Jual 3D Filament ABS/PLA/HIPS/PVA/FLX/PETG/CCU/CCT/WOOD/BRONZE/CLEANING +6285777088533
Posted by Aneka3D
October 01, 2015 04:41AM
READY STOCK - OKTOBER 2015 - Semua jenis 3D Filament tersedia.
3D Printer Filament 1.75 mm : ABS, PLA, HIPS, PVA, Flexible, PETG, Color Change By UV, Color Change By Temp, Wood, Bronze & Cleaning Filament.
Dapat digunakan pada Printer 3D : MakerBot, Mbot, Come3D, Afinia, Reprap, Up!, Makible, Printrbot, Prusa Mendel, Sumpod Delta, Mixshop, Solidoodle, RigidBot, Robo 3D, Eventorbot, RapidBot, 3D Kits, RepRapPro, Willybot, Tantillus, Airwolf, Hyrel 3D, Type A Machines, Weistek Dll / Compatible Mesin Printer 3D dengan System Fused Deposition Modeling (FDM) mengunakan filament plastik ABS, PLA, HIPS, PVA, Flexible, PETG, Color Change By UV, Color Change By Temp, Wood, Bronze & Cleaning Filament. dia 1,75 mm.
Hub : Egan - SMS Only : 085 777 088 533 atau Tel : (021)6290433 - 6394908
01. ABS 3D Filament
Terbuat dari ABS (Acrylonitrile Butadiene Styrene) Virgin Pellet Plastic + Colorant Pigment Additive
Diameter Filament : 1,75 mm
Net Weight : 1 Kg (berat isi filament diluar berat spool)
Vacuum Plastic Pack + Box Karton
Print Temperature : 220°C - 260 °C
Harga ABS 3D Filament : @ Rp. 320.000,- / Kg (Spool)
Khusus Warna Luminous Color (Glow In The Dark) : @ Rp.425.000,- / Kg (Spool)
Warna yang tersedia :
Black (Out of Stock), Light Blue, Green, Grey, Luminous green, Luminous blue, Natural, Pink, Red, Silver, Gold, Purple, Blue, Peak Green, White, Yellow, Brown, Pine Green, Magenta, Skin.
Black - tersedia kembali akhir October 2015
02. PLA 3D Filament
Terbuat dari PLA (Polylactide) Virgin Pellet Plastic + Colorant Pigment Additive
Print Temperature : 190°C - 220 °C
Harga PLA 3D Filament : @ Rp. 370.000,- / Kg (Spool)
Khusus Warna Luminous (Glow In The Dark) : @ Rp.450.000,- / Kg (Spool)
Black (Out of Stock), Light Blue, Green, Grey, Luminous green, Luminous blue, Natural, Orange, Pink, Red, Silver, Gold, Purple, Blue, Peak Green, White, Yellow, Brown, Pine Green, Magenta, Skin.
03. HIPS 3D Filament
HIPS adalah singkatan High Impact Polystyrene dan sangat mirip dengan ABS. Perbedaan utama adalah bahwa HIPS dapat larut dalam larutan Limonene. Ini berarti bahwa Anda dapat menggunakan HIPS selain sebagai produk print akhir, dapat juga untuk mencetak object 3D yang komplek dengan kombinasi 3D filament lain, dimana HIPS sebagai bahan pendukung/support yang kemudian dapat dengan mudah dihilangkan dengan menempatkan hasil 3D Print Anda di Larutan D-Limonene Oil. Ini adalah alternatif yang fantastis untuk pembersihan bahan pendukung/support. Yang biasanya dapat membuat tangan Anda sakit dan membuat Anda merasa frustrasi.
Harga HIPS 3D Filament : @ Rp. 350.000,- / Kg (Spool)
Sementara ini hanya tersedia Warna : Putih, Hitam dan Natural saja.
04. PVA 3D Filament
PVA (Polyvinyl Alkohol) filament adalah 3D filament printer yang larut dalam air. Fitur ini membuat filamen PVA kami sangat cocok sebagai bahan pendukung/support untuk 3D Print PLA yang kompleks.
Net Weight : 0,5 Kg (berat isi filament diluar berat spool)
Harga PVA 3D Filament : @ Rp. 640.000,- / (Spool)
Sementara ini hanya tersedia Warna : Natural saja.
05. Flexible PLA 3D Filament
Tidak berbahaya / beracun dan merupakan 3D Filament yang menghasilkan 3D Print yang Flexible dan Elastis.
