Merakit printer reprap/restrap delta jenis karya3D January 10, 2016 09:57PM |
Re: Merakit printer reprap/restrap delta jenis karya3D January 11, 2016 09:59PM |
Re: Merakit printer reprap/restrap delta jenis karya3D January 13, 2016 12:55AM |
Re: Merakit printer reprap/restrap delta jenis karya3D January 13, 2016 01:06AM |
Re: Merakit printer reprap/restrap delta jenis karya3D January 14, 2016 03:09AM |
Re: Merakit printer reprap/restrap delta jenis karya3D January 17, 2016 04:21AM |
Re: Merakit printer reprap/restrap delta jenis karya3D January 30, 2016 05:06AM |
Re: Merakit printer reprap/restrap delta jenis karya3D January 30, 2016 10:43AM |
Re: Merakit printer reprap/restrap delta jenis karya3D January 30, 2016 11:48AM |
Re: Merakit printer reprap/restrap delta jenis karya3D January 31, 2016 07:45AM |
Re: Merakit printer reprap/restrap delta jenis karya3D January 31, 2016 06:48PM |
Re: Merakit printer reprap/restrap delta jenis karya3D January 31, 2016 11:45PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 01, 2016 05:17AM |
rollingdice
Sharing dikit pengalaman merakit racikan agan Ryan.
Paket datang awal Januari lalu. Ngerakitnya dilakukan secara bertahap karena nunggu alat-alat dan bahan tambahan dateng.
Yang saya beli antara lain:
- Palu plastik
- Jangka sorong 300mm
- Epoxy resin
- Bubble level
- Teflon tape / selotip paralon
Setelah ketok sana ketok sini, ada beberapa trik penting yang saya tangkap:
- Di langkah perakitan effector, jangan lupa potong bowden tube lalu masukkan di antara hotend dan pushfit. Sebenernya ada fotonya sih di atas, tapi berhubung ane nubi, jadi baru ketahuan pas ngeprint ada flex filamen di antara pushfit dan hotend karena gak pake bowden tube.
- Cara pasang balljoint ke carbon tube agak beda di versi saya. Masukin screw ke balljoint sampe mentok > balurin superglue ke bagian baut yang masuk ke carbon rod > masukin screw ke karbon rod > lepas balljoint > pasang teflon tape di ujung screw 8-12 putaran > pasang balljoint. Teflon tape di sini tujuannya agar balljoint bisa diatur sehingga panjang carbon rod bisa diseragamkan tanpa membuat si balljoint geser-geser saat printer operasional.
- Cek level platform bawah dan platform atas, apabila kemiringannya beda maka ketok si platform atas di sudut X, Y, atau Z sedemikian rupa sehingga kemiringannya sama.
- Saya pertama upload software pakai yang versi tanpa endstop. Tapi berhubung saya dikirimin microswitch 3 biji, dipake aja deh daripada nganggur. Alhasil bikin configuration.h sendiri di situsnya repetier, programnya juga donlod baru versi vanilla (tanpa modif no endstop). Lebih nyaman juga seandainya komputer ngehang / mati lampu bisa dihoming dari repetier tanpa angkat manual. Untuk pemasangan endstop sendiri perlu sedikit skill solder sama part-part elektronik.
- Selesai rakit, sayakonfirmasi steps/mm dari printer pake jangka sorong. Firmware dari agan Ryan sih udah disetting sebenernya, tapi nggak ada salahnya ngecek sekali lagi.
- Selain itu, perlu cek juga parameter lain kayak delta radius, endstop correction, dan tower angle correction karena yang namanya cacat manufaktur itu pasti ada. Saya pake ini nih. Pilih 6 factor dan 7 point, kalo mau lebih akurat mungkin bisa pake 10 point. Jangan lupa firmware typenya pilih Repetier. Kalo selesai tinggal dimasukin aja angkanya ke firmware EEPROM lewat Repetier Host.
- Test print pertama, coba ngeprint yang bulet-bulet. Perhatikan nozzlenya, kalo terlalu neken/terlalu ngambang, sesuaikan endstop correction di EEPROM.
- Jika layer pertama susah nempel, coba oleskan UHU glue stick di printbed.
