3D Printing Challenge Print
Posted by IP3D
September 30, 2015 02:07AM
Nah - Ini kesukaan bro Zungmann - Pyramid
STL attached
Ayo - siap2 ngeprint....
open | download - Pyramid.stl (255.2 KB)
Re: 3D Printing Challenge Print
September 30, 2015 02:10AM
ogut ikutan ya. yang laen ikutan juga donk biar rame. kl gagal gpp posting aja. biar share sama sama problem nya dmn supaya kita belajar bareng.
September 30, 2015 03:04AM
Mana nih yang lain - silent reader - malu-malu atau gimana?
September 30, 2015 03:18AM
Hadir, ane ikutan bro
Pla esun 1.75 suhu 190
Mesin prusa i3 dasziel , speed 50
Edited 1 time(s). Last edit at 09/30/2015 03:21AM by dasziel.
September 30, 2015 03:25AM
lha - nongol langsung show thumbs up smileys with beer
Hahaha pake esun PLA 190C - takut stringnya keluar... hehehehhe
Edited 1 time(s). Last edit at 09/30/2015 03:28AM by IP3D.
September 30, 2015 03:31AM
Seru juga nih, iseng iseng daripada suntuk, hasil masih kurang halus permukaannya speed lupa diturunin.
Benar bro herman, takut gagal dan string keluar ane pakai yang pasti pasti aja, pla esun.
Ayo mana yang lain
Edited 1 time(s). Last edit at 09/30/2015 03:56AM by dasziel.
"if you don't know how to build better you buy good printer first and try to learn from there" -- By Herman IP3D
REPRAP Prusa i3 Dasziel Rework ready to print 8.5jt, hasil print super smooth.
Support filament flexible rubber, wood 10jt
Profesional jasa printing or costumize 15jt<
[forums.reprap.org]
Printer 3d build up : Rapide lite 200 , 26jt.
Jasa rakit, servis, tuning, programming, untuk semua jenis printer 3d.
Khusus yang mau belajar rakit printer 3d tersedia part set lengkap dan tutorial (call for price).
Jual part printer 3d , printed kit, dll.
Menyediakan filament berkualitas untuk hasil print yang baik sebaiknya konsultasi dulu, harga >250rb/kg tergantung jenis.
Contact dan Whatsapp 082111703999
Office : cengkareng indah blok ic/1a, jakarta barat
September 30, 2015 06:22AM
Mo kumpulin tugas kuliah dulu nih pak guru. file nya greget nih pak guru.
Edited 1 time(s). Last edit at 09/30/2015 06:26AM by djunz.aza.
September 30, 2015 06:38AM
Karena kesukaan, maka masih ada stok foto pyramid di hp, yg berhasil dan 'gagal'.
Si pyramid biasa saya pake buat kalibrasi retract dan extrusion flow. Ujungya itu lho...menantang sekali.
September 30, 2015 06:41AM
HAHAHAHA,
Mau benerin ujung - gampang.... print 2 model together kasih jarak 3-4cm
Silahkan print lagi...
BTW sekedar info - saya print nya cuma 1 - ngga pake prime pillar dan only one model 60mm/s infill 15-20%.
October 01, 2015 01:45AM
Tantangan ini memaksimalkan setting Slic3R ... utamanya di speed dan retract, karena bowden emang penyakitnya disitu.
Tambah paham setingan2 di slicer melalui trial and error.
October 17, 2015 01:17PM
Menarik.
Gagal 2x gara2 copot dari bed mid-print. Bro2 di sini buat PLA pakai alas apa sih?
Modal printer aurora, setelah kalibrasi kian lamanya, ternyata ada wobble-nya lumayan keliatan di sini baru sadar hahahaha
Settingan sayah :
Slic3r, speed (orang2 kalo nyebut speed tuh speed apanya sih yg dimaksud?) print 80mm/s travel 150mm/s; tapi cooling max 5s perlayer, jadi gatau deh jadi slowed down sampe berapa haha.
Kayaknya thread ini perlu digarap dan sering di-update dengan challenge2 oke deh, biar kita2 pada tau challenge apa menantang di bagian settingan mana dan bisa saling share hasil masing2 dengan yg lain supaya tau di mana yg harus dikalibrasi lagi.
October 18, 2015 01:26AM
Ayo sekarang yang ini - Detail test.... Super gampang....
Punya saya Pic nya hilang lagi - besok saya print lagi warna terang biar keliatan...
Herman IP3D
open | download - 08 Detail_Test.stl (81.2 KB)
November 23, 2015 04:56AM
pak ada yang bisa servis printer 3d lulzbot?
