Re: Merakit printer reprap/restrap delta jenis karya3D February 16, 2016 11:28AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 17, 2016 03:51AM |
ryannining
Maksud saya bukan kertas rokok, tapi itu lo aluminium foil yg di toko masak, sorry.
Btw printed bushing, bushing kipas angin, printed bushing dengan selang teflon, sudah saya coba berbagai gaya. susah.... tidak licin seperti bimetal bushing.
Bimetal sendiri dalemannya konon ada teflonnya.
Re: Merakit printer reprap/restrap delta jenis karya3D February 17, 2016 05:21AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 17, 2016 08:34AM |
Hoo beda ya? Sorry ganQuote
ryannining
Mungkin bukan backlash maksudnya gan, tapi play/main. Itu karena asnya ga pas 6mm tapi 5.8mm, iya dipanjangin jarak 2 busing bisa.
[attachment 72728 Capture1.PNG]
Jadi dimasukkan baru disekrup. Sebelum disekrup kan itu lubang masih bisa fleksibel karena bentuknya.
Re: Merakit printer reprap/restrap delta jenis karya3D February 17, 2016 09:36AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 17, 2016 08:15PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 18, 2016 07:22AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 20, 2016 10:03PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 20, 2016 11:20PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 22, 2016 09:05AM |
rollingdice
ryannining
Oke deh sekarang ane coba panjangin dulu si file .stl nya, semoga sih bisa berkurang play-nya jadi minimal setengahnya, hehehe.
Re: Merakit printer reprap/restrap delta jenis karya3D February 22, 2016 05:29PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 22, 2016 10:58PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 22, 2016 11:52PM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 25, 2016 02:21AM |
Re: Merakit printer reprap/restrap delta jenis karya3D February 25, 2016 02:42AM |
Re: Merakit printer reprap/restrap delta jenis karya3D March 02, 2016 05:04PM |
rollingdice
Sharing dikit pengalaman merakit racikan agan Ryan.
Paket datang awal Januari lalu. Ngerakitnya dilakukan secara bertahap karena nunggu alat-alat dan bahan tambahan dateng.
Yang saya beli antara lain:
- Palu plastik
- Jangka sorong 300mm
- Epoxy resin
- Bubble level
- Teflon tape / selotip paralon
Setelah ketok sana ketok sini, ada beberapa trik penting yang saya tangkap:
- Di langkah perakitan effector, jangan lupa potong bowden tube lalu masukkan di antara hotend dan pushfit. Sebenernya ada fotonya sih di atas, tapi berhubung ane nubi, jadi baru ketahuan pas ngeprint ada flex filamen di antara pushfit dan hotend karena gak pake bowden tube.
- Cara pasang balljoint ke carbon tube agak beda di versi saya. Masukin screw ke balljoint sampe mentok > balurin superglue ke bagian baut yang masuk ke carbon rod > masukin screw ke karbon rod > lepas balljoint > pasang teflon tape di ujung screw 8-12 putaran > pasang balljoint. Teflon tape di sini tujuannya agar balljoint bisa diatur sehingga panjang carbon rod bisa diseragamkan tanpa membuat si balljoint geser-geser saat printer operasional.
- Cek level platform bawah dan platform atas, apabila kemiringannya beda maka ketok si platform atas di sudut X, Y, atau Z sedemikian rupa sehingga kemiringannya sama.
- Saya pertama upload software pakai yang versi tanpa endstop. Tapi berhubung saya dikirimin microswitch 3 biji, dipake aja deh daripada nganggur. Alhasil bikin configuration.h sendiri di situsnya repetier, programnya juga donlod baru versi vanilla (tanpa modif no endstop). Lebih nyaman juga seandainya komputer ngehang / mati lampu bisa dihoming dari repetier tanpa angkat manual. Untuk pemasangan endstop sendiri perlu sedikit skill solder sama part-part elektronik.
- Selesai rakit, sayakonfirmasi steps/mm dari printer pake jangka sorong. Firmware dari agan Ryan sih udah disetting sebenernya, tapi nggak ada salahnya ngecek sekali lagi.
- Selain itu, perlu cek juga parameter lain kayak delta radius, endstop correction, dan tower angle correction karena yang namanya cacat manufaktur itu pasti ada. Saya pake ini nih. Pilih 6 factor dan 7 point, kalo mau lebih akurat mungkin bisa pake 10 point. Jangan lupa firmware typenya pilih Repetier. Kalo selesai tinggal dimasukin aja angkanya ke firmware EEPROM lewat Repetier Host.
- Test print pertama, coba ngeprint yang bulet-bulet. Perhatikan nozzlenya, kalo terlalu neken/terlalu ngambang, sesuaikan endstop correction di EEPROM.
- Jika layer pertama susah nempel, coba oleskan UHU glue stick di printbed.
Hasilnya lumayan bagus, walaupun ngeprint 20mm cube masih ada deviasi 0,4mm di sisi Y (entah itu yang nggak bener rodnya atau jangka sorongnya karena belinya bukan mitutoyo
Foto-foto menyusul, next up: flying extruder mod
Re: Merakit printer reprap/restrap delta jenis karya3D March 02, 2016 08:31PM |
Re: Merakit printer reprap/restrap delta jenis karya3D March 26, 2016 12:45AM |
Re: Merakit printer reprap/restrap delta jenis karya3D March 27, 2016 10:27PM |
Re: Merakit printer reprap/restrap delta jenis karya3D March 28, 2016 02:00AM |
Re: Merakit printer reprap/restrap delta jenis karya3D March 28, 2016 09:34PM |
Re: Merakit printer reprap/restrap delta jenis karya3D March 29, 2016 10:04AM |
Re: Merakit printer reprap/restrap delta jenis karya3D March 29, 2016 09:45PM |
Re: Merakit printer reprap/restrap delta jenis karya3D March 30, 2016 04:59AM |
Re: Merakit printer reprap/restrap delta jenis karya3D March 30, 2016 12:16PM |
Re: Merakit printer reprap/restrap delta jenis karya3D April 01, 2016 10:04AM |
Re: Merakit printer reprap/restrap delta jenis karya3D April 06, 2016 09:09AM |
Re: Merakit printer reprap/restrap delta jenis karya3D April 07, 2016 10:50PM |
Re: Merakit printer reprap/restrap delta jenis karya3D July 01, 2016 12:16PM |
Re: Merakit printer reprap/restrap delta jenis karya3D August 13, 2016 12:33PM |