Hasilnya lumayan bagus, walaupun ngeprint 20mm cube masih ada deviasi 0,4mm di sisi Y (entah itu yang nggak bener rodnya atau jangka sorongnya karena belinya bukan mitutoyo
Foto-foto menyusul, next up: flying extruder mod
Re: Merakit printer reprap/restrap delta jenis karya3D February 01, 2016 08:31PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 02, 2016 01:42AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 02, 2016 10:33AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 02, 2016 10:50AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 02, 2016 11:12AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 03, 2016 04:12AM |
ryannining
Ok, sekarang tahapnya adalah membuat effector. Untuk delta. effector ini yg penting adalah :
- posisi magnet presisi, caranya dengan memotong cetakan kertas MKEff dan tempel ke bahan flat dan potong
- bahan yg dipake flat dan harus kuat/tidak melengkung, tidak rusak karena panas
- saya memilih bahan mata gerinda 1mm dengan cekungan dan lubang ditengahnya (bebas si sebenernya)
- potong memakai mata gerinda jenis diamond
Untuk posisi nozzle, throat, heatsink, posisi kiri kanan tidak penting, yg penting kencang, dan posisi heatsink+fan nantinya tidak mengganggu lengan delta.
Untuk pengkabelan, ada baiknya kabel pemanas dan NTC diarahkan ke sudut ujung dari effector. karena kalo di posisi lebarnya nantinya mengurangi area cetak, dikarenakan, saat mencetak di sudut kabelnya kena tiang.
Untuk lengannya saya memotong carbon tube masing2 15cm, nantinya ditambah sekrup M4 dan bola joint, jadi sekitar 18cm, cukup untuk area cetak 14cm
Sebenernya tadi udah bikin video timelapse.... TAPI TERNYATA POSISI SAYA DUDUK UTAK UTIK SALAH , jadi cuma keliatan sedikit diujung. Terpaksa akhirnya foto2 biasa. Dan proses bikin drat pada heatsink, proses motong semua ilang.
[attachment 69612 CameraHDRStudio-1452661077126-1.jpg][attachment 69613 CameraHDRStudio-1452661091425-1.jpg][attachment 69614 CameraHDRStudio-1452661753282-1.jpg][attachment 69615 CameraHDRStudio-1452661772950-1.jpg][attachment 69616 CameraHDRStudio-1452661828105-1.jpg][attachment 69617 CameraHDRStudio-1452662081348-1.jpg][attachment 69618 CameraHDRStudio-1452662086220-1.jpg][attachment 69619 CameraHDRStudio-1452663087579-1.jpg]
Video timelapse semi gagal ini.
[youtu.be]
Re: Merakit printer reprap/restrap delta jenis karya3D February 03, 2016 06:14AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 03, 2016 10:12PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 04, 2016 10:55AM |
ryannining
Kertasnya kan ga dikletek abis dipasang.
Untuk effector itu cara paling bagus. namun untuk carriage, emmang ribet. makanya saya sebut repstrap, tapi, model part baru, effectornya ga perlu pake cara tsb. karena dijamin pas. ya geser2 karena bor di kayunya paling 1 mili kurang.
Efek dari tidak presisinya lokasi joint (magnet ataupun lainnya) adalah posisinya tidak pas, jadi geometri hasil cetak tidak sempurna. Misal lingkaran jadinya aga penyok.
Namun hal ini memang ciri printer reprap, harus presisi/simetri makanya saat buat. Ya semaksimal mungkin. Ga bisa lah ngejar perfek 100% presisi la part2nya aja linear motion pake sederhana.
Namun untuk kebutuhan basic saya print casing produk, print part printer, ya cukup.
Re: Merakit printer reprap/restrap delta jenis karya3D February 05, 2016 11:47AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 07, 2016 10:46AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 07, 2016 11:04AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 07, 2016 12:55PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 07, 2016 07:29PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 08, 2016 04:53AM |
ryannining
Untuk BELT pemasangannya adalah dilipat kemudian dimasukkan ke sela
Mengatur kekencangannya tentunya dengan mengatur posisi melipatnya sebelum dimasukkan ke plastik carriage
Perhatikan bahwa belt saat melewati idler bearing di bawah adalah bagian halusnya, bukan geriginya. Jadi sisi kanannya beltnya diputar. Hal ini ga ada masalah sama sekali pada hasil. Dan jadi lebih ringkas desain penguncian belt dan desain idler bawahnya bisa pake bearing kecil.
Yang paling penting, karena ini memakai bushing, maka posisi belt yg melewati carriage/pengunci belt idler dan motor harus bener2 lurus, berada di tengah2 tiang. Ini supaya kerja bushing rata tidak berat sebelah. Ya meskipun meleset2 dikit saya rasa ga masalah si.
Plastik cetak dudukan idlernya kalo saya pake LEM, motornya bebas ukurannya jadi saya pake cable ties untuk mengikat motor ke body printer.
Re: Merakit printer reprap/restrap delta jenis karya3D February 08, 2016 08:34AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 08, 2016 02:12PM |
