Graphite instead of Teflon
Posted by 691175002
November 06, 2012 01:10AM
Has anyone tried making a liner out of graphite instead of teflon? Both are low friction but graphite is good to several thousand degrees.
The stratasys patent mentions graphite as an alternative to teflon as well.
VDX
Re: Graphite instead of Teflon
November 06, 2012 02:25AM
... graphite is brittle and you have to polish/ream the inner bore for perfect feeding, while PTFE tubing is ready to use - and yes, more heat-resistance would be fine ... but you didn't really want to heat the plastic to higher temps than actually used ...
Viktor
yru
November 23, 2012 06:03PM
and it conducts heat preety nicely.
