Re: Low cost 3D printing filament extruder for recycled plastics November 01, 2013 01:14PM |
Re: Low cost 3D printing filament extruder for recycled plastics November 07, 2013 08:58PM |
Re: Low cost 3D printing filament extruder for recycled plastics November 15, 2013 10:38PM |
Re: Low cost 3D printing filament extruder for recycled plastics November 18, 2013 12:55PM |
Re: Low cost 3D printing filament extruder for recycled plastics December 05, 2013 07:00AM |
Re: Low cost 3D printing filament extruder for recycled plastics December 14, 2013 02:24AM |
Steel tube length:200 mm (seamless stainless steel pipe)Quote
hiliagusta
Re: Low cost 3D printing filament extruder for recycled plastics March 03, 2014 02:16PM |
Re: Low cost 3D printing filament extruder for recycled plastics March 03, 2014 10:27PM |
Re: Low cost 3D printing filament extruder for recycled plastics March 03, 2014 11:05PM |
Re: Low cost 3D printing filament extruder for recycled plastics March 11, 2014 02:21PM |
Re: Low cost 3D printing filament extruder for recycled plastics March 12, 2014 03:22AM |
ianmcmill
Thanks for the pictures Xabbax !
But I wonder what parts you used in picture F and G.
And how did you fasten the nut on the motor shaft.
Is this a square nut that connects the axis to the nut (from picture E) ??
I put a hex-nut onto the motorshaft and drilled a hole between the thread of the nut and shaft and put a 2mm steal bolt into it so that it doesn't loosen while driving the auger bit.
[attachment 28421 bolt.jpg]
First I used Loctite but this was not strong enough to keep up with the motor power.
Re: Low cost 3D printing filament extruder for recycled plastics March 15, 2014 09:12AM |
Re: Low cost 3D printing filament extruder for recycled plastics March 15, 2014 03:42PM |
Re: Low cost 3D printing filament extruder for recycled plastics March 16, 2014 12:38PM |
ianmcmill
I just found your Masterbatch guide. Wonderful !!
I made some pictures of the filament and recorded an extrusion.
This is my extruder in action. The cracking sound of the pellets is nasty...
[www.youtube.com]
[attachment 28686 IMG_0820_web.jpg] This is the result of around 30 minutes extruding.
[attachment 28683 IMG_0825_web.jpg] Extrusion temp. around 270-280°C
[attachment 28684 IMG_0827_web.jpg] Extrusion temp. around 270-280°C
[attachment 28685 IMG_0830_web.jpg] Here you can see that the pellets are hollowed. May this cause those bubbles and ravels ?
Oh and I did not dry the pellets in the oven before.
And some questions:
1) What is your extrusion speed ? I am getting around 3m/min. That is 118"/min (for 2mm filament)
2) How fast is your motor running ? As it is a wiper motor, it has Speed 1 / 2 and "3" if you (or at least me) connect the speed 1 pin to ground and speed 2 to voltage in of the the motor.
3) Your nozzle diameter ? But I think I can recall you said something about 1mm.
Re: Low cost 3D printing filament extruder for recycled plastics March 16, 2014 01:55PM |
Re: Low cost 3D printing filament extruder for recycled plastics March 23, 2014 05:57PM |
ianmcmill
Thanks. Getting the laser to work was alot of fun.
Oh I forgot to mention that I am not using pure ABS but a PC/ABS compound. It combines the high temperature rating of PC with the lower one from ABS.
The datasheet says "Processing (melt) temperature = 240-270°C" (Link to the datasheet)
Also when extruding the temperature decreases continuously by circa 0.1-0.2 °C per second and the heater can't keep up. (200 Watt heater). After 30 minutes I stopped the extrusion and the temperature was down to 270°C from 305°C.
I did choose 305°C as a starting temperature because I thought an extra buffer might help the PID/Heater to counteract the temperature decline.
Re: Low cost 3D printing filament extruder for recycled plastics March 27, 2014 11:21AM |
Re: Low cost 3D printing filament extruder for recycled plastics April 10, 2014 05:17AM |
Re: Low cost 3D printing filament extruder for recycled plastics May 25, 2014 12:13AM |
Re: Low cost 3D printing filament extruder for recycled plastics May 25, 2014 01:23AM |
Re: Low cost 3D printing filament extruder for recycled plastics May 26, 2014 06:22AM |
Dougwar
I'm trying to do a filament extruder and I get this;
too many bubbles in it, temperature were 190C, do you have any suggestion?
what's the dimension between the nozzle and the auger?
Thanks
Re: Low cost 3D printing filament extruder for recycled plastics May 26, 2014 07:32PM |
Re: Low cost 3D printing filament extruder for recycled plastics July 05, 2014 09:39AM |
Anonymous User
Re: Low cost 3D printing filament extruder for recycled plastics July 09, 2014 02:11PM |