Terbuat dari PLA (Polylactide) Virgin Pellet Plastic + Flexible Additive
Harga Flexible PLA 3D Filament : @ Rp. 600.000,- / Kg (Spool)
Warna yang tersedia : Natural
06. PETG 3D Filament
PETG filament (Glycol-modified PET; Co polyesters) adalah senyawa plastik yang satu famili dengan PET (Polyethylene terephthalate). Memiliki pengabungan keungulan dari senyawa plastik ABS dan PLA, serta memiliki warna yang bening/transparent dan kilap.
Print Temperature : 230°C - 250 °C
Harga PETG 3D Filament : @ Rp. 475.000,- / Kg (Spool)
Sementara ini hanya tersedia Warna : Natural (Transparent) saja.
07. Color Change By UV 3D Filament
Color Change By UV filament adalah 3D printer filament yang akan berubah warnanya bila terkena Sinar UV atau Sinar Matahari.
Harga Color Change By UV 3D Filament : @ Rp. 475.000,- / (Spool)
Warna yang tersedia : Natural-White to Purple, Natural-White to Red Pinkies.
08. Color Change By Temperature 3D Filament
Color Change By Temp filament adalah 3D printer filament yang akan berubah warnanya bila terpapar / kontak dengan Panas (Misal : dicelup air panas)
Harga Color Change By Temperature 3D Filament : @ Rp. 475.000,- / (Spool)
Warna yang tersedia : Natural-White to Blue, Natural-White to Grey.
09. Wood 3D Filament
Wood filament adalah 3D printer filament yang memiliki kareteristik warna & hasil seperti kayu.
Harga Wood 3D Filament : @ Rp. 475.000,- / (Spool)
Warna yang tersedia : Wood.
10. Bronze 3D Filament
Bronze filament adalah 3D printer filament yang memiliki kareteristik warna & hasil mirip Bronze.
Print Temperature : 180°C - 210 °C
Harga Bronze 3D Filament : @ Rp. 475.000,- / (Spool)
Warna yang tersedia : Bronze.
11. Cleaning 3D Filament
Cleaning filament adalah 3D printer filament yang memiliki fungsi sebagai pembersih Nozzle 3D Printer anda. Sangat disarankan, untuk digunakan antar pengantian Type / Warna Filament.
Net Weight : 0,1 Kg
Plastic Pack
Print Temperature : 160°C - 280 °C
Harga Cleaning 3D Filament : @ Rp. 175.000,- / (Spool)
Harga diluar Ongkos Kirim dan PPN 10%
Minimum Pembelian : 1 (satu) Kg / Spool / Warna
Stock Barang / 3D Filament pada umumnya selalu tersedia di Aneka, Karena banyaknya Jenis dan Warna dari 3D Filament ini, untuk kepastian stock dari jenis yang dibutuhkan mohon hubungi kami.
Mohon perhatikan ukuran spesifikasi spool filament yang tersedia diatas, adalah kompatibel untuk Printer Makerbot, untuk kompatibalitas dengan spool holder 3D printer lainnya. (Bila Uk lubang Spool tidak cocok, umumnya pembeli membuat/memodifikasi holder spoolnya sendiri)
Tampilan warna filament diatas sebagai gambaran akan warna filament yang akan didapatkan, warna sesungguhnya mungkin bisa sedikit berbeda dari pada tampilan warna di monitor pembeli. Foto 3D filament diatas adalah foto sesungguhnya dari foto 3D filament yang kami jual.
Untuk memesan : (Bahan : ABS, PLA, HIPS, PVA, Flexible, PETG, Color Change By UV, Color Change By Temp, Wood, Bronze, Cleaning Filament - Warna Qty Kg - Alamat)
Iroh / Egan
PT Aneka Indonesia
Jl. Lautze No. 9
Jakarta 10740
INDONESIA
Tel : +6221-6394908, 6290433, 6251748, 6252460
Fax : +6221-6295023
SMS Only : +6285777088533
Email : anekaid@gmail.com ; anekaid@yahoo.com
Jam Kerja :
Senin - Jum'at : 09:00 - 16:30
Sabtu : 09:00 - 13:00
Minggu - Hari Raya : Libur, Kantor tidak buka.
FAQ :
Bagaimana Kualitas dari 3D Filament ini :
3D Filament di import dari Pabrikan 3D Filament terbesar dan tertua di China : Shenzhen Esun Industrial Co.,Ltd yang telah berhasil memenangkan Blue Ribbon Award yang prestigious untuk kategori 3D Filament pada 18-19 Mei 2013 Bay Area Maker Faire Events yang diadakan di San Mateo County Center USA salah satu pameran Hobby DIY terbesar dengan pengunjung 120,000 orang.
