45 Degree Overhangs September 06, 2008 06:21AM |
Re: 45 Degree Overhangs September 06, 2008 07:19AM |
A recent blog post implied that Dr Bowyer was working on this problem, so it might just be solved soon without having to resort to overhang hacks.
Re: 45 Degree Overhangs September 06, 2008 07:33AM |
Re: 45 Degree Overhangs September 06, 2008 09:15AM |
Re: 45 Degree Overhangs September 07, 2008 05:58PM |
Re: 45 Degree Overhangs September 08, 2008 04:03AM |
\..... x\.... \... #\.. # \. # \
\..... #\.... #y\... # #\.. # # \. # # \
Re: 45 Degree Overhangs September 08, 2008 04:37AM |
Admin Registered: 18 years ago Posts: 14,154 |
Re: 45 Degree Overhangs September 08, 2008 05:31AM |
Re: 45 Degree Overhangs September 08, 2008 05:47AM |
Re: 45 Degree Overhangs September 08, 2008 05:56AM |
Re: 45 Degree Overhangs September 09, 2008 11:55PM |
Re: 45 Degree Overhangs September 10, 2008 04:24AM |
analyze the overhanging slice with reference to material properties like bridging strength
and shrinkage
and the amount (length) of the overhang(tricky)
This is without addressing the problems of hollow objects and other hard to detach areas.
This is why I am still a fan of finding a soluble or otherwise flowable support material which could be recycled.
Re: 45 Degree Overhangs September 10, 2008 06:37PM |
Re: 45 Degree Overhangs September 11, 2008 04:33AM |
Say what? What about PVOH
In any case, the statement that "absoluetly no-one has any idea what on earth it could possibly be" is quite unbelievable
Re: 45 Degree Overhangs September 13, 2008 10:03AM |
Re: 45 Degree Overhangs September 13, 2008 10:46AM |
I also believe that the support structures should be IN the stl file rather than calculated by the software
Re: 45 Degree Overhangs September 14, 2008 08:27AM |
Re: 45 Degree Overhangs September 17, 2008 12:56PM |
). Or something like that.
Re: 45 Degree Overhangs September 30, 2008 01:27AM |
Re: 45 Degree Overhangs September 30, 2008 03:52AM |
Why not use another type of plastic as support material?
I'd rather have both. We should continue working on both software/firmware scaffold generation and soluble supports.
So, any progress on the scaffolds?
) so I'm in no particular rush to duplicate his efforts.|
Re: 45 Degree Overhangs October 21, 2008 01:05PM |
Re: 45 Degree Overhangs October 21, 2008 02:13PM |
Re: 45 Degree Overhangs October 21, 2008 06:56PM |
Re: 45 Degree Overhangs October 21, 2008 10:55PM |
Of course there is the slight issue of deposited material adhering to a rotated work surface...|
Re: 45 Degree Overhangs October 22, 2008 11:37AM |
Re: 45 Degree Overhangs October 22, 2008 11:40AM |
Admin Registered: 18 years ago Posts: 1,915 |
Re: 45 Degree Overhangs October 22, 2008 01:26PM |
Re: 45 Degree Overhangs October 22, 2008 01:32PM |
Re: 45 Degree Overhangs October 23, 2008 11:24AM |
Re: 45 Degree Overhangs October 23, 2008 11:55AM |
