Assargadon's self-introduction.
Posted by Assargadon
January 02, 2008 01:43PM
I observe the RepRap site for a long period of time. It was only the very exiting idea, when I found it first time. The idea was greate but, as far as nothing was made at those time, I doubted it will reach something. I was pessimistic and there are nothing I can help a project with...so I practically forget this project.
So glad I make a mistake.
Since that time I take my degree, I worked some time in IT and now I'm mooving in financial sphere (really unexpected for me, heh). And one day I saw the information about the reprap...somewhere, I don't remember now. It was inspiring chock for me, really.
So I should describe my plans now.
Re: Assargadon's self-introduction.
January 02, 2008 01:54PM
I have a possibility of buying this ancient soviete-union-times 3-axis positioning device: [[http://richart-consalt.ru/robot.jpg]]. It should cost me about $40-$50, and it's fairly cheap, isn't it? I know it working (geeks in university used it for some reason half a year before), but problem is no one know the control protocol (this geeks got some informetion trought revers-engeenering...) and I even don't know if motors of this robot is steppers or not (I hope they do).
January 02, 2008 02:13PM
The big black box you can see at the photo (see the link above) is the control device. I think, easysest way is abandon this device at all, and provide the motors with reprap electronics.
So as far as I got this soviet-time-system, I should order the electronic kit from Zach (rrrf.org). I don't check it, but I'm sure it's not a problem to find the electronical components - we have a big electronics market every week-end.
So my first milestone is to force this positioning system to move itself by my orders.
I will have a really big problem if motors of this system is not steppers. Maybe it will be possible for me to use Zach's NEMA 23 motor (http://store.rrrf.org/product_info.php?products_id=59)...but it will be a really big problem. I have no manufacturing skills at all and I just cannot imagine how it can be accomplished. Maybe I should find someone to perform it for me.
One of the targets I want to reach with this project - to gain some manufacturing/electronics skills.
January 02, 2008 02:20PM
When my positioning system will be functional, I should order the extrudedr toolhead kit from [www.bitsfrombytes.com] (sorry, Zach, and thank for the link), assemle it and force to work.
It's my second milestone - both the positioning and extruder ready, assembled, provided with control electronics and working.
The last step will be an attaching the extruder to positioning device. It's a really big problem for me now - I just don't know how I can perform thee. Maybe I find some usefull idea till that time...or mayube I just attach it with some sort of good glue, heh.
January 02, 2008 02:26PM
As I told before, I'm not very good in manufacturing or engeeniring.
My fields are mathematics, phisics, and, after all, I'm good programmer.
If someone have any Ideas I can help the RepRap project, you are welcome.
January 03, 2008 01:54AM
The server hosting the picture:
[richart-consalt.ru]
seems to be down. I assume you are describing a x-y-z 3-axis machine, rather than something like an human arm or tripod. How big is it? Would it also be useful as a CNC router?
My first step would be to contact the manufacturer of the machine to get the documentation and software.
Hopefully you will be able to use the existing motors. You should be able to figure out what kind of motors they are either by googling the information printed on the motor or by examing the wires going in to it with the aid of an ohmmeter.
How are the motors mounted onto the machine? If it is 4 bolts at the corners of a square, measure the distance between the bolts. If they are 47.1 mm you can use a NEMA 23 motor without fabricating an adaptor plate. If they are not 47.1 mm you may want to buy steppers that fit your machine or fabricate an adaptor plate out of acrylic or aluminum.
"47.1 mm" via:
[www.kelinginc.net]
Also look at how the shaft of the motor couples to the the shaft of the machine. You'll want to get the same kind of shaft or use a shaft adapter. (For light use, a bit of silicone/rubber tubing may work.
Regarding how you can help the RepRap project, I would suggest you familiarize yourself with the software as a first step.
Eventually, we'll want Russian-language documentation of the project. Right now, we're still in development, and everything keeps changing, so it is too early to maintain other-language documentation.
If you end up building a Darwin-type RepRap, you may want to write down who your supppliers are. (mcmaster.com doesn't ship to *.ru (or anywhere else outside the US.) smiling smiley
VDX
January 03, 2008 05:31PM
Hi Assargadon and Sebastien,
... here is the image of the robot:
It seems to ba a fully usable concept, but the motor-type isn't so clear - could be old-styled 3-phase-steppers, as they are longer and taller, then normal steppers ...
