusa a CNC 5 Assi January 16, 2016 03:05AM |
Re: Da Prusa a CNC 5 Assi January 30, 2016 09:29PM |
Re: Da Prusa a CNC 5 Assi February 01, 2016 02:34AM |
Re: Da Prusa a CNC 5 Assi February 03, 2016 08:42PM |
Re: Da Prusa a CNC 5 Assi April 24, 2016 04:30AM |
