Нет связи между контроллером и экструдером January 06, 2011 05:44AM |
Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Program Files\RepRap\reprap-mendel-20100806>reprap C:\Program Files\RepRap\reprap-mendel-20100806>rem reprap-host -- runs Reprap Ja va host code with an appropriate classpath C:\Program Files\RepRap\reprap-mendel-20100806>rem Amount of RAM to allow Java V M to use C:\Program Files\RepRap\reprap-mendel-20100806>set REPRAP_RAM_SIZE=1024M C:\Program Files\RepRap\reprap-mendel-20100806>rem reprap.jar file and stl file C:\Program Files\RepRap\reprap-mendel-20100806>set REPRAP_DIR=C:\Program Files\R eprap C:\Program Files\RepRap\reprap-mendel-20100806>rem Java3D and j3d.org libraries C:\Program Files\RepRap\reprap-mendel-20100806>rem set JAVA_LIBRARY_DIR=C:\Progr am Files\Reprap C:\Program Files\RepRap\reprap-mendel-20100806>rem cd so we can find the reprap- wv.stl file. Can we avoid this?? C:\Program Files\RepRap\reprap-mendel-20100806>IF NOT EXIST reprap-wv.stl cd "C: \Program Files\Reprap" C:\Program Files\RepRap\reprap-mendel-20100806>java -cp ".\reprap.jar;.\RXTXcomm .jar;.\j3dcore.jar;.\j3d-org-java3d-all.jar;.\j3dutils.jar;.\swing-layout-1.0.3. jar;.\vecmath.jar;." -Xmx1024M org/reprap/Main Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 comms: G-code: N0 T0 *26 dequeued and sent [0,000s/-1294310168854ms] ERROR: GCodeWriter.waitForResponse() - request to resend from line 11. RepRap s aid: rs 11 Serial Error: Linenumber (0) is not last + 1 (0), line received: ►♀ [ 0,047s/47ms] comms: Response: rs 11 Serial Error: Linenumber (0) is not last + 1 (0), line re ceived: ►♀ [0,047s/0ms] comms: G-code: N11 M113 *48 dequeued and sent [0,047s/0ms] comms: Response: ok intercom::waitError() [0,078s/31ms] comms: G-code: N12 M105 *52 dequeued and sent [0,078s/0ms] comms: Response: ok T:0 B:0 intercom::queueError() [0,109s/31ms] comms: G-code: N13 M105 *53 dequeued and sent [0,109s/0ms] comms: Response: ok T:0 B:0 intercom::queueError() [0,140s/31ms] comms: G-code: N14 M105 *50 dequeued and sent [1,640s/1500ms] comms: Response: ok T:0 B:0 intercom::queueError() [1,703s/63ms] comms: G-code: N15 M105 *51 dequeued and sent [1,703s/0ms] comms: Response: ok T:0 B:0 intercom::queueError() [1,734s/31ms] comms: G-code: N16 M105 *48 dequeued and sent [3,234s/1500ms] comms: Response: ok T:0 B:0 intercom::queueError() [3,265s/31ms] comms: G-code: N17 M105 *49 dequeued and sent [3,281s/16ms] comms: Response: ok T:0 B:0 intercom::queueError() [3,297s/16ms] comms: G-code: N18 M105 *62 dequeued and sent [4,812s/1515ms] comms: Response: ok T:0 B:0 intercom::waitError() [4,843s/31ms] comms: G-code: N19 M105 *63 dequeued and sent [4,859s/16ms] comms: Response: ok T:0 B:0 intercom::queueError() [4,875s/16ms]Что делать? Где смотреть?
