Design using watter pipe if the pipe is replaced by 8020 could it be straighter and strong enough?
Posted by josheeg
Design using watter pipe if the pipe is replaced by 8020 could it be straighter and strong enough? 8020 makes 2 kinds of extruded aluminum blocks the ones with the holes in it might be used to make a kit for less need for a drill press...
If the restrap needs to be built from the least number of tools that method might be it..
Edited 1 time(s). Last edit at 01/06/2009 03:58PM by josheeg.