ESUN adalah yang Merek 3D Filament terbaik di Cina dengan standar kualitas yang sangat tinggi. ESUN telah memenangkan 2014 China 3D Printing Filament First-Choice Brand. Telah di ekspor ke banyak negara termasuk Amerika dan Eropa.
Prosedur Pemesanan/ Pembelian 3D Filament :
Telepon/ SMS/ email, untuk cek stok ketersediaan : (Type Filament - Warna - Jumlah Roll/Spool) + Alamat Pemesan (agar bisa dihitung biaya Ongkos Kirimnya), bisa juga diambil sendiri - bayar ditempat.
Setelah itu, akan mendapat balasan konfirmasi dari kami dan informasi No. Rek Bank kami untuk dilakukan pembayaran, setelah pembayaran kami terima, barang akan kami kirim ke Pemesan melalui Ekspedisi JNE dalam 1-2 hari kerja dari tempat kami. Bukti No Resi Pengiriman, akan kami informasikan kepada pemesan.
Larutan Limonene, dimana belinya ?
Bisa beli di Toko Kimia : Minyak Atsiri Kulit Jeruk / Limonen Oil
D-Limonene Oil, bisa juga beli di Aneka3D :
- a. Kemasan Botol isi : 100 ml @ Rp. 100.000,- / Botol
- b. Kemasan Botol isi : 250 ml @ Rp. 200.000,- / Botol
- c. Kemasan Botol isi : 500 ml @ Rp. 350.000,- / Botol
- d. Kemasan Botol isi : 1.000 ml @ Rp. 600.000,- / Botol
Harga diatas diluar Ongkir dan PPN 10%.
D-Limonene Oil adalah bukan produksi Esun.
Bagaimana cara kerja Cleaning Filament ?
Cleaning Filament ini mempunyai range temp. extrude yang paling lebar yaitu 160 - 280 °C. Sehingga mempunyai kemampuan untuk mengikat dan mendorong sisa/residu filament sebelumnya yang ada didalam nozzle filament extruder. Buat yang suka eksperimen dengan bermacam filament / warna - dimana filament-filament tersebut mempunyai range temp. yang berbeda. Cleaning filament ini sangat disarankan, karena setiap jenis filament umumnya memiliki lebar selisih temp. extrudenya hanya 20-30 °C saja.
Contoh : Setelah cetak dengan PETG filament (230°C - 250 °C), setelah unload lalu ganti/load dengan filament PLA (190°C - 220 °C), perbedaan temperatur extrude dari kedua jenis filament ini akan menyebabkan Nozzle Extruder macet sewaktu akan mencetak bahan PLA pada range temp 190°C - 220 °C, karena sisa/bekas filament dari PETG yang tersisa pada nozzle, yang mempunyai range temp 230°C - 250 °C tidak bisa keluar/extrude, waktu 3D printer dijalankan pada temp. PLA. Demikian juga dalam kondisi sebaliknya, habis jalankan PLA lalu PETG, yang terjadi adalah sisa/bekas PLA filament yang tersisa pada nozzle akan hangus dan menyebabkan nozzle macet juga. Cleaning Filament memiliki warna natural (tidak mengandung pewarna/color pigment), jadi bagus untuk membersihkan residu pigment/pewarna filament atau sisa residu filament yang hangus yang tertinggal di nozzle extruder. Terutama untuk sisa/bekas PLA filament pada nozzle yang tidak bisa kita bersihkan / larut dalam cairan acetone.
Cara pakainya : Sama seperti filament yang lain, umumnya dipakai diantara jeda setiap print object, pemakaian rata-rata sekitar 10 - 25 cm panjang cleaning filament.
Bagaimana kompatibilitas dari 3D Printer Filamen ini ?
Semua filament kami dapat dipergunakan pada semua merk FDM Printer.
Dengan Catatan :
- Selama tidak ada penguncian di setting output temperatur extruder oleh pabrikannya, (Mis. Up 3D Printer)
- Tidak adanya pengunaan Chip Protection untuk Filament Consumablenya. (Mis. : XYZ Davinci, Cube3D Printer)
- Mengunakan ukuran filament dengan diameter 1.75 mm.
- Extruder Head mampu extrude filamen pada range temperature yang dibutuhkan.