Re: Нет связи между контроллером и экструдером January 07, 2011 02:27PM |
Re: Нет связи между контроллером и экструдером January 08, 2011 05:20AM |
Re: Нет связи между контроллером и экструдером January 08, 2011 09:50AM |
Re: Нет связи между контроллером и экструдером January 08, 2011 03:23PM |
Re: Нет связи между контроллером и экструдером January 10, 2011 04:05PM |
Re: Нет связи между контроллером и экструдером January 11, 2011 08:13AM |
C:\Program Files\RepRap\reprap-mendel-20100806>java -cp ".\reprap.jar;.\RXTXcomm .jar;.\j3dcore.jar;.\j3d-org-java3d-all.jar;.\j3dutils.jar;.\swing-layout-1.0.3. jar;.\vecmath.jar;." -Xmx1024M org/reprap/Main DEBUG: The distribution preferences file and yours match. This is good. [0,016s /-1294751383968ms] DEBUG: GCode opening port COM4 [0,109s/93ms] Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 DEBUG: Attempting to initialize Arduino/Sanguino [0,469s/360ms] comms: G-code: N0 T0 *26 dequeued and sent [4,828s/4359ms] comms: Response: ok [4,828s/0ms] comms: G-code: N1 M113 *1 dequeued and sent [4,844s/16ms] comms: Response: ok intercom::waitError() [4,859s/15ms] comms: G-code: N2 M105 *5 dequeued and sent [4,875s/16ms] comms: Response: ok T:0 B:0 intercom::queueError() [4,891s/16ms] comms: G-code: N3 M105 *4 dequeued and sent [4,906s/15ms] comms: Response: ok T:0 B:0 intercom::queueError() [4,937s/31ms] comms: G-code: N4 M105 *3 dequeued and sent [6,437s/1500ms] comms: Response: ok T:0 B:0 intercom::queueError() [6,469s/32ms]Если температура передаётся именно по RS485 то проблема именно в нём. Придётся прибегнуть к помощи старого друга С1-65A...
Re: Нет связи между контроллером и экструдером January 11, 2011 12:26PM |
Re: Нет связи между контроллером и экструдером January 11, 2011 01:41PM |
Re: Нет связи между контроллером и экструдером January 11, 2011 04:11PM |
Re: Нет связи между контроллером и экструдером January 11, 2011 04:26PM |
Re: Нет связи между контроллером и экструдером January 12, 2011 04:38AM |
Re: Нет связи между контроллером и экструдером January 13, 2011 08:38AM |
Re: Нет связи между контроллером и экструдером January 13, 2011 05:07PM |
Re: Нет связи между контроллером и экструдером January 14, 2011 03:23PM |
Re: Нет связи между контроллером и экструдером January 19, 2011 09:22AM |
Re: Нет связи между контроллером и экструдером January 21, 2011 04:07AM |
Re: Нет связи между контроллером и экструдером January 21, 2011 06:33AM |
Re: Нет связи между контроллером и экструдером January 21, 2011 01:20PM |
Re: Нет связи между контроллером и экструдером January 22, 2011 11:58PM |
Re: Нет связи между контроллером и экструдером January 23, 2011 05:38AM |
Re: Нет связи между контроллером и экструдером January 24, 2011 04:36AM |
Re: Нет связи между контроллером и экструдером January 24, 2011 05:20AM |
Admin Registered: 16 years ago Posts: 13,886 |
Re: Нет связи между контроллером и экструдером January 27, 2011 09:44AM |
comms: G-code: N69 M105 *56 dequeued and sent [55,015s/1500ms] comms: Response: ok T:25 B:-17 [55,046s/31ms] comms: G-code: N70 M105 *48 dequeued and sent [55,078s/32ms] comms: Response: ok T:25 B:-17 [55,093s/15ms] comms: G-code: N71 M105 *49 dequeued and sent [56,593s/1500ms] comms: Response: ok T:25 B:-17 [56,609s/16ms] comms: G-code: N72 M105 *50 dequeued and sent [56,609s/0ms] comms: Response: ok T:25 B:-17 [56,640s/31ms] comms: G-code: N73 G1 F3000.0 *71 dequeued and sent [57,468s/828ms] comms: Response: ok [57,468s/0ms] comms: G-code: N74 G1 E251.0 *118 dequeued and sent [57,484s/16ms] comms: Response: ok [57,484s/0ms] comms: G-code: N75 G1 F1500.0 *70 dequeued and sent [57,500s/16ms] comms: Response: ok [57,500s/0ms] comms: G-code: N76 M105 *54 dequeued and sent [58,156s/656ms] comms: Response: ok T:22 B:-19 [62,562s/4406ms] comms: G-code: N77 M105 *55 dequeued and sent [62,562s/0ms] comms: Response: ok T:22 B:-19 [62,593s/31ms] comms: G-code: N78 M105 *56 dequeued and sent [64,109s/1516ms] comms: Response: ok T:22 B:-19 [64,125s/16ms]Светодиоды котроллера шаговика на экструдере мигают все т.е. каналы рабочие.
