Extruder flow rate limitations
Posted by annodomini2
February 12, 2011 04:24AM
One of the fundamental print speed issues is the extruder flow rate, a variable aperture nozzle could in theory help and changing nozzles, but fundamentally if you can increase the flow rate you can increase the print speed.
So could we detail the limitations to increased flow rate here, which may help maximise the potential of the system.
If this works can we make this thread sticky and in future add to the wiki?
Re: Extruder flow rate limitations
February 12, 2011 12:40PM
another maximum is how fast you can heat the filament to temp equilibrium. Faster flow rates might need a larger melt zone inside the hot end in order to have sufficient melted plastic in the reservoir. But a larger melt zone will probably also make retraction a problem, leading to more ooze, but if the head is moving fast enough it might not be
another max speed limiter would be how quickly a build dissipates heat, and how long you have to wait for each layer to cool, but this can be sped up by a fan.
February 13, 2011 05:38AM
Here's a printer doing 300 mm/s with PLA:
[blog.ultimaker.com]
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
February 13, 2011 06:00AM
Damn!!
My 20x20x10 test print with 20% infill was 1/3rd done when I started watching it, and is only finishing as I type this!!
I will need to up my speed lol