3D Printer saya termasuk yang mempunyai proteksi diatas, apa tetap bisa mengunakan 3D Filament ini ?
Banyak pelanggan kami, yang mempunyai 3D printer dengan proteksi diatas, Mereka banyak membeli filament dari kami dan sangat kreatif, dengan berusaha mencari solusi crack atas proteksi tersebut diatas. (Kalau berkenan, Search di Google, untuk solusi unproteksi hal diatas)
Note. : Segala solusi unproteksi diatas adalah tanggung jawab para pemakai/pelanggan sendiri.
Perbedaan Pengunaan Support Filamen PVA atau HIPS ?
Filamen PVA dan HIPS memiliki temperature extrude yang berbeda.
PVA pada temp 190°C - 220 °C, sedangkan HIPS temp 220°C - 260 °C
Pilihlah filamen support yang memiliki range temperatur yang sama dengan filamen yang akan dipergunakan sebagai struktur / hasil.
Misal :
Filamen PLA dengan support Filamen PVA atau
Filamen ABS dengan support Filamen HIPS
Saya mau lihat langsung barangnya dan ambil sendiri, dimana Lokasi / Peta Aneka3D - PT Aneka Indonesia :
Jl. Lautze No. 9 Jakarta Pusat. Tel : (021) 6394908
(Ruko ke: 5&6 dari perempatan Jl. Lautze - Karang Anyar - Krekot Bunder)
[fjb.kaskus.co.id]
Edited 19 time(s). Last edit at 10/05/2015 01:56AM by VDX.
PERHATIAN!!!!!!
ANEKA INDONESIA BUKAN CHANNEL dari IP3D
TETAPI MENJUAL PRODUK TAK BERMERK BLANK dan MENCLAIM PRODUK ASLI DARI PABRIKAN ESUN...
IP3D ADALAH THE ONLY SOLE DISTRIBUTOR DI INDONESIA
HARAP DIBACA JELAS-JELAS
[forums.reprap.org]
KEPADA PIHAK ANEKA INDONESIA
" ANDA TIDAK SEHARUSNYA MEMBOHONGI - DAN MENIPU KONSUMEN terutama DI REPRAP GROUP INDONEISA dengan MENCLAIM BARANG eSUN (OEM - dari pabrikan) - MOHON DIBUKTIKAN BAHWA BARANG ANDA ASLI eSUN - CHINA - dan KAMI REPRAPERS REQUEST SURAT DARI SOURCE SUPPLIER ANDA RESMI.
ESUN CHINA LENGKAP DENGAN BOX dan LOGO bahkan SPOOL eSUN TRANSPARANT BARU - VACUUM TIGHT PACKAGING.
ANDA TIDAK ADA KONTRIBUSI di REPRAP SAMA SEKALI dan MAU MENCOBA MENIPU ANGGOTA GROUP.
MOHON DICAM-KAN BAIK - BAIK - dan Pihak IP3D bisa meneruskan ke kasus (PENIPUAN) apabila anda terus menclaim menjual PRODUK eSUN padahal menjual PRODUK BLANK no MERK.
DAN IP3D tidak cuma melayani 1.75mm saja - FULL 1.75mm dan 3.0mm.
KEPARA PARA REPRAPERS - MOHON TIDAK TERPROVOKASI OLEH IKLAN YANG TIDAK JELAS.... HARAP WISE dan PEMBELI....
PARA SENIOR REPRAPER INDONESIA sudah TAHU Produk ASLI dari eSUN.
Dan bisa dilihat di WEBSITE RESMI eSUN - [www.esun3d.net]
Untuk REPRAPERS INDONESIA- eSUN ASLI Bisa di peroleh dari BRO ZUNGMAN, BRO Dazriel, BRO RYAN WIDI, dan BRO ARIA.
APABILA ADA INFO YANG DIINGINKAN LEBIH LANJUT bisa menghubungi saya di 031-5023679 (Jam Kantor) untuk Klarifikasi.
eSUN adalah BRAND INTERNASIONAL dan SUDAH Terkenal Dimana mana. Jadi Jangan membeli dari SUMBER yang Tidak Jelas apalagi harga murah dan kualitas rendah... sehingga merusak Brand Original eSUN.
TERIMA KASIH
PT. INDOPRIN TIGA DEMENSI (IP3D)
SURABAYA - INDONESIA
Herman - IP3D
Edited 4 time(s). Last edit at 10/02/2015 10:09PM by IP3D.
