simpler extrusion tube
Posted by makeme
February 14, 2011 09:02PM
Has anyone tried just dousing a metal extruder in spray-on PTFE instead of inserting a PTFE tube into a metal support?
This stuff
[www.dowcorning.com]
[www.amazon.com]
Claims up to 450*F/240*C, which is basically high enough.
Edited 1 time(s). Last edit at 02/14/2011 10:04PM by makeme.
Re: simpler extrusion tube
February 15, 2011 01:27AM
Those lubricant sprays would not last, they would be pushed out by the plastic. An actual baked on teflon coating might work though.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
February 15, 2011 01:59AM
The amazon one you linked is a lubricant with PTFE, not really PTFE-only coating. I don't think that would work out well.
The second one is recommended for "Rubber guides, sliding doors, furniture hinges, small mechanism in office machines and sunroof seals" which sounds like just what we're looking for. I couldn't find a price though, you'd have to call you local dow corning distributor and ask.
Somebody referenced a spray-on PTFE coating sold for refinishing guns. Should also be a very durable finish, IIRC was around $35 a can.
However, according to nophead's research on the subject, the transition zone (melt zone) needs to be either short, tapered, OR slippery. I think that getting two out of three should be enough to get a rock-solid reliable extruder no matter which plastic you push through it. Getting all three would be a bonus, and I don't think can be done without some sort of spray-on coating like this. It'd be hard to get it all over the inside of an extruder barrel, but I'm sure it could be done well enough.
I'm building it with Baling Wire
February 16, 2011 02:07AM
February 16, 2011 12:24PM
That looks really nice. Good to 450C, recommended for thermoplastics. Drying time is quite high (8-12 hours) so should be easy to work with.
Costs $47 though. You could do a lot of extruder barrels with that, but very pricey for an individual.
February 16, 2011 09:58PM
I'd be curious to try Teflon ENP plating on metal extruder parts: [www.reliableplating.com]
[haveblue.org]
