Maximum nozzle diameter
Posted by Stanislav
March 12, 2013 05:51PM
Hello, this is my first post.
So - I need crude 3d printer to print relatively crude, radius 10mm at min, big (600x250 mm) and flat (6-8mm height) parts, on cardboard. And parts should stick to it.
Is it ok to use 2 or 2.5 mm nozzle for 4 mm abs/hdpe filament ? Or it should have good reduction for better pressure build-up inside extruded ? I had seen in one post of successful using of 1 mm nozzle. But, could it be made even bigger ?
Stanislav
Re: Maximum nozzle diameter
April 20, 2013 02:10PM
If you intend to print in plastic, say ABS, everything needs to scale up. The melt chamber will need to be quite large, in order to melt at a useful rate. The filament (assuming) will need to be wide. Might have a look at plastic welding systems for inspiration.
April 20, 2013 11:50PM
i thought the hot zone should be as small as possible for fast extruding, so the filament can be pushed with more pressure in the hot zone
April 22, 2013 07:04AM
Actually its a common mistake, but the pressure rises if the tube diameter increases and not the other way around, at least regarding to water (one of the main reasons why some irrigation systems fail - the tubes aren't just thick enough and the pressure is lost on the furthest sprinklers...)
April 22, 2013 04:08PM
no i mean something other, if the hot zone is long, the filament will be soft, long before it will be extruded, this soft filament can not build up pressure on the nozzle if its pushed, this is why we have stainless steel barrels with active cooling (stainless steel conducts heat bad) or with PEEK
October 04, 2013 11:04AM
With larger nozzles you will have a higher throughput of material. With a small heating volume like you use for 0.5 - 0.2mm Nozzles you will not be able to melt the material for a 2mm nozzle fast enough. You need more volume (preferably larger diameter not length) to liquify the filament sufficently fast.
You can just enlargen the nozzle diameter to 2mm, but you will need to go slow then.
I tried up to 1mm with my Merlin Nozzle and it worked fine, i had to limit speed a bit though.
Cheers
Björn
