Has anyone tried ABS weld rod from Us Plastic?
Posted by prcdslnc13
February 12, 2013 12:47PM
[www.usplastic.com]
Its way cheaper then most of the plastic suppliers Ive seen, granted it only comes in two colors but heck 12$ a pound??
Re: Has anyone tried ABS weld rod from Us Plastic?
February 13, 2013 06:14PM
3.175mm is 1/8"...so it should work with at least some hotends. It sure would be interesting to try it. They also have other materials such as Polyethylene and polypropylene as well. The other materials I see under welding rod look like they are straight lengths of plastics...not sure how that'd work out. Maybe someone should give it a try?
Edited 1 time(s). Last edit at 02/13/2013 06:14PM by Bobbitay.
February 15, 2013 03:49PM
I was planning to order some teflon and some tygon tubing to play with different hot end designs so I may throw a pound of this in too...
February 24, 2013 09:55AM
I suppose that could be a real benefit for those who are creating SAE versions of the printers. The build cost for a printer isn't chicken change, but the cost of plastic is an ongoing one that adds up to well over the initial investment in very short order for an aggresive "printee".
Thanks for the heads-up