Pihak Aneka Indonesia berdiri sejak 1980 adalah Perusahaan Terbatas - Legal dan memiliki alamat dan kantor yang jelas,
dan pihak kami jauh lebih lama menjual 3D Filamen Esun dari pada IP3D (bisa dilihat dari Link Posting Kami di FJB Kaskus
Kami memberikan GARANSI 100% - Uang Kembali bila Filament yang kami jual bukan dari Shenzhen Esun Industrial Co. Ltd.
Para Reprap dan para 3D printer user akan bisa menilai sendiri dan akan tahu siapa yang benar dan bohong.
Untuk itu kami minta Pihak IP3D untuk mencabut komentar diatas secepatnya. Kami persilahkan IP3D untuk menghubungi Pihak Esun,
bila meragukan keaslian Product yang kami jual. Serta kami persilahkan semua pihak untuk membuktikan ke aslian produk yang kami jual.
Untuk Info lebih lanjut akan keaslian Produk yang kami jual.
Bisa menghubungi kami
Agus Kuatsjah
PT Aneka Indonesia
Jl. Lautze No. 9
Jakarta 10740
INDONESIA
Tel : 6221- 6251748, 6252460, 6394908
Fax : 6221-6295023
[fjb.kaskus.co.id]
Agus Kuatsjah
PT Aneka Indonesia
Jl. Lautze No. 9
Jakarta 10740
INDONESIA
Fax : 6221-6295023
[fjb.kaskus.co.id]
Agus Kuatsjah
PT Aneka Indonesia
Jl. Lautze No. 9
Jakarta 10740
INDONESIA
Fax : 6221-6295023
[fjb.kaskus.co.id]
OK - AKAN SAYA PROSES dengan ESUN PUSAT dan Dr. KEVIN (CEO eSUN)
Herman Kristanto
Managing Director
PT INDOPRIN TIGA DEMENSI
Surabaya - INDONESIA
IP3D
Herman Kristanto
Managing Director
Kepada Bpk. Herman,
Itu baru bener pak. Fair. Jangan asal cuap saja.
Terima kasih.
OK - Now we are talking Professional .... We'll see and you only sell BLANK FILAMENT
Kaya kaki lima tanah abang smiling smiley - and your COMPANY is not even listed in eSUN OFFICIAL WEBSITE
BLANK MARKET - NGOTOT
OH IYA - SURAT LOE kalo ASLI eSUN MANA?????
JANGAN BILANG - OH OEM PAK..... PEDULI amat udah jualan (KASKUS) dah tahunan.
Regards
Herman Kristanto
Edited 1 time(s). Last edit at 10/01/2015 09:05AM by IP3D.
Saya juga pengguna favorite esun, memiliki harum yang khas, boleh saya buktikan?
"if you don't know how to build better you buy good printer first and try to learn from there" -- By Herman IP3D
REPRAP Prusa i3 Dasziel Rework ready to print 8.5jt, hasil print super smooth.
Support filament flexible rubber, wood 10jt
Profesional jasa printing or costumize 15jt<
[forums.reprap.org]
Printer 3d build up : Rapide lite 200 , 26jt.
Jasa rakit, servis, tuning, programming, untuk semua jenis printer 3d.
Khusus yang mau belajar rakit printer 3d tersedia part set lengkap dan tutorial (call for price).
Jual part printer 3d , printed kit, dll.
Menyediakan filament berkualitas untuk hasil print yang baik sebaiknya konsultasi dulu, harga >250rb/kg tergantung jenis.
Contact dan Whatsapp 082111703999
Office : cengkareng indah blok ic/1a, jakarta barat
Yth Pak Herman,
Kan tadi sudah jelas, We are talking Professional,
Prosesnya kan sudah jelas. Pihak kami pun bersedia di cek ke Aslian Produk yang kami jual.
Mohon jangan buat statement membabi buta seperti itu. Nanti malu sendiri.
Stok kami untuk Esun 3D Filament terlengkap dan tersedia dalam jumlah yang cukup serta Ready Stock
dan dijual dengan Harga yang Pantas.
Terima Kasih.
PT Aneka Indonesia
dasziel
Siap Bro Dasziel, bisa ketempat kami atau kami kirimkan ketempat Bro Dasziel.
Kl ketempat kami, bisa random pickup. Biar Mantaaap
Agar para Reprap dan 3D Printer users jelas.