Re: Нет связи между контроллером и экструдером January 27, 2011 10:00AM |
Re: Нет связи между контроллером и экструдером January 27, 2011 04:14PM |
Re: Нет связи между контроллером и экструдером January 27, 2011 05:35PM |
Re: Нет связи между контроллером и экструдером January 28, 2011 09:00AM |
Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\sergey.HOME5B>cd "\Program Files\RepRap\reprap-mendel- 20110127" C:\Program Files\RepRap\reprap-mendel-20110127>reprap.bat C:\Program Files\RepRap\reprap-mendel-20110127>rem reprap-host -- runs Reprap Ja va host code with an appropriate classpath C:\Program Files\RepRap\reprap-mendel-20110127>rem Amount of RAM to allow Java V M to use C:\Program Files\RepRap\reprap-mendel-20110127>set REPRAP_RAM_SIZE=1024M C:\Program Files\RepRap\reprap-mendel-20110127>rem reprap.jar file and stl file C:\Program Files\RepRap\reprap-mendel-20110127>set REPRAP_DIR=C:\Program Files\R eprap C:\Program Files\RepRap\reprap-mendel-20110127>rem Java3D and j3d.org libraries C:\Program Files\RepRap\reprap-mendel-20110127>rem set JAVA_LIBRARY_DIR=C:\Progr am Files\Reprap C:\Program Files\RepRap\reprap-mendel-20110127>rem cd so we can find the reprap- wv.stl file. Can we avoid this?? C:\Program Files\RepRap\reprap-mendel-20110127>IF NOT EXIST reprap-wv.stl cd "C: \Program Files\Reprap" C:\Program Files\RepRap\reprap-mendel-20110127>java -cp ".\reprap.jar;.\RXTXcomm .jar;.\j3dcore.jar;.\j3d-org-java3d-all.jar;.\j3dutils.jar;.\swing-layout-1.0.3. jar;.\vecmath.jar;." -Xmx1024M org/reprap/Main Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 comms: G-code: N0 M110 *3 dequeued and sent [0,000s/-1296222429343ms] ERROR: GCodeWriter.waitForResponse() - request to resend from line 0. RepRap sa id: rs 0 Serial Error: checksum mismatch. Remote (3) not equal to local (51), l ine received: 0000000N0 M110 *3 [1,032s/1032ms] comms: Response: rs 0 Serial Error: checksum mismatch. Remote (3) not equal to local (51), line received: 0000000N0 M110 *3 [1,032s/0ms] comms: G-code: N0 M110 *3 dequeued and sent [1,032s/0ms] comms: Response: ok [1,047s/15ms] comms: G-code: N1 T0 *27 dequeued and sent [3,360s/2313ms] comms: Response: ok [3,360s/0ms] comms: G-code: N2 M113 *2 dequeued and sent [3,375s/15ms] comms: Response: ok [3,375s/0ms] comms: G-code: N3 M105 *4 dequeued and sent [3,391s/16ms] comms: Response: ok T:18 B:-23 [3,407s/16ms]
Re: Нет связи между контроллером и экструдером January 28, 2011 09:31AM |
Re: Нет связи между контроллером и экструдером January 29, 2011 01:54PM |
