Ideas for High Temperature Extruder (printing Polycarbonate) April 27, 2013 07:56PM |
At 1/5 the thermal conductivity of PTFE and with it's consistent rigidity, MDF seems like it would be the perfect candidate for a thermal barrier in a high temperature extruder. I have not tested this yet, but I was wondering if anyone else had. Is there some unappealing property of MDF that I am overlooking? This could also cut down on the number of necessary CNC machined parts and junctions where the parts meet by replacing the conventional PTFE tube and brass barrel combo with a single MDF part. I was thinking that you could have the drive gear push the filament directly into the MDF insulator, which could have an M6 external thread on the bottom end with the brass nozzle/ heater block attached to it. Since the filament would feed directly from the "MDF barrel/insulator" into the brass nozzle, the melt zone could be reduced to about 4 to 10mm (depending on the nozzle design). This would really reduce the chances of the hot end clogging (right?). Sorry, I am explaining a lot of things in words...I wish I had of drawing of this -__-
Are there any other thermal insulators that would be better suited for the higher temps required for PC? I am trying to avoid the all-metal hot end at all costs. It seems like waaayyyyyy to much trouble than it's worth.
Let me know what you guys think!|
Re: Ideas for High Temperature Extruder (printing Polycarbonate) April 28, 2013 12:15AM |
While it performs well around heat bed temps, it starts smoking at 200C and by 350C it is billowing toxic smoke. Conclusion: MDF is not safe at high temps. Its a pity, MDF is a great insulator (even at 350C, I could touch the small MDF piece without burning myself). It could probably be used in the same way that PTFE/PEEK are used in conventional hot ends. I guess the all-metal/fan cooled design is the only way to go
Re: Ideas for High Temperature Extruder (printing Polycarbonate) April 28, 2013 04:32AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) April 28, 2013 03:10PM |
Admin Registered: 18 years ago Posts: 14,196 |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) May 11, 2013 03:37AM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) May 11, 2013 02:24PM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) May 17, 2013 02:18PM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) May 17, 2013 04:31PM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) May 28, 2013 05:26PM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) May 30, 2013 12:45AM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) July 05, 2013 06:27AM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) July 08, 2013 04:08PM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) July 12, 2013 07:33AM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) July 18, 2013 03:23PM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) July 19, 2013 12:45PM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) July 22, 2013 04:05AM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) July 22, 2013 09:57PM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) July 25, 2013 10:31AM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) July 25, 2013 09:24PM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) August 06, 2013 08:21AM |
Ideas for High Temperature Extruder (printing Peek September 06, 2014 05:08PM |
Re: Ideas for High Temperature Extruder (printing Polycarbonate) December 17, 2014 01:04AM |