When the motors arent't conventional steppers, then you have to bring to work the driver -- if they are, and you cant't run the driver, then it would be best to use the reprap-electronics or Zachs arduinos ...
Viktor
January 04, 2008 05:28PM
Thanks for so quick answer - I'm really inspired by it.
SebastienBailard Wrote:
> How big is it?
Working area is cube with 25-30 santimeters side.
Yes, I think it strong enought for it. I going to use it like subtractive-manufacturing CNC miller...just after I build RepRap of some kind using this as RepStrap.
Yup...problem is, as I told before, this robot was made in time of soviet union...so it's ABSOLUTELY impossible to find ANY documentation about it.
I'm really doubt it will be possible to find something THIS way...becouse, as I told before, this robot was maked in soviet union time...so, motors was made at those time, too...in russia.
Yes, it's something I should to do - but I'm not sure I know the way waht I should measure and how I should interpret the results. I understand eit will be quite impossible to tell me such information just here - but I have a very usefull and unique skill - I skilled in READING smiling smiley So I need something to read to get general information about what I should searching for. I already start the process using wikipedia smiling smiley
What you called "familiarize"?
I install thee, it works...crashing sometimes.
I install the SVN client and download the source code (don't yet trying to compile it).
I admit it smiling smiley
Yes. I mean some other help like inventing slices filling alhorithm, for example, or writing code for chips (i have a little expirience in low-level programming).
Yes, and it will be awful.
Hmm...i thinking about writing my one (i don't know how far reverse-engeeniring, I told before, reaches). I afraid that, despite the fact my driver WILL work, I'll be forced to make a LOT of extra job to make the raprap software working with my driver.
Maybe changing the drives and electronics completely will be easier...but I'm not sure.
VDX
January 04, 2008 05:45PM
Hi Assargadon,
... try to open a motor, then you can test, if it's a common stepper and how much phases it has.
- 'normal' bipolar steppers should have 4, 6 or 8 wires - 3-phased have 3, 4 or 6 (sometimes you have some more wires for a tacho or coarse angular sensor, but separated from the motor-lines)
- when opened, you should have a permanent-magnetized rotor toothed like a gear
- the inner stator is toothed too, but in two separated rings displaced by half a teeth (then you can count the teeth for calculating steps-per-turn)
Best you open a motor an post some images, so it would be easier to check ...
Viktor
January 05, 2008 04:53AM
On the other hand, sometimes opening a motor damages it so that it is weaker or broken.
I'd start with a ohm meter and building up a n x n table of resistances between wires {0, ... , n}.
January 31, 2008 11:17AM
I just receive PCBs (and some other stuff like nichrome wire) from Zach.
February 07, 2008 04:30AM
This is why I suggested not disassembling the motors;
[yarchive.net]
This is a serious misnomer. It should read: DO NOT DISASSEMBLE
without reading the manual. The stator must not be removed from the
20-pole magnet without at the same time pushing in an iron plug of the
same diameter. The magnet will demagnetize itself instantly if the
magnetic return path (the stator or "keeper") is broken even for a
nanosecond. This continuity cannot be over emphasized. All 20 poles
must be in close proximity to a continuous magnetic return path at all
times. Most Dyno Hubs have been disassembled by unwitting mechanics
and their magnets are "flat" producing negligible power ever after.
The rest of
[yarchive.net]
is worth reading, if you are bored or like bikes.
Ant
November 03, 2008 02:54AM
I saw the picture, and that machine would be useless as a router or milling. It is not rigid enough. It could perhaps mill small parts very close to the near end of travel.
A stepper motor will not have an encoder to tell it location. Look to see if there is an encoder somewhere. I see 3 white cables that look like RS232 cables (sort of). I suspect those are encoders. If they are, that would mean the motors are DC motors. Probably low voltage.
You might try putting 5volts on the motor see if it turns. It might need more voltage. If it is a stepper motor it will lock up when power is applied, be more difficult to turn than it is without power. If it is a DC motor, it'll turn when power is applied.
I'm in the process of making a RepRap which will use DC motors rather than steppers. When it is complete you'll be able to use those electronics, probably.
Tony
