Q: Proper use of Speed (Bridge flow vs bridge feed rate)
Posted by Andke
January 02, 2012 05:20AM
The help on SFACT's Speed tab is not helping much, so I need to ask:
If my "main feed rate" is 12mm/s and perimeter is 6mm/s
What If I wish to slow down bridge printing ?
"Bridge Feed rate ratio to perimeter feed" (default 1) should be set to something close or equal to the value of "bridge flow rate (scaler)" (default 1) ?
So If I set both to 0.7 - I'll get 70% of the 6mm/s speed - with properly scaled amount of extruded material ?
and If I only reduce "feed rate" - it'll only reduce the head speed, while extruding (too much) material ?
- not sure if I got his right smiling smiley
Re: Q: Proper use of Speed (Bridge flow vs bridge feed rate)
January 03, 2012 01:27AM
Looks like you got it right. What machine are you printing on that you are using such low speeds?
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
January 03, 2012 03:38AM
It's a larger version of Prusa Mendel, did not experiment yet with higher speeds, I need precision over speed. - and with higher speed, the extruded plastic is sometimes not as perfectly placed, as with lower speed.
January 06, 2012 12:48AM
woof! but 6mm/s! sad smiley
January 06, 2012 02:40AM
what would you suggest ? - current settings are 10 and 6mm/s (perimeter)
January 12, 2012 05:51AM
My normal print speed is 80mm/sec fill and 65mm/sec perimeter.
With travel speed of 195mm/sec.
Getting quality, accurate prints.
On a Prusa Mendel with Linear bearings.
Rich
[richrap.blogspot.com]
January 12, 2012 06:24AM
If I go that fast, filament gets dragged from it's place on travel or circle, before bonding with the layer beneath.
what extruder/hotend do you use ?
(I too use bigger than normal prusa mendel, with linear bearings )
Edited 1 time(s). Last edit at 01/12/2012 06:25AM by Andke.
January 12, 2012 10:55AM
I use j-head 0.5mm and mendel-parts v5 0.35mm
both same speeds.
0.3 or lower layer heights
January 18, 2012 04:09PM
ok, so you use a 0.5mm nozzle, with 0,3mm layer ? - and extrusion width is then ~0.7? what's your measured extrusion width ?
If I reduced layer thickness, (using 0.4 now) that would most likely reduce the possibility of dragging filament in a shortcut across a circle.
August 05, 2012 03:15PM
> 65mm/sec perimeter.
> Rich
Hello Richard,
Do you use Skeinforge to generate g code? if so, what is your actual Flow Rate settings for that speed?
Your bridge ratios are grater or lower than 1?
Thank you!!!!
Ernesto Pareja
dcctrains.netne.net
