Hello and onto a problem...
Posted by ijmok
April 20, 2011 07:29PM
Hi, Thought id introduce my self
Im Rob, im 21 and just beginning my build.
So far i think i have about 85% of the hardware required to build a Mendel Prusa.
Im a way of finishing that but i thought i would begin sourcing the other major components.
I work as a Engineer so the mechanical build and any machining required i can do easily.
What im less sure of is the electronics.
I think im set on buying a pre -assembled Gen 3 or 6 board, (suggestions please!)
Ramps appears less obvious to me.
So the question is which one, and where from.
Rob
Re: Hello and onto a problem...
April 21, 2011 04:13AM
Welcome smiling smiley
I have G3 running, but that is old stuff. If I was to do this again I would build the pololu solution designed by Adrian. Simply because it seems relatively diy.
For the rest I cannot help you. Perhaps you should ask on the main boards as this is a problem not specific to the UK but to all.
good luck with your build. You will have fun and learn loads smiling smiley