Alamat kami :
PT Aneka Indonesia
Jl. Lautze No. 9
Jakarta 10740
Indonesia
Tel : 6221-6251748, 6252460, 6290433, 6394908
Fax : 6221-6295023
Mobile : Egan - 085 777 088 533
Intinya aja - NAMA COMPANY ANDA di Website eSUN ada ngga - Surat Distributor eSUN RESMI Ada Ngga, Penampakan Produk eSUN anda sudah sesuai standar eSUN Factory atau Belum.
Yang seharusnya malu siapa? IP3D tidak mungkin malu karena IP3D adalah "SOLE DISTRIBUTOR RESMI" (saya bantu terjemahkan DISTRIBUTOR TUNGGAL PEMEGANG MERK) harap CHECK LINK dibawah.... Tertera NAMA IP3D atau PT ANEKA INDONESIA???????
[www.esun3d.net]
Respons terakhir kami terhadap SEMUA Statement anda - Kontribusi anda buat REPRAPERS APA????? Selain NIAT BUAT Jualan Jualan Jualan dan Jualan......... JOIN BARU BULAN AGUSTUS dah KEPOH........drinking smiley
Aneka3D [ Send a PM ] [ Add Buddy ] [ Show all posts ]
Email:
Hidden
10
08/12/2015 07:17AM
Edited 2 time(s). Last edit at 10/01/2015 10:01AM by IP3D.
IP3D
Yang seharusnya malu siapa? IP3D tidak mungkin malu karena IP3D adalah "SOLE DISTRIBUTOR RESMI" harap CHECK LINK dibawah.... Tertera NAMA IP3D atau PT ANEKA INDONESIA???????
[www.esun3d.net]
Cape nih ngomong sama Orang yang enggak Professional dan Emosian seperti ini.
Kan Pihak Kami Aneka, Siap di Cek Ke Aslian dan Kualitas Filament Esun yang kami jual.
Kenapa kebakaran Jenggot kayak gini ya.
Ini Forum terhormat dan sopan Pak Herman
Email:
Hidden
10
08/12/2015 07:17AM
Check LINK
[www.esun3d.net]
IP3D
Check LINK
[www.esun3d.net]
Untuk Pembelian Esun 3D Printer Filamen
bisa hub : Ms. Iroh / Egan - 085 777 088 533
PT Aneka Indonesia
Jl. Lautze No. 9
Jakarta 10740
Indonesia
Fax : 6221-6295023
Check Link
[www.esun3d.net]
eSUN SOLE AUTHORIZED DISTRIBUTOR in INDONESIA
P.T. Indoprin Tiga Dimensi (IP3D)
Jl. Kalibokor Selatan Blok B-88, Surabaya 60284
INDONESIA
Our Partner for COMPANY that SELL eSUN BRAND:
Inovasi Tiga Dimensi
(Medan) [i3d.co.id]
SK3D
[sk3d.id]
Edited 1 time(s). Last edit at 10/01/2015 10:34AM by IP3D.
IP3D
Check Link
[www.esun3d.net]
INDONESIA
PT Aneka Indonesia
Jl. Lautze No. 9
Jakarta 10740
Indonesia
Fax : 6221-6295023
Jualan Jualan...... Yang PASTI PASTI AJA
Check Link
[www.esun3d.net]
INDONESIA
(Medan) [i3d.co.id]
SK3D
[sk3d.id]
Mau donk test filament nya. boleh kirim gak? btw tester ini free khan 1 roll smiling bouncing smiley kl boleh free ntar ogut PM in alamat nya.
IP3D
Stock Terlengkap - Ready Stock - Jakarta Indonesia
PT Aneka Indonesia
Jl. Lautze No. 9
Jakarta 10740
Indonesia
Fax : 6221-6295023
Check Link
[www.esun3d.net]
INDONESIA
(Medan) [i3d.co.id]
SK3D
[sk3d.id]
djunz.aza
Boleh Bro djunz.aza, Hub : Egan di : 085 777 088 533
Syaratnya : Harus buat Testi sejujur-jujurnya.
Setelah menerima Esun 3D Filamen dari kami dan dilakukan test,
Harus buat Testi / Laporan pada Forum Reprap Indonesia ini.
Tester akan diberikan Warna Natural - Bisa Pilih salah satu jenis : ABS / PLA
Ongkir di tanggung Tester, atau bisa diambil ke tempat kami. PT Aneka Indonesia
Edited 1 time(s). Last edit at 10/01/2015 11:00AM by Aneka3D.
Aneka3D
djunz.aza
wuah rame amat... c amat aja lg prepare maljum nih gan...
