Re: Support material candidates July 01, 2008 09:10PM |
Re: Support material candidates July 02, 2008 08:33AM |
Re: Support material candidates July 02, 2008 04:48PM |
Re: Support material candidates July 03, 2008 04:01AM |
Re: Support material candidates July 03, 2008 12:55PM |
Re: Support material candidates July 07, 2008 01:14PM |
Re: Support material candidates July 07, 2008 02:03PM |
Re: Support material candidates July 25, 2008 05:54AM |
Re: Support material candidates July 25, 2008 06:31AM |
Has anyone suggested solder yet? Or any other metal?
Re: Support material candidates July 25, 2008 03:29PM |
Re: Support material candidates July 25, 2008 03:44PM |
Admin Registered: 17 years ago Posts: 7,879 |
You can only extrude paste like substances. Liquids will just flow out of the nozzle uncontrollably and run away. There is a metal extruder but that is for filling channels in plastic.Quote
I imagine you could control it such that you could get a fairly flat surface for a layer with some tweaking (or at least a predictably curved one, based on the properties of the solder mixture).
The main reason for warping is that hot layers are extruded onto cold layers that have already frozen. They in turn freeze but they are still hot so they contract afterwards. This puts the layer below under stress leading to it curling upwards.Quote
Is that the correct description of your warping problem, which supposedly necessitates adhesion between the extruded material and the support material?
Re: Support material candidates July 25, 2008 05:13PM |
Re: Support material candidates July 26, 2008 11:49AM |
Re: Support material candidates July 26, 2008 11:54AM |
Re: Support material candidates July 26, 2008 12:27PM |
Oh, I didn't mean you would use a standard extruder head. It would probably have to be some complex piece of equipment
How about simply injecting a given quantity of a suitably viscous liquid into areas that need support
Re: Support material candidates July 26, 2008 04:02PM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: Support material candidates July 26, 2008 04:21PM |
Re: Support material candidates July 26, 2008 06:23PM |
I did not believe that it would be simple. Perhaps I should stick to building a working repstrap first to have something to test with smiling smiley.
Re: Support material candidates July 26, 2008 10:51PM |
Admin Registered: 17 years ago Posts: 1,915 |
Re: Support material candidates July 27, 2008 05:49AM |
Possibly not.
Re: Support material candidates July 27, 2008 05:52AM |
Where's that then?Quote
A few hundred miles north, and people seem to be throwing away old machine tools for pocket change.
Re: Support material candidates July 27, 2008 06:13AM |
Re: Support material candidates July 27, 2008 11:27PM |
Re: Support material candidates July 28, 2008 04:12PM |
Is heating the object feasible
It would probably be simpler and cheaper to pivot the building platform (and/or build object).
Re: Support material candidates August 21, 2008 01:49AM |
Re: Support material candidates August 21, 2008 02:15AM |
Re: Support material candidates August 23, 2008 12:02AM |
Re: Support material candidates August 23, 2008 03:26PM |
What's wrong with the various(?) water-soluble polymers?
Mr. Bowyer
