drivers afstellen May 12, 2013 04:02PM |
Re: drivers afstellen May 12, 2013 05:02PM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: drivers afstellen May 12, 2013 05:41PM |
Re: drivers afstellen May 12, 2013 06:13PM |
Power dissipation considerations
The DRV8825 driver IC has a maximum current rating of 2.5 A per coil, but the current sense resistors further limit the maximum current to 2.2 A, and the actual current you can deliver depends on how well you can keep the IC cool. The carrier’s printed circuit board is designed to draw heat out of the IC, but to supply more than approximately 1.5 A per coil, a heat sink or other cooling method is required.