Hayoooo yang asli mana....
eSUN White ASLI (Putih Gypsum) from IP3D
dari warna aja semua tahu lhoooooo..... Barangnya siapa hayooooooo
eSUN atau ASUN........
Sampai kapanpun - FAKE is FAKE
Check Link
[www.esun3d.net]
INDONESIA
(Medan) [i3d.co.id]
SK3D
[sk3d.id]
IP3D
Check Link
[www.esun3d.net]
INDONESIA
(Medan) [i3d.co.id]
SK3D
[sk3d.id]
PT Aneka Indonesia
Jl. Lautze No. 9
Jakarta 10740
Indonesia
Fax : 6221-6295023
01. ABS 3D Filament
Black, Light Blue, Green, Grey, Luminous green, Luminous blue, Natural, Pink, Red, Silver, Gold, Purple, Blue, Peak Green, White, Yellow, Brown, Pine Green, Magenta, Skin.
02. PLA 3D Filament
Black, Light Blue, Green, Grey, Luminous green, Luminous blue, Natural, Orange, Pink, Red, Silver, Gold, Purple, Blue, Peak Green, White, Yellow, Brown, Pine Green, Magenta, Skin.
04. PVA 3D Filament
Net Weight : 0,1 Kg
Plastic Pack
Edited 1 time(s). Last edit at 10/01/2015 11:20AM by Aneka3D.
Dear All,
Di sini adalah forum RepRap yang ditujukan tuk berbagi ilmu, pengalaman, dan skill reprap dan 3d printing. Kami tidak anti dengan sale seputar 3d printing, jika itu membantu maka ok saja.
RepRaper dan setiap orang bebas memilih oleh karena itu layak dapat informasi yg betul dan jujur atas barang apapun yg ditawarkan.
Bro Aneka3D, jika memang filamen anda sesuai seperti yg anda klaim, maka tunjukkan saja buktinya. Karena melibatkan brand terkenal yg menjaga kualitas dan brand, maka harusnya anda sudah punya penunjukkan resmi. Tolong jangan buat polemik dan memberikan info yg salah terhadap para RepRaper.
Saya sendiri dan juga para RepRaper di sini banyak yang sudah lama menggunakan berbagai filamen branded dan juga filamen non-brand. Jadi kami cukup pengalaman dan bisa memnedakan mana yg bagus, biasa saja, atau tidak bagus sama sekali.
zungmann
Dear All,
Siap Bro Zungmann,
Saya setuju setiap orang bebas memilih oleh karena itu layak dapat informasi yg betul dan jujur atas barang apapun yg ditawarkan,
Perlu kami jelaskan sekali lagi :
Produk 3D Filament yang kami jual, adalah benar dan sebenarnya product dari Shenzhen Esun Industrial Co. Ltd.
Memang benar produk Esun, sudah kami impor beberapa kali di mulai dari Akhir Tahun 2012, dan kami memang minta khusus Non Brand Packaging.
Untuk Brand Esun, ada pada kemasan Karton Besar isi : 12 (dua belas) Spool.
Kenapa kami memilih import melalui Local buyer kami di China - karena Market Local China yang sangat kompetitif dalam harga,
Local China Buyer kami yang melakukan pembelian Direct ke Esun China dalam volume besar untuk mendapatkan bottom price mereka,
Dengan demikian kami harapkan para Reprap bisa mendapatkan Kualitas dan Harga yang Sesuai dan kompetitif.
Dengan demikian semakin banyak dan semakin terjangkau 3D Printing Technologi ini bagi Bangsa Indonesia.
Produk Esun 3D Filamen ini sdh kami jual sejak awal Tahun 2013. Dengan begitu banyak kendala diawalnya, dan sekarang semakin baik dan dapat dibandingkan dengan
produk serupa dari US, EU maupun AU.
Perusahaan kami pun, dalam pernyataan pada Reprap ini, Siap di cek keaslian dan kualitas produknya 3D Filamen ini adalah benar dari Esun.
dan tidak pernah menyatakan diri sebagai Sole Distributor u/ Indonesia.
Hanya sayangnya salah satu perusahaan 3d printing supply, melakukan perbuatan dan tindakan tidak terpuji terhadap perusahaan kami ini. dengan pernyataan-pernyataaan yang menyesatkan.
Terima Kasih Bro Zungmann. Salam 3D Indonesia dari kami.
