Hi all!
I made models of the angle iron bedframe I'm planning on using for my repstrap. I'll use these to play around with configurations before deciding on how to cut it up, just figured I'd put them out here if anyone else is using bedframes as a material.
Included are the .blend and .dxf files for the angle iron frame, the end pieces (which were riveted on along with another funky connector plate I didn't model), and a simple cylinder the size of a skate bearing. It's all in inches, cause the material is shaped to that standard.
enjoy!