JANGAN NGE CLAIM BARANG eSUN kalo NGGA PUNYA BUKTI - SELESAI
INI MASALAH BRAND NOT PRODUCT - SILAHKAN MAU JUAL JADI ASUN kek - ASU kek
You are Playing with BRAND NAME. UNDESTAND!!!!......... WE'LL SEE......
Herman Kristanto
IP3D
Herman Kristanto
Kepada Yth,
Bro - Bro RepRap dan Moderator yang terhormat.
Untuk menegur Pak Herman.
Buat pihak kami, dari sejak kami berdiri Tahun 1980 dengan Nama Aneka Supplier dan sekarang menjadi PT Aneka Indonesia
Sudah merupakan Prinsip Utama, kami menjual dengan informasi yg benar dan jujur atas barang apapun yg kami tawarkan,
Para Bro-Bro, bisa melihat Informasi Sale kami. Kami memberikan Deskripsi yang jelas atas Setiap Filamen yang kami jual.
- Asal Usul Pabrikan dari Filamen yang kami jual.
- Deskripsi Bahan 3D Filamen
- Packaging - Berat - Stock dan Harga yang Update
- Alamat dan Kontak yang jelas - dalam transaksi.
Pihak kami, sudah menegaskan berkali-kali, untuk tidak membuat pernyataan yang menyesatkan.
Sebelum pihak kami melaporkan ke Pihak yang Berwajib atas pernyataan - pernyataan Fitnah
yang menyatakan Barang kami Palsu - bukan dari Esun - Shenzhen Esun Industrial Co. Ltd.
Pihak kami pun sudah menyatakan siap di cek untuk ke- Aslian dan Origin dari produk 3D filamen yang kami jual.
Pihak Aneka pun, sudah jauh lebih lama jual Produk 3D filamen dari Esun ini, sebelum Pihak Pak Herman jual produk dari Esun.
Dan bukan pada tempatnya untuk Pihak Pak Herman, menjudge atas Kualitas dan Ke Aslian dari Produk yang kami Jual.
Biarlah para Pembeli dan Pemakai yang punya Hak untuk menjudge atas Kualitas, Pelayanan dan Support atas Barang yang kami jual
Semoga Informasi ini, bisa memberikan kejelasan pada forum ini.
Salam 3D Indonesia
Agus Kuatsjah
PT Aneka Indonesia
Edited 1 time(s). Last edit at 10/01/2015 07:30PM by Aneka3D.
Brand punya pengaruh yg kuat dan ada alasan orang menggunakan branded stuff.
Bro Aneka3D sudah mengatakan memilih non-brand packaging, dan tentu ada alasan di balik itu. Saya pikir dan fair jika Aneka3D konsisten dan menghormati pilihannya sendiri: non-branded, walaupun productnya dihasilkan oleh company esun tsb. Tentu aja Anda bisa mengatakan filamen tsb diproduksi oleh perusahaan yg menghasilkan brand esun. Soal kualitas, nanti para ReRaper atau para pengguna yg menilai. Mungkin filamen Aneka3D lebih baik atau mungkin tidak.
Di luar itu, terkait dispute product, brand dsb. silakan diselesaikan secara baik.
Wah, wah.. Gimana ya soal jualan..
Mungkin w ga banyak ribut dsni, tapi ya klo bgnian jangan bawa sensi gtu..
Klo emng dia punya palsu ya mo gmna juga ini sebenarnya forum belajar..
Saya sendiri udh coba filament dari yang merek dan ga merek, ya klo jelek langsung ga beli lagi aja.. "Blacklist seller".. Kelar..
Toh klo emng sudah biasa print nanti juga tau perlu beli laginya kemana..
Soal spool sama keaslian sih klo ga ditunjukin, ga tau ya...
Kan dia blom posting foto spool dia sama sekali, kenapa tau" dibandingin gtu...
Nanti pas mrk mau ambil ya liat aja gmna feedbacknya... Mana tau memang spool dri lokal begtu..spinning smiley sticking its tongue out
Secara emng bikin plastik yang warna item lebih ekonomis dari pada yg transparant, soalnya bisa udh bekas recycle klo yg item...
Ya nyatanya ada aja yg jual spoolny item kyk di amazon (pake bren esun juga tuh): amazon
Pihak Aneka3D juga ga ada gunanya bilang sudah lebih lama atau gmna,
Toh banyak juga prusahaan tua yang udh mau gugur jadi pakai jalan belakang... grinning smiley
Ini lebih baik tingkatkan kewaspadaan buyer sih..
